NEW!!!! Daily Specials at Detailed Image
Old Aug 31, 2012 | 04:14 AM
  #1261
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (August 31, 2012) is Chemical Guys Black Light Hybrid Radiant Finish.
Regular Price for 16 oz is $27.99. Today's price is $20.15!
  • Incredibly deep reflection that makes any color paint look great
  • Get the protection of a sealant with the gloss of a high end wax or glaze
  • WARNING Insane Gloss Levels!
  • Extremely easy to apply and remove
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Sep 4, 2012 | 03:14 AM
  #1262
Detailed Image
Detailed Image
Today's Daily special (September 4, 2012) is CarPro Iron X Iron Remover ( IronX w/cherry scent ).
Regular Price for 500 ml is $19.99. Today's price is $15.20!
Regular Price for 1000 ml is $32.99. Today's price is $25.08!
Regular Price for 4 L is $119.99. Today's price is $93.00!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
Old Sep 5, 2012 | 04:14 AM
  #1263
Detailed Image
Detailed Image
Today's Daily special (September 5, 2012) is SONAX Glass Cleaner.
Regular Price for 500 ml is $12.99. Today's price is $9.35!
  • Highly effective glass cleaner!
  • Works great inside and outside of the vehicle
  • Engineered by Germany's best from SONAX headquarters
  • Gentle and environmentally responsible formula
Old Sep 6, 2012 | 04:13 AM
  #1264
Detailed Image
Detailed Image
Today's Daily special (September 6, 2012) is Clay Magic Medium Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.62!
  • Remove embedded surface contamination that does not come off during the washing process
  • Medium grade bars will remove contamination quickly, however it may result in micro-marring
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Follow up the medium grade clay bar with a finishing polish to remove any micro-marring
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Sep 7, 2012 | 04:10 AM
  #1265
Detailed Image
Detailed Image
Today's Daily special (September 7, 2012) is Poorboy's World Natty's Blue Paste Wax.
Regular Price for 8 oz is $21.99. Today's price is $16.38!
  • Arguably the best value of any carnauba wax on the market
  • Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
  • Easy to apply and remove with a foam applicator pad and a microfiber towel for removal
  • An 8 oz jar will last 20 plus uses when applied correctly
  • Works on all paints but looks exceptional on darker colors
Old Sep 10, 2012 | 03:16 AM
  #1266
Detailed Image
Detailed Image
Today's Daily special (September 10, 2012) is Chemical Guys Stripper Scent - Smell of Success.
Regular Price for 16 oz is $11.99. Today's price is $9.16!
  • Extra pleasant smell sure to please all!
  • This product comes with a happiness warning!
  • Active odor eliminators will subdue unpleasant smells at the source
Old Sep 11, 2012 | 04:19 AM
  #1267
Detailed Image
Detailed Image
Today's Daily special (September 11, 2012) is NanoSkin AutoScrub Fine Foam Pad.
Regular Price for 4" is $59.99. Today's price is $43.19!
Regular Price for 6" is $49.99. Today's price is $35.49!
  • The fastest way to safely deep clean your paint
  • Replaces the need for a clay bar while saving you time
  • Works with most orbital buffers with a hook and loop backing
  • Can be used 30 or more times so it's a better value than clay bars
  • Works great with the NanoSkin Glide
Old Sep 12, 2012 | 04:12 AM
  #1268
Detailed Image
Detailed Image
Today's Daily special (September 12, 2012) is Optimum Metal Polish.
Regular Price for 8 oz is $14.99. Today's price is $10.64!
Regular Price for 32 oz is $34.99. Today's price is $26.07!
  • Polish any metal or clear coated piece so it's clean and shinny again
  • Removes deeply embedded brake dust and road grime
  • Commonly used on wheels, exhaust tips, trim and more
  • New formula will clean, shine and protect in one step
Old Sep 13, 2012 | 04:14 AM
  #1269
Detailed Image
Detailed Image
Today's Daily special (September 13, 2012) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $4.31!
  • The ideal solution for achieving that streak free finish when caring for glass
  • Use a slow wiping motion, while applying some pressure to the glass polishing towel
  • The low, ultra thin nap ensures that there is no lint left behind on glass
  • Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
  • Always wash your microfiber products prior to first use and remove tags to ensure paint safe
Old Sep 14, 2012 | 04:10 AM
  #1270
Detailed Image
Detailed Image
Today's Daily special (September 14, 2012) is Lake Country Blue Fine Finishing Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.19!
Regular Price for 5.5 inch is $7.99. Today's price is $5.91!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • Our softest foam pad, the blue fine finishing pad, designed to apply ultra fine polishes, sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Blackfire Wet Diamond All Finish Paint Protection is one of the most popular sealants to apply with a blue pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • If you want to jewel or burnish the paint for some extra shine combine with the Menzerna Micro Polish SF 4500 (PO85RD)
Old Sep 14, 2012 | 10:49 AM
  #1271
logan09's Avatar
logan09
Hey just wanted to say thanks for providing these awesome deals to us here.
I ordered a thing of Klasse aio and some Natty Blue paste on the 12th and it got here (Central IA) at noon on the 14th! Exceptional shipping times. I will be doing business again very soon, thanks.
Old Sep 17, 2012 | 03:08 AM
  #1272
Detailed Image
Detailed Image
Today's Daily special (September 17, 2012) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.66!
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
Old Sep 18, 2012 | 04:10 AM
  #1273
Detailed Image
Detailed Image
Today's Daily special (September 18, 2012) is DI Microfiber Mini-Towel.
Regular Price for 8" x 8" is $2.99. Today's price is $2.23!
  • Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
  • Perfect for keeping your sunglasses clean and free of fingerprints
Old Sep 19, 2012 | 04:10 AM
  #1274
Detailed Image
Detailed Image
Today's Daily special (September 19, 2012) is Chemical Guys GlossWorkz Shampoo.
Regular Price for 16 oz is $12.99. Today's price is $9.61!
Regular Price for 128 oz is $42.99. Today's price is $33.31!
  • Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
  • Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
  • Use 1 oz per 4 to 5 gallons of water
Old Sep 20, 2012 | 04:09 AM
  #1275
Detailed Image
Detailed Image
Today's Daily special (September 20, 2012) is Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $16.05!
Regular Price for 6.25" is $23.99. Today's price is $17.75!
Regular Price for 3" is $13.99. Today's price is $9.93!
  • Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
  • This item includes 2x DA Microfiber Finishing Disc Buffing Pads
  • Outstanding polishing power that provides a high level of gloss
  • Microfiber buffing pads are changing the way detailers work
  • Use it with the Meguiar's Professional Backing Plate, 5" Product Code: W67DA, 6" Product Code: S6BP
Old Sep 21, 2012 | 04:17 AM
  #1276
Detailed Image
Detailed Image
Today's Daily special (September 21, 2012) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.46!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
  • You can clean these pads with the Lake Country Snappy Clean Pad Cleaner
Old Sep 24, 2012 | 03:14 AM
  #1277
Detailed Image
Detailed Image
Today's Daily special (September 24, 2012) is DI Accessories Sheepskin Wash Mitt without thumb.
Regular Price is $10.99. Today's price is $8.57!
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
Old Sep 25, 2012 | 04:11 AM
  #1278
Detailed Image
Detailed Image
Today's Daily special (September 25, 2012) is Optimum No Rinse Wash & Shine (ONR) New Formula 2012.
Regular Price for 32 oz is $15.99. Today's price is $11.67!
Regular Price for 128 oz is $39.99. Today's price is $28.39!
  • New formula launched in 2012 with more gloss, slicker feel and it releases contaminants better
  • Properly wash your car without the need for a hose or rinsing your vehicle
  • Use as a quick detailer and clay bar lubricant, mix 1 oz of ONR to 16oz of water
  • Favorite product of many high end detailers
  • Perfect for detailing on the go, those living in apartment complexes, washing in the winter, mobile detailing, etc.
Old Sep 26, 2012 | 04:12 AM
  #1279
Detailed Image
Detailed Image
Today's Daily special (September 26, 2012) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.44!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Sep 27, 2012 | 04:10 AM
  #1280
Detailed Image
Detailed Image
Today's Daily special (September 27, 2012) is Lake Country Blue Grout Sponge.
Regular Price is $5.99. Today's price is $4.25!
  • One of the most popular used wash mediums by professional detailers
  • Very soft and durable, while being able to hold tons of suds and water helps reduce imperfections
  • One of the best features of the grout sponge is that it releases contamination very easily
  • For maximum results, use in combination with a Grit Guard bucket insert
