Drag NHRA, IDRC, IHRA, NDRA
What is your best 60ft on street tires, not dr's.
Old May 14, 2007 | 02:41 PM
  #41
Nealoc187's Avatar
Nealoc187
Originally Posted by S8ER95Z
wtf??? great 60ft but the rest of the numbers are garbage. What happened?
What happened is that the 60' timing lights were tripped by something accidentally. That 60' isn't possible in this instance.
Old May 14, 2007 | 04:02 PM
  #42
Alberto's Avatar
Alberto
Cranky FI Owner
+3 BS. 60ft doesnt add up for that weaksauce et or trap in the 1/8 let alone the 1/4...
Old May 14, 2007 | 06:37 PM
  #43
cj350's Avatar
cj350
Originally Posted by BriGuyMax
Those numbers don't add up...obviously the 60ft light was tripped early by something because that kind of 60ft with a 74mph 1/8 trap will run you much quicker than 9.3 in the 1/8.
Show us a 1.5 or even a low 1.6 to back that up and I MIGHT start to believe that it was actually possible. (which I already know it's not.)
lol this is crazy..... ok you guys win coz i really don't have the time to prove stuff to you guys (just got better things to do and also i sold the car but maybe you guys can buy me an sti an i can do it again for you if it means a lot)..... lol i did miss gears in that run (now plz don't investigate which gears i missed and other stuff)
Old May 14, 2007 | 08:07 PM
  #44
Nealoc187's Avatar
Nealoc187
So apparently you don't have another timeslip showing even a 1.5 or low 1.6? Let me guess, all your other timeslips from that day are high 1.6s (if you're lucky) or more likely 1.7s and 1.8s, maybe even 1.9s? But you've got that magical 1.4... lol I love it.
Old May 14, 2007 | 08:19 PM
  #45
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
So you're telling me that's the ONLY pass that you ever made in the car?? Show us another timeslip from that day with a 60' within even a tenth and a half of that 1.48.
I don't think you understand what goes into pulling a sub 1.5 60' time. Hell...my Z on a slick launching from 6000rpms has only pulled a best of 1.62 and that took full traction and 430rwhp.
Old May 14, 2007 | 09:33 PM
  #46
bacalhau16's Avatar
bacalhau16
I wouldnt mind seeing another slip if you got one. I will take it back if you can show me more then that.
That slip just doesnt add up at all. A 1.4 60', but then a 6.0 330'? I guess when you said you miss-shifted you werent kidding. Thats one hell of a miss-shift.
Old May 15, 2007 | 07:38 AM
  #47
hurricane62's Avatar
hurricane62
You guys said 60' with street tires, so I had a 2.109 on Potenzas. I was pretty pleased with that, being noob at drag racing.
Old May 15, 2007 | 08:40 AM
  #48
Nealoc187's Avatar
Nealoc187
That's pretty decent for a virgin drag racer, nice job.
Old May 15, 2007 | 09:41 AM
  #49
S8ER95Z's Avatar
S8ER95Z
DOH... wasn't really thinking about a red light situation here or something flipping acrossed the sensor. Makes sense now.
Old May 15, 2007 | 02:03 PM
  #50
04treefiddy's Avatar
04treefiddy
i've been playing at the strip for over 7 years now. The z has seen more than 100 passes at the strip easy. Just takes practice.
Old May 17, 2007 | 09:26 PM
  #51
boostintt's Avatar
boostintt
here you go
BriGuyMax & bacalhau16 jk
wow.. nice 60'
Old May 30, 2007 | 09:14 AM
  #52
DouBLeJ16's Avatar
DouBLeJ16
They probably started with the rear tires located where the front tires should be. (pretty much like a car length jump) Resulting in some crazy 60' time.
The kids do it all the time at the local 1/8th mile track.
However, there are STI's and EVO's there that run 1.6 60' times 100% stock down to the tires. That is with a pretty much perfect launch.
Old May 30, 2007 | 08:35 PM
  #53
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
probably...huge difference between a 1.6 and a 1.4 though....
Old May 31, 2007 | 01:57 PM
  #54
bacalhau16's Avatar
bacalhau16
If the rear tires were at the line, not the front tires, then this would make sense.
If you do it out mathmatically, it almost works perfectly.
A 2.0sec 60', means you covered an avg of 30' per sec.
So, with about 7' less, assuming the rear tires are on the line, it would only take you about 1.43 sec to hit the 60' line on the track. Then this would make sense. So in this case I would tell you CJ, that it seems like you really got just over a 2.0 sec 60'. Good job!!
Old May 31, 2007 | 02:04 PM
  #55
04treefiddy
new best on streets 1.83 60ft
Old May 31, 2007 | 08:43 PM
  #56
bacalhau16's Avatar
bacalhau16
Damn, thats just impressive. Your car really hooks!
Old Jun 4, 2007 | 10:51 AM
  #57
craigo'sznprgrs's Avatar
craigo'sznprgrs
I can hardly break 2.2 on the sixty foot mark, lol. I have hit 2.1 a couple of times. I don't have a good track up here though, I ran a 8.3 at 88, had to let off I was spinning hard then the next run, I feathered it and ran 8.5 and had to let off in 3rd but had a trap of 90.0 mph. I would love to see what my car would run without any type of traction issues.
I would be in the 7's in the 1/8th with some of your 60' times, I am kind of jealous.
Old Jun 4, 2007 | 11:30 AM
  #58
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Buy a set of DRs....
Old Jun 4, 2007 | 04:27 PM
  #59
craigo'sznprgrs
I need too!! I accept donations as they are apparently becoming more and more popular here
Old Jun 4, 2007 | 04:42 PM
  #60
bacalhau16's Avatar
bacalhau16
Really, I havent seen much of that over here.
