Drag NHRA, IDRC, IHRA, NDRA
NEW Time 12.583 @ 116.56
Old Oct 22, 2006 | 12:06 AM
ipcheck's Avatar
ipcheck
Default NEW Time 12.583 @ 116.56
I spun 1st and much of 2nd.
Attached Thumbnails NEW Time 12.583 @ 116.56-picture-010.jpg   NEW Time 12.583 @ 116.56-picture-012.jpg   NEW Time 12.583 @ 116.56-picture-013.jpg   NEW Time 12.583 @ 116.56-picture-014.jpg   NEW Time 12.583 @ 116.56-picture-015.jpg
Old Oct 22, 2006 | 01:29 AM
ct350z's Avatar
ct350z
Glad You Did Good Homie, To Bad I Didnt Have The Same Luck...time For New Wheels, Something Beefier!!!!
Old Oct 22, 2006 | 01:34 AM
Dubai's Avatar
Dubai
Nice.
was it on street tires?
Old Oct 22, 2006 | 07:01 AM
ipcheck's Avatar
ipcheck
Originally Posted by Dubai
Nice.
Street Tires, 285/35/19" BF_Goodridge Comp TA KDW
Old Oct 22, 2006 | 09:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
And Jeremy says FL tracks are slow-look at that trap! Excellent for a ST...
Old Oct 22, 2006 | 02:34 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i noticed NX in your sig, did you use that at all?? just wondering. nice trap speed though
Old Oct 22, 2006 | 03:09 PM
ct350z's Avatar
ct350z
no he's not on nitrous!!! i wish i was..lol
Old Oct 22, 2006 | 03:42 PM
Thumbs up
You done good.
Old Oct 22, 2006 | 03:59 PM
JonsilvZ's Avatar
JonsilvZ
With better traction you should be in the low 12s. Even with the 3.3 gearing its still hard to put the power down.
Old Oct 22, 2006 | 04:21 PM
supra crazy's Avatar
supra crazy
Didnt you have Slick last time what happen?
Old Oct 22, 2006 | 05:13 PM
atar350's Avatar
atar350
Are those tires the semi slicks? My 285's couldnt hold 1st and 2nd if I didnt roll off the line and granny second.
Old Oct 23, 2006 | 07:33 AM
ipcheck's Avatar
ipcheck
I'm sponsored by NX, I have the kit, but not connected or used at all, it would easily blow (engine), I will soon connect an intercooler chill bar and use it for that...
Old Oct 23, 2006 | 07:35 AM
ipcheck's Avatar
ipcheck
Its weird, I pulled a 12.26 @ 118 before a couple of mods and on street tires as well, I've pulled several 117 traps.. I'm thinking its my tires and driving combined.
Old Oct 23, 2006 | 07:36 AM
ipcheck's Avatar
ipcheck
Tires are full street radials, not even Drags.
Old Oct 23, 2006 | 07:37 AM
ipcheck's Avatar
ipcheck
I went to the track with my buddys ET streets, but the problem on the Z, you canot use the brakes for a burnout, and I couldnt heat up the tires, so it looked like a crazy fish down the track, and felt as if I was gonna eat the wall, ****ty times, also, my best times have been on street tires.
Next trip to the track will be with 18" Drag radials. We'll see....
Old Oct 23, 2006 | 07:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Pull the brake fuse and do a nice 2nd gear burnout...that enables you to warm them up "enough".
ipcheck's Avatar
ipcheck
Not semi slicks, full street tires, with the different gears out back, its a lot better off the whole, it spins a bit on 1st and a bit on 2nd, but it stays much on the ground. I improved my 60ft from 2.3 to 2.0 on street tires just with the gear change, also I pass the trap on 4th gear, b4 I used to have to shift into 5th
Old Oct 23, 2006 | 07:40 AM
ipcheck's Avatar
ipcheck
You mean the brake light fuse located under the driver side correct?
I will try that next time when I roll up with the DR...s
Old Oct 23, 2006 | 07:53 AM
ct350z's Avatar
ct350z
IM NOT GOING OUT THERE AGAIN WITH OUT SOME DRAG RADIALS OR SLICKS HOMIE!!!
Old Oct 23, 2006 | 03:01 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes the brake fuse located in the drivers side kick panel...
