tar removal
Old Nov 14, 2003 | 10:05 AM
Wil350lieZ's Avatar
Wil350lieZ
Question tar removal
Need help I have tar onnthe hood, so what the best product to remove without paint damage?
Old Nov 14, 2003 | 11:13 AM
aprez99's Avatar
aprez99
I can tell you what I have used to take it off, but I can't tell you if it will hurt your clearcoat/paint. I used to work at a car wash and we used mineral spirits. Hold a rag over the can and soak it a little bit. Start wiping it. The tar will start to soften then streak a little bit. After a couple wipes it will come completely off. I am pretty sure that if you hose down the area with water for a couple minutes where you just used mineral spirits, it shouldn't harm your car. Just to cover my ***, I WOULD personally do this. But I am in no way taking liability for your car if it harms it. Sorry, just had to add that.
Old Nov 14, 2003 | 06:01 PM
eddytsi's Avatar
eddytsi
awhile back, I forgot the namebrand, but it was in a blueish gel bottle. that worked great. go to your local pepboys/ autozone car store and ask the guys what they would recommend. good luck!
Old Nov 15, 2003 | 05:34 AM
Lee3Z's Avatar
Lee3Z
WD-40 works at removing tar without hurting paint or clearcoat. It softens the tar so you can just wipe it off with a soft white cloth.
Old Nov 15, 2003 | 09:19 AM
s9am_me's Avatar
s9am_me
bug and tar removers for cars at any auto store or target or walmart. runs for about $4-5. works really good. My friend took a road trip from SF to LA and back. Once he got home... he sprayed it.. let it sit for a while.. and wiped it off. well he had to do 2 apps cuz his hood and bumper was a mess. works well and didn't harm the paint of course
Old Nov 16, 2003 | 11:16 AM
Kevin Overall's Avatar
Kevin Overall
The best tar remover I have ever used is Stoner's Tarminator, its a thin liquid and softens and removes without seeming to dull or effect the wax or polish coating, based on using it on a Zainoed finish that is.
I would not use the tar remover compounds that look like polishing or rubbing compounds, they strip wax pretty easily and dull the surface requiring re-polishing and re-waxing to make the repaired spot match the rest of the surface.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
