NEW!!!! Daily Specials at Detailed Image
Old Feb 19, 2014 | 04:06 AM
  #1601
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (February 19, 2014) is Optimum Opti-Clay.
Regular Price for 4 oz Yellow is $14.99. Today's price is $11.09!
  • Remove embedded surface contamination quickly and easily!
  • Properly prep your paints surface for polishing, applying a glaze, wax, sealant and / or a coating
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • Comes with two individually packaged 2 ounce clay bars
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Feb 20, 2014 | 05:02 AM
  #1602
Detailed Image
Detailed Image
Today's Daily special (February 20, 2014) is Menzerna Power Finish PF 2500.
Regular Price for 16 oz is $29.99. Today's price is $21.89!
Regular Price for 32 oz is $44.99. Today's price is $31.94!
  • An incredible one step polish!
  • Finishes down very well creating a glossy appearance
  • Excellent polishing power to remove swirls, oxidation, etc.
  • A light to medium polish that can finish down like premium light polishes
Old Feb 21, 2014 | 04:05 AM
  #1603
Detailed Image
Detailed Image
Today's Daily special (February 21, 2014) is DI Accessories Terry Cloth White Stripe Applicator Pad.
Regular Price is $1.49. Today's price is $1.11!
  • Ideal for interior and exterior applications!
  • Durable and reusable applicator
Old Feb 24, 2014 | 04:10 AM
  #1604
Detailed Image
Detailed Image
Today's Daily special (February 24, 2014) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.86!
  • Our softest and plushest foam applicator pad that has two distinct sides to apply products with
  • Most commonly used for applying last step products (LSPs), such as sealants and waxes
Old Feb 25, 2014 | 04:09 AM
  #1605
Detailed Image
Detailed Image
Today's Daily special (February 25, 2014) is Lake Country Hydro Tech Crimson Ultra Fine Finishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.93!
Regular Price for 5.5 inch is $9.99. Today's price is $7.29!
Regular Price for 4 inch is $5.99. Today's price is $4.37!
Regular Price for 3 inch is $3.99. Today's price is $2.87!
  • Bring out the maximum depth and gloss of any polish
  • Use the Hydro Tech Crimson pads to apply finishing polishes, glazes or even sealants and waxes
  • Experience longer work time and less dusting with less product absorption
  • You can clean these pads with the Lake Country Snappy Clean Pad Cleaner
Old Feb 26, 2014 | 04:06 AM
  #1606
Detailed Image
Detailed Image
Today's Daily special (February 26, 2014) is DI Microfiber Grey on Gray Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.95!
  • Tight weave and low/medium nap for easy removal of polish, wax, sealants, etc
  • Can be used to clean and apply virtually any product
  • Use it on the vehicle's interior and around the home!
  • Soft fibers are safe and effective!
  • Can be washed hundreds of times, we recommend Micro-Restore Microfiber Detergent Concentrate
Old Feb 27, 2014 | 04:04 AM
  #1607
Detailed Image
Detailed Image
Today's Daily special (February 27, 2014) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.46!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Old Feb 28, 2014 | 04:20 AM
  #1608
Detailed Image
Detailed Image
Today's Daily special (February 28, 2014) is Lake Country Pink Very Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.09!
Regular Price for 5.5 inch is $7.99. Today's price is $5.67!
Regular Price for 4 inch is $4.99. Today's price is $3.54!
Regular Price for 3 inch is $3.99. Today's price is $2.91!
  • A very popular polishing pad designed to remove light surface imperfections
  • When you need a tad more power than a white polishing pad, the pink pad is your answer
  • Menzerna Power Finish PF 2500 (PO203) polish is one of the most popular products to use with this pad
  • We recommend caring for your pads with Lake Country Snappy Clean Pad Cleaner
  • Lake Country had two unique green pads, but replaced it's more aggressive one with this pink pad
Old Mar 3, 2014 | 03:30 AM
  #1609
Detailed Image
Detailed Image
Today's Daily special (March 3, 2014) is DI Brushes ATLASTA Soft Tip Brush.
Regular Price is $14.99. Today's price is $10.64!
  • Versatile brush can be used on your interior or exterior surfaces!
  • Packed with soft filament bristles that hold their shape
  • 9.75" long with a weight of 4.3 oz
  • Amazing brush for wheels!
Old Mar 4, 2014 | 04:32 AM
  #1610
Detailed Image
Detailed Image
Today's Daily special (March 4, 2014) is Lake Country Orange Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.44!
Regular Price for 5.5 inch is $7.99. Today's price is $5.91!
Regular Price for 4 inch is $4.99. Today's price is $3.59!
  • A light cutting pad designed to remove moderate swirls and scratches with a medium polish
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
  • Generally we recommend following up with a lighter pad and polish after
Old Mar 5, 2014 | 04:29 AM
  #1611
Detailed Image
Detailed Image
Today's Daily special (March 5, 2014) is CarPro Iron X Iron Remover Cherry Scent.
Regular Price for 500 ml is $19.99. Today's price is $14.79!
Regular Price for 1000 ml is $32.99. Today's price is $23.42!
Regular Price for 4 L is $99.99. Today's price is $72.99!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
  • Also available in Lemon Scent!
Old Mar 6, 2014 | 04:13 AM
  #1612
Detailed Image
Detailed Image
Today's Daily special (March 6, 2014) is DI Microfiber Mini-Towel.
Regular Price for 8" x 8" is $1.99. Today's price is $1.43!
  • Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
  • Perfect for keeping your sunglasses clean and free of fingerprints
Old Mar 7, 2014 | 04:28 AM
  #1613
Detailed Image
Detailed Image
Today's Daily special (March 7, 2014) is DI Accessories Sheepskin Wash Mitt without thumb.
Regular Price is $11.99. Today's price is $8.87!
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
Old Mar 10, 2014 | 03:48 AM
  #1614
Detailed Image
Detailed Image
Today's Daily special (March 10, 2014) is Chemical Guys Grime Reaper A.P.C..
Regular Price for 16 oz is $8.99. Today's price is $6.56!
Regular Price for 128 oz is $32.99. Today's price is $23.75!
  • One of our most powerful degreasers available, designed to easily cut through contamination
  • Powerful concentrated solution can be diluted down 8:1 with water and still maintain effectiveness
  • Perfect to degrease wheel wells, engine bays, door jambs, tires and much more
  • Dilute into a 22oz empty spray bottle or a handy 4oz pump spray bottle
Old Mar 11, 2014 | 04:07 AM
  #1615
Detailed Image
Detailed Image
Today's Daily special (March 11, 2014) is Lake Country Blue Fine Finishing Pad.
Regular Price for 5.5 inch is $7.99. Today's price is $5.83!
Regular Price for 4 inch is $4.99. Today's price is $3.64!
Regular Price for 3 inch is $3.99. Today's price is $2.97!
  • Our softest foam pad, the blue fine finishing pad, designed to apply ultra fine polishes, sealants and liquid waxes
  • Also commonly used to burnish the paint to a high gloss with a gloss enhancing polish
  • Blackfire Wet Diamond All Finish Paint Protection is one of the most popular sealants to apply with a blue pad
  • If you want to jewel or burnish the paint for some extra shine combine with the Menzerna Micro Polish SF 4500 (PO85RD)
Old Mar 12, 2014 | 04:20 AM
  #1616
Detailed Image
Detailed Image
Today's Daily special (March 12, 2014) is 3M Automotive Performance Masking Tape.
Regular Price for 18 mm is $3.99. Today's price is $2.97!
Regular Price for 36 mm is $5.99. Today's price is $4.68!
  • Properly protect paint, trim, emblems, lights, adjacent panels and more when using a buffer
  • Very high quality tape, perfect for auto detailing
  • Instantly sticks on surfaces and releases without any residue left behind
  • Ensures you don't get the dreaded white stain on your trim
Old Mar 13, 2014 | 04:13 AM
  #1617
Detailed Image
Detailed Image
Today's Daily special (March 13, 2014) is DI Brushes All Purpose Exterior Brush.
Regular Price is $4.99. Today's price is $3.72!
  • Use it to safely clean the exterior of your vehicle
  • Soft and safe to use on various surfaces
  • Flagged-tip bristles are resistant to acids and detergents for added longevity
Old Mar 14, 2014 | 04:33 AM
  #1618
Detailed Image
Detailed Image
Today's Daily special (March 14, 2014) is CarPro Spotless Water Spot & Mineral Remover.
Regular Price for 500 ml is $14.99. Today's price is $11.40!
  • Easily remove water spots and mineral deposits from your paint, chrome and glass
  • We recommend using a foam applicator pad along with some elbow grease for application
  • Is a great product to use with the CarPro Cquartz Ceramic Quartz Paint Protection, and other Coatings
Old Mar 17, 2014 | 03:25 AM
  #1619
Detailed Image
Detailed Image
Today's Daily special (March 17, 2014) is DI Accessories Detailed Image Garage Banner.
Regular Price for 2' x 5' is $24.99. Today's price is $20.72!
  • Hang indoors or out
  • Large size (2' x 5')
  • Printed on heavy duty Scrim Glossy Vinyl
  • Proudly display your love of Detailed Image!
  • Comes with grommets so it's very easy to hang
Old Mar 18, 2014 | 04:24 AM
  #1620
Detailed Image
Detailed Image
Today's Daily special (March 18, 2014) is Scotchgard Auto Fabric & Carpet Foaming Cleaner.
Regular Price for 17.5 oz is $6.99. Today's price is $5.17!
  • Deep clean and protect your carpets in one easy to use foam cleaner!
  • Penetrates into carpet and upholstery fibers, breaking up dirt and lifting out stains
  • Will restore that brand new look to your fabric, carpets, and floor mats
