NEW!!!! Daily Specials at Detailed Image
Old May 16, 2014 | 04:03 AM
  #1661
Detailed Image's Avatar
Detailed Image
Detailed Image
Today's Daily special (May 16, 2014) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old May 20, 2014 | 04:28 AM
  #1662
Detailed Image
Detailed Image
Today's Daily special (May 20, 2014) is DI Microfiber Detailing Apron.
Regular Price is $19.99. Today's price is $14.39!
  • Protect your paint from metal and plastic clothing pieces
  • Made of ultra soft microfiber that is paint safe
  • One size fits all design
  • Two large pockets for easy access of any tools, products, or microfiber towels you are using
  • 300 GSM
Old May 21, 2014 | 04:22 AM
  #1663
Detailed Image
Detailed Image
Today's Daily special (May 21, 2014) is DI Brushes Fender and Grill Brush.
Regular Price is $4.99. Today's price is $3.54!
  • Safely remove built up dirt and grime from your grill
  • Soft natural tampico bristles will not mar or scratch the surface
  • 8.5" durable foam block handle
Old May 22, 2014 | 04:18 AM
  #1664
Detailed Image
Detailed Image
Today's Daily special (May 22, 2014) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.75!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old May 23, 2014 | 03:59 AM
  #1665
Detailed Image
Detailed Image
Today's Daily special (May 23, 2014) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $34.99. Today's price is $25.19!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Old May 27, 2014 | 03:41 AM
  #1666
Detailed Image
Detailed Image
Today's Daily special (May 27, 2014) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.54!
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
  • 407 GSM
Old May 30, 2014 | 05:17 AM
  #1667
Detailed Image
Detailed Image
Today's Daily special (May 30, 2014) is Poorboy's World Wheel Sealant.
Regular Price for 8 oz is $19.99. Today's price is $14.79!
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Has an amazing watermelon scent that everyone loves!
  • The thinner the application the better, which allows you to get dozens and dozens of applications
  • Apply with a foam applicator pad or soft cloth and remove with a clean microfiber towel
  • Extremely easy to apply and remove, feels ultra slick upon completion
  • Prevents brake dust from etching in to the wheels finish
Old Jun 2, 2014 | 03:06 AM
  #1668
Detailed Image
Detailed Image
Today's Daily special (June 2, 2014) is DI Brushes Pet Hair Removal Brush.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
Old Jun 3, 2014 | 06:45 AM
  #1669
Detailed Image
Detailed Image
Today's Daily special (June 3, 2014) is DI Accessories Detailed Image Kneeling Pad.
Regular Price for 12" x 12" is $5.99. Today's price is $4.87!
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
Old Jun 4, 2014 | 04:15 AM
  #1670
Detailed Image
Detailed Image
Today's Daily special (June 4, 2014) is DI Brushes Carpet Brush for Buffers.
Regular Price is $14.99. Today's price is $10.94!
  • Great for deep cleaning carpets using the added power of a buffer!
  • Packed with 7/8" long semi-stiff polyproplylene bristles
  • 5" diameter and durable hook and loop backing
  • Works great with the Lake Country DA 5" Backing Plate or the Lake Country Rotary 5" Backing Plate
Old Jun 5, 2014 | 04:05 AM
  #1671
Detailed Image
Detailed Image
Today's Daily special (June 5, 2014) is DI Accessories Universal Replacement Flip Top Caps.
Regular Price is $0.75. Today's price is $0.54!
  • Universal top that fits the majority of 16oz, 32oz, 500ml and 1000ml bottles
  • Spout helps control how much you pour out
  • Helps conserve product and save you money
  • Keep a few around the garage in case you break a cap
Old Jun 6, 2014 | 06:21 AM
  #1672
Detailed Image
Detailed Image
Today's Daily special (June 6, 2014) is Chemical Guys Extreme EZ-Creme Glaze with Acrylic Shine II.
Regular Price for 16 oz is $16.99. Today's price is $12.40!
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
Old Jun 9, 2014 | 03:06 AM
  #1673
Detailed Image
Detailed Image
Today's Daily special (June 9, 2014) is Optimum Opti-Bond Tire Gel.
Regular Price for 32 oz is $15.99. Today's price is $11.67!
Regular Price for 128 oz is $35.99. Today's price is $26.63!
  • Gel based tires dressing that applies easily and does not sling onto your paint
  • Can be applied in multiple layers for a glossier look or buffed down to a matte finish
  • We recommend using a Lake Country tire dressing applicator to apply Tire Shine
Old Jun 10, 2014 | 04:07 AM
  #1674
Detailed Image
Detailed Image
Today's Daily special (June 10, 2014) is Chemical Guys GlossWorkz Shampoo.
Regular Price for 16 oz is $12.99. Today's price is $9.61!
Regular Price for 128 oz is $42.99. Today's price is $32.97!
  • Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
  • Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
  • Use 1 oz per 4 to 5 gallons of water
Old Jun 11, 2014 | 04:28 AM
  #1675
Detailed Image
Detailed Image
Today's Daily special (June 11, 2014) is CarPro Iron X Iron Remover Cherry Scent.
Regular Price for 500 ml is $19.99. Today's price is $14.89!
Regular Price for 1000 ml is $32.99. Today's price is $24.58!
Regular Price for 4 L is $99.99. Today's price is $72.99!
  • This is the MUST have product for ALL detailers!
  • Remarkably quick and effective cleaner for the exterior paint and wheels
  • Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
  • pH balanced and gentle formula safe to use over virtually the entire exterior
  • Turns a deep and dark red color as it dissolves particles stuck to the surface
  • Cherry scented with improved formula!
  • Also available in Lemon Scent!
Old Jun 12, 2014 | 04:36 AM
  #1676
Detailed Image
Detailed Image
Today's Daily special (June 12, 2014) is DI Brushes Wheel Wash Boar's Hair Brush.
Regular Price is $33.99. Today's price is $25.15!
  • Clean your wheel safely and easily!
  • Breaks up road grime and brake dust with ease
  • 50% more boar's hair bristles than many similar brushes
  • Safe on clear coated, anodized, polished, aluminum, painted, powder coated and chrome wheels
Old Jun 13, 2014 | 04:25 AM
  #1677
Detailed Image
Detailed Image
Today's Daily special (June 13, 2014) is Chemical Guys Diablo Gel Rim and Wheel Cleaner.
  • pH balanced wheel cleaner safe on ALL wheel finishes and competes amongst the best wheel cleaners available
  • Powerful concentrated suspension allows for dilution of product without the loss of cleaning power, making it a great value
  • Perfect for high end professional detailers who detail expensive wheels
Old Jun 16, 2014 | 03:03 AM
  #1678
Detailed Image
Detailed Image
Today's Daily special (June 16, 2014) is Sonax Polymer Net Shield.
Regular Price for 210 ml is $27.99. Today's price is $19.87!
  • Aerosol based spray on sealant
  • Can be applied easily in minutes
  • Protects up to 6 months
  • Adds gloss and depth to your paint
Old Jun 17, 2014 | 04:25 AM
  #1679
Detailed Image
Detailed Image
Today's Daily special (June 17, 2014) is DI Accessories Razor Blade Holder with Soft Grip.
Regular Price is $2.99. Today's price is $2.15!
  • Perfect way to hold your plastic or metal razor blades
  • Easy way to remove stickers from paint, glass, license plates, etc.
  • All standard razor blades will fit this holder
  • Made in the USA
Old Jun 18, 2014 | 04:00 AM
  #1680
Detailed Image
Detailed Image
Today's Daily special (June 18, 2014) is Chemical Guys Signature Series Orange Degreaser.
Regular Price for 16 oz is $8.99. Today's price is $6.70!
  • A versatile degreaser that you can use all over your vehicle
  • Professional strength, super concentrated, citrus-based formula
  • Removes tough grease, grime, dirt and debris with ease
  • Works great on paint, engine bay, tires, rims, undercarriages etc.
  • Amazing value, you can dilute in Trigger Spray Bottle
