NEW!!!! Daily Specials at Detailed Image
Old May 31, 2012 | 04:12 AM
  #1201
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (May 31, 2012) is Chemical Guys Jetseal 109.
Regular Price for 16 oz is $38.99. Today's price is $28.46!
  • One of our best selling sealants due to how well rounded of a product Jet Seal 109 is
  • Offers wax like depth and gloss, strong protection, ease of use, slick surface, and good durability
  • Works great on any colored vehicle, light, dark, metallic or non-metallic
  • Easy to apply and remove when applied properly, which is as thin as possible
  • For maximum durability, allow the sealant to cure for 24 hours prior to applying another coat
  • Best applied with a foam applicator pad and removed with a microfiber towel
  • When using a buffer, best applied with a blue fine finishing pad
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Jun 1, 2012 | 04:12 AM
  #1202
Detailed Image
Detailed Image
Today's Daily special (June 1, 2012) is DI Accessories Sheepskin Wash Mitt without thumb.
Regular Price is $10.99. Today's price is $8.57!
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
Old Jun 4, 2012 | 03:15 AM
  #1203
Detailed Image
Detailed Image
Today's Daily special (June 4, 2012) is Poorboy's World Bold & Bright Tire Gel.
Regular Price for 16 oz is $12.99. Today's price is $9.48!
  • Gel based version of the very popular Poorboy's Bold 'n Bright
  • Long durable tire shine that is easy to apply and does not sling!
Old Jun 5, 2012 | 04:13 AM
  #1204
Detailed Image
Detailed Image
Today's Daily special (June 5, 2012) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $17.99!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Jun 6, 2012 | 04:07 AM
  #1205
Detailed Image
Detailed Image
Today's Daily special (June 6, 2012) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $8.99. Today's price is $6.56!
Regular Price for 128 oz is $26.99. Today's price is $20.57!
  • One of our most powerful degreasers available, designed to easily cut through contamination
  • Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
  • Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Old Jun 7, 2012 | 04:11 AM
  #1206
Detailed Image
Detailed Image
Today's Daily special (June 7, 2012) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.25!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Old Jun 8, 2012 | 04:05 AM
  #1207
Detailed Image
Detailed Image
Today's Daily special (June 8, 2012) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.39!
Regular Price for 128 oz is $32.99. Today's price is $24.58!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
Old Jun 11, 2012 | 03:11 AM
  #1208
Detailed Image
Detailed Image
Today's Daily special (June 10, 2012) is Meguiar's All Purpose Cleaner Plus D103.
Regular Price for 128 oz is $15.99. Today's price is $11.35!
  • Best used to degrease engine bays, wheel wells, tires, interior clean ups, and much more
  • Effective even at a 10:1 dilution ratio making this an extremely good value
  • Works well in carpet extractors due to the low sudsing formula
  • Dilute and dispense using a 22 oz trigger spray bottle
Old Jun 12, 2012 | 04:13 AM
  #1209
Detailed Image
Detailed Image
Today's Daily special (June 12, 2012) is DI Accessories Fresh and Clean Air Freshener.
Regular Price is $4.99. Today's price is $3.64!
  • Fresh and Clean scent is universally loved!
  • Comes with a string and a clip so you can place it anywhere
  • Gel based scent lasts much longer than traditional ones
  • Helps eliminate odors
Old Jun 13, 2012 | 04:06 AM
  #1210
Detailed Image
Detailed Image
Today's Daily special (June 13, 2012) is NanoSkin AutoScrub Towel.
Regular Price for 12" x 12" is $49.99. Today's price is $35.99!
Old Jun 14, 2012 | 04:11 AM
  #1211
Detailed Image
Detailed Image
Today's Daily special (June 14, 2012) is Optimum Opti-Seal & Free Yellow Foam Applicator.
Regular Price for 8 oz is $24.99. Today's price is $18.49!
  • The ultimate in ease of use when it comes to protecting your vehicle with a sealant
  • Simply mist Opti-Seal onto your paint and walk away, no wiping is necessary when applied properly
  • Perfect for professional detailers or enthusiasts who are looking for maximum results in less time
  • Includes a FREE yellow foam applicator
Old Jun 15, 2012 | 04:15 AM
  #1212
Detailed Image
Detailed Image
Today's Daily special (June 15, 2012) is Meguiar's DA Microfiber Correction Compound.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
Regular Price for 32 oz is $34.99. Today's price is $26.07!
Regular Price for 128 oz is $84.99. Today's price is $63.32!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
Old Jun 18, 2012 | 03:12 AM
  #1213
Detailed Image
Detailed Image
Today's Daily special (June 18, 2012) is DI Microfiber Autofiber Zero Edge Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.69!
  • Highly effective edgeless design saves you time while improving results
  • Premium microfiber threads that feel extremely soft
  • Specializes in removing the left over product (i.e. polish, wax, etc.) from the paint
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
Old Jun 19, 2012 | 04:03 AM
  #1214
Detailed Image
Detailed Image
Today's Daily special (June 19, 2012) is Chemical Guys Microfiber Wash Cleaning Detergent.
Regular Price for 128 oz is $32.99. Today's price is $25.44!
  • Restore your microfiber to a like new condition every wash
  • Helps extend the life of your microfiber towels by keeping them fresher longer
  • Works great with any microfiber product: towel, applicator, mitt, etc.
Old Jun 20, 2012 | 04:47 AM
  #1215
Detailed Image
Detailed Image
Today's Daily special (June 20, 2012) is DI Accessories Disposable Floor Mat.
Regular Price for 10 pack is $5.99. Today's price is $4.25!
  • Durable mats to help prevent adding stains to clean carpets during a detail
  • Ensure your carpets look their best when you deliver the vehicle to your customer
Old Jun 21, 2012 | 04:18 AM
  #1216
Detailed Image
Detailed Image
Today's Daily special (June 21, 2012) is Porter Cable 7424XP Random Orbital Buffer.
Regular Price is $129.99. Today's price is $115.00!
  • The most popular random orbital polisher amongst enthusiasts and professionals alike
  • Powerful upgraded motor produces plenty of power to break down polishes and yield swirl free results
  • Save time and energy while achieving higher quality results compared to hand applications
  • The Porter Cable 7424 XP comes with a 3 year limited warranty, 1 year free service and a 90 day money back guarantee
  • 5" Counterweight is built in to the unit and can be replaced
Old Jun 22, 2012 | 04:11 AM
  #1217
Detailed Image
Detailed Image
Today's Daily special (June 22, 2012) is Dodo Juice Supernatural Shampoo.
Regular Price for 250 ml is $24.99. Today's price is $18.24!
  • A premium shampoo that sets the bar for what top quality shampoos should be
  • Extremely concentrated formula that can diluted 1500:1 or dilute 1 pump (2 ml) with each gallon of water
  • Perfect maintenance shampoo that will not strip off sealant or wax
  • Another outstanding Dodo Juice product that lives up to the Supernatural name
  • Utilizes sheeting agents, lubricants, lime scale inhibitors, anti-static properties and of course top notch cleaning agents
Old Jun 25, 2012 | 03:13 AM
  #1218
Detailed Image
Detailed Image
Today's Daily special (June 25, 2012) is DI Microfiber Waffle Weave Drying Towel.
Regular Price for 36" x 24" is $17.99. Today's price is $13.13!
  • One of the best options for drying your vehicle safely and quickly
  • Continues to soak up large amounts of water even after it's damp or wet
  • A fine silk edging ensures this is a safe towel
  • This towel can hold up to 10 times its weight with water
  • Use this towel with the sheeting method for the most efficient drying process
Old Jun 26, 2012 | 04:09 AM
  #1219
Detailed Image
Detailed Image
Today's Daily special (June 26, 2012) is TUF SHINE Tire Clearcoat.
Regular Price for 6 oz is $24.99. Today's price is $17.74!
  • The longest lasting tire shine we have ever tested, lasts several months at a minimum
  • One coat gives you a beautiful matte finish, two coats gives you an incredibly dark and glossy finish
  • Water based formula with anti-static properties that repel dust
  • Does not use any petroleum solvents, silicones or oils that can attract dust
  • To get the Tire Clearcoat and more check out the TUF SHINE Tire Appearance Kit
  • Withstands several pressure washing treatments and can be washed with gentle cleaners
Old Jun 27, 2012 | 04:09 AM
  #1220
Detailed Image
Detailed Image
Today's Daily special (June 27, 2012) is DI Microfiber All Purpose Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.83!
  • Our most versatile microfiber towel, most commonly used to apply and remove a variety of products
  • Easily remove polish residue, glazes, sealants and waxes with the medium nap microfiber towel
  • Works great for applying interior care products, specifically interior protectants
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
  • Remove the tag to minimize adding any imperfections to your paint
