Drag NHRA, IDRC, IHRA, NDRA
my '07 Base Z w/hks exhaust track video
Old Jun 29, 2007 | 07:47 AM
faithmassive's Avatar
faithmassive
Default my '07 Base Z w/hks exhaust track video
http://www.youtube.com/watch?v=ks183JBR-1M
+90 degress and humid
tires ... 22psi
60' ... 2.321
330 ... 6.120
1/8 ... 9.176
MPH ... 80.61
1000... 11.787
1/4 ... 13.979
MPH ... 102.66
I'm not sure if the humidity has anything to do with this (moisture on the track) but I can't seem to get my 60' down below 2.228 which is my best so far... it's rediculous. I'm a decent driver and on the street I can feather the clutch and launch very well at 3500rpm.. but at moroso in wpb, fl I can't even feather at 2000rpm. The tires just spin off the line.. maybe I'm too excited.. I dropped my tires to 22psi but I just can't connect at the track. I need to try a different one because people call this one "moroslow" any suggestions?
Old Jun 29, 2007 | 09:30 AM
ACEMAN's Avatar
ACEMAN
Master
The track seems like it is in a good location ( 23Ft Above Sea Level ). Looks like in your case it depends on track prep. Throw some drag radials on there
I was going to say use 22 psi and launch around 2500-3000rpm feathing out of the hole. But it looks like you are already doing that. Are you always using the same lane? Maybe one side might be better preped than the other??
Just some thoughts
Later
Todd
Old Jun 29, 2007 | 09:33 AM
bacalhau16's Avatar
bacalhau16
Still a pretty fast car though. Most Z owners would be happy with a 13.9. Pretty identical to my PB right now. I have the same problem with poor track prep. Hopefully it will be better next time out.
Old Jun 29, 2007 | 09:35 AM
S8ER95Z's Avatar
S8ER95Z
temp and humity have to do with DA... sounds like the overall DA was high... the track I race at is only 640ft above sea level but at times the air here is equivelant of 5000+ft above... bad air = bad times.
Old Jun 29, 2007 | 09:36 AM
350z2go's Avatar
350z2go
nice time man
Old Jun 29, 2007 | 09:45 AM
faithmassive
Just some thoughts
Later
Todd
I think with a great launch I can pull mid 13's easier. Because I see people hitting 13.4 in the '07 stock and I'm kicking myself every time I see anything 14 I might be letting the clutch out faster then I think I am cause I'm excited.. not sure, thanks for the comments though!
Old Jun 29, 2007 | 09:48 AM
ACEMAN's Avatar
ACEMAN
Master
Here you go
Plug in the numbers for that day at the track and see what % of HP your car is putting out. Im sure its not 100%
http://wahiduddin.net/calc/calc_hp_dp.htm
You can grab the the temp info here. Pick a Airport that is close to the track to give you a round about idea.
http://weather.noaa.gov/
Let me know what you find out.
Later
Todd
faithmassive
if you look in the right lane of the video, there is this s2000 w/exhaust, intake, vtech controller and test pipes. He's a decent driver and he wasn't running any faster then me. It was a nice looking car
Old Jun 29, 2007 | 09:51 AM
SargentZ's Avatar
SargentZ
maybe rolling the windows up would help. less drag. Can't wait to get mine to the track. I will definitely be pulling the spare and any non essential weight prior though.
Old Jun 29, 2007 | 09:52 AM
ACEMAN's Avatar
ACEMAN
Master
If i plug in the numbers for my track with the condition here right now here is what i come up with
Air Temp 71
Altimeter 30.05
Dew point 64
Altitude of track 535ft
Relative Horsepower -- 99.2%
So this tells me that my car is not running at its full potential.
Hope this helps
Later
Todd
Old Jun 29, 2007 | 09:58 AM
faithmassive
Air Temp 71
Altimeter 30.05
Dew point 64
Hope this helps
Later
Todd
I ran on wednesday which was hotter then yesterday night but I can only get the last 24 hours, so I put in the numbers for yesterday and got.
air temp: 86
altimeter: 30.02
dewpoint: 75
altitude: 23
relative horsepower: 98.6%
Old Jun 29, 2007 | 09:59 AM
faithmassive
they were up I believe, they make us run with them up. Oh, I had my 2 amps in the car with the amp rack.. I take the subs out though
Old Jun 29, 2007 | 10:04 AM
FastZ33's Avatar
FastZ33
tires ... 22psi
60' ... 2.321
330 ... 6.120
1/8 ... 9.176
MPH ... 80.61
1000... 11.787
1/4 ... 13.979
MPH ... 102.66
thats not so bad, my friend hit a 13.7 on a stock 07 ent.
Old Jun 29, 2007 | 10:07 AM
FastZ33's Avatar
FastZ33
another problem is t hat u dont have a lsd. if u get one ur 60 will drop a lot, try and swap out and lsd, also take out as much weight as u can to help u with the long run
Old Jun 29, 2007 | 10:09 AM
coachk's Avatar
coachk
Not bad for Moroslow...get your Z ready for the private track rental thats coming up in October at Bradenton..Bradenton will have a very well prepped track so you can probably better your 60' time.
Old Jun 29, 2007 | 10:12 AM
ACEMAN's Avatar
ACEMAN
Master
air temp: 86
altimeter: 30.02
dewpoint: 75
altitude: 23
What do you think your car puts down to the wheels?
If its 265hp then with the relative horspower of 98.6 your putting around 261hp. Thats not that big of a difference. But change the 23ft altitude to 535ft once Comes to 96.4%. With that, you would be losing about 10HP
All those numbers effect your 1/4 mile times. I like to check things before i go out just to see.
Later
Todd
Old Jun 29, 2007 | 10:14 AM
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Every tenth you drop off of this ( 60' ... 2.321 ) should give you 2 tenths in the 1/4.
Good luck and work on that launch
Later
Todd
faithmassive
ahh.. maybe it's the lsd.. I forgot about that.
edit: but veetec has a base
Old Jun 29, 2007 | 10:15 AM
faithmassive
Later
Todd
thanks for the feedback, I'll talk to you later
Old Jun 29, 2007 | 10:17 AM
coachk's Avatar
coachk
Default my 07 Base Z
Nice in car vid...looks like you shift ok (you must have been watching Albertos vid of him shifting..lol). If you can make it thru the trap without shifting to 5th gear that will help. It looked like you were shifting into 5th right at the end. Next time try to stay in 4th thru the trap just don't bang it off the rev limiter.
