NEW!!!! Daily Specials at Detailed Image
Old Apr 5, 2013 | 04:21 AM
  #1401
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (April 5, 2013) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $10.64!
Regular Price for 128 oz is $34.99. Today's price is $24.84!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Apr 8, 2013 | 03:02 AM
  #1402
Detailed Image
Detailed Image
Today's Daily special (April 8, 2013) is Optimum Opti-Lens Coating.
Regular Price for 10 cc is $59.99. Today's price is $45.00!
  • Easily protect your headlights from fading, yellowing, hazing, and road grime
  • Keep your headlights crystal clear for optimal clarity while driving
  • Unique resin based formula that bonds to the surface of your headlights for durable protection
  • Easy to apply to any smooth plastic surfaces
Old Apr 9, 2013 | 04:13 AM
  #1403
Detailed Image
Detailed Image
Today's Daily special (April 9, 2013) is DI Brushes All Purpose Exterior Brush.
Regular Price is $4.99. Today's price is $3.69!
  • Use it to safely clean the exterior of your vehicle
  • Soft and safe to use on various surfaces
  • Flagged-tip bristles are resistant to acids and detergents for added longevity
Old Apr 11, 2013 | 04:11 AM
  #1404
Detailed Image
Detailed Image
Today's Daily special (April 11, 2013) is Meguiar's Professional DA Polisher Backing Plate W67DA.
Regular Price for 5" is $19.99. Today's price is $15.53!
  • Soft core foam allows for easier maneuverability compared to stiffer backing plates
  • Works with any polisher with a 5/16th shaft (such as the Porter Cable 7424XP)
  • Durable one piece construction ensures a long life
  • Works best with 5.5" pads or larger
Old Apr 12, 2013 | 04:06 AM
  #1405
Detailed Image
Detailed Image
Today's Daily special (April 12, 2013) is DI Microfiber Autofiber Pocket Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.43!
  • Great microfiber towel with a unique paint safe design
  • Two large pockets help keep your hand in place while working side to side
  • Pockets helps protect your hand on both sides
  • Can be machine washed and dried
  • Saves you time while improving your results!
Old Apr 15, 2013 | 03:10 AM
  #1406
Detailed Image
Detailed Image
Today's Daily special (April 15, 2013) is Lake Country Detailing Stick.
Regular Price is $1.99. Today's price is $1.45!
  • Excellent tool for cleaning tough to reach areas
  • Rinse and re-use these sticks over and over again
  • Great tool for the front grill, exterior trim, engine bay, lug nuts, door jambs, side mirrors, etc.
  • Remove tough stains with the Lake Country Snappy Clean Pad Cleaner
  • Durable foam tip with 8" wooden handle
Old Apr 16, 2013 | 04:08 AM
  #1407
Detailed Image
Detailed Image
Today's Daily special (April 16, 2013) is Meguiar's Pad Conditioner Brush.
Regular Price is $13.99. Today's price is $10.35!
  • Helps remove excess product trapped in your buffing pad
  • Helps keep pads working in ideal condition
  • Safe on all foam pads and very easy to use!
Old Apr 18, 2013 | 04:16 AM
  #1408
Detailed Image
Detailed Image
Today's Daily special (April 18, 2013) is 303 Aerospace Protectant Wipes.
Regular Price is $7.99. Today's price is $5.95!
  • A convenient way to apply valuable UV protection
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • 40 Aerospace Protectant Wipes come in each bottle
  • Treated surfaces resist dust, soiling and staining plus it helps repel moisture
Old Apr 19, 2013 | 04:19 AM
  #1409
Detailed Image
Detailed Image
Today's Daily special (April 19, 2013) is DI Microfiber Black and Yellow Towel.
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
Old Apr 22, 2013 | 03:12 AM
  #1410
Detailed Image
Detailed Image
Today's Daily special (April 22, 2013) is DI Accessories DetailedImage.com License Plate Frame.
Regular Price is $5.99. Today's price is $4.25!
  • Black DetailedImage.com license plate frame with white lettering
  • "Clean Shine Protect" tag line
  • Thank you for your support!
Old Apr 23, 2013 | 04:11 AM
  #1411
Detailed Image
Detailed Image
Today's Daily special (April 23, 2013) is Meguiar's DA Microfiber Correction Compound.
Regular Price for 16 oz is $18.99. Today's price is $14.15!
Regular Price for 32 oz is $34.99. Today's price is $25.54!
Regular Price for 128 oz is $84.99. Today's price is $63.32!
  • Superior cutting power that finishes down smooth and glossy in one step!
  • Use with Meguiar's Microfiber Cutting Disc Buffing Pad and a Porter Cable 7424 XP for best results
  • Revolutionary new technology that will forever change detailing!
Old Apr 24, 2013 | 04:20 AM
  #1412
Detailed Image
Detailed Image
Today's Daily special (April 24, 2013) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.79!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old Apr 25, 2013 | 04:21 AM
  #1413
Detailed Image
Detailed Image
Today's Daily special (April 25, 2013) is CarPro Iron X Iron Remover ( IronX w/cherry scent ).
Regular Price for 500 ml is $19.99. Today's price is $15.20!
Regular Price for 1000 ml is $32.99. Today's price is $25.08!
Regular Price for 4 L is $99.99. Today's price is $85.00!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
Old Apr 26, 2013 | 04:07 AM
  #1414
Detailed Image
Detailed Image
Today's Daily special (April 26, 2013) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.91!
  • Outstanding leather care brush to deep clean leather!
  • Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
  • Soft and gentle leather brush that works great
Old Apr 29, 2013 | 03:07 AM
  #1415
Detailed Image
Detailed Image
Today's Daily special (April 29, 2013) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.56!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Old Apr 30, 2013 | 04:24 AM
  #1416
Detailed Image
Detailed Image
Today's Daily special (April 30, 2013) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old May 1, 2013 | 04:12 AM
  #1417
Detailed Image
Detailed Image
Today's Daily special (May 1, 2013) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6 inch is $11.99. Today's price is $8.75!
Regular Price for 5 inch is $9.99. Today's price is $7.09!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old May 2, 2013 | 04:08 AM
  #1418
Detailed Image
Detailed Image
Today's Daily special (May 2, 2013) is Dodo Juice Born to be Mild Shampoo.
Regular Price for 250 ml is $16.99. Today's price is $12.66!
  • One of the best shampoos we've tested in terms of lubricity and maximizing your coats of protection
  • Highly concentrated formula means only a little bit of product is needed to achieve great results
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old May 3, 2013 | 04:11 AM
  #1419
Detailed Image
Detailed Image
Today's Daily special (May 3, 2013) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.41!
  • Pocket size plastic scraper with one single edge razor blade
  • Quickly remove inspection stickers and registration stickers
  • Use for virtually any scraping, trimming, or cutting
  • Open or close with easy push button lock system
Old May 6, 2013 | 03:09 AM
  #1420
Detailed Image
Detailed Image
Today's Daily special (May 6, 2013) is Surbuf R Series MicroFingers Buffing Pads.
Regular Price for 2x 6.5" is $16.99. Today's price is $12.57!
Regular Price for 2x 5.5" is $13.99. Today's price is $10.21!
Regular Price for 2x 4" is $9.99. Today's price is $7.29!
  • Excellent polishing power with minimal haze left behind!
  • Read a professionals recommendations on how-to use Surbuf pads properly
  • Each box comes with 2 pads
  • The pads can be washed and re-used many times
  • Perfect match for Porter Cable users with Meguiar's M105
