Took my AT 07 out today>>>>
First time taking it out to the track (drag strip) since I bought it.
Didn't do too bad, the only trouble with the AT at this power level is the ability to leave hard off the line with drag radials. The stall on the converter is too low and the stock gearing isn't helping things either.
Mods so far are Fast Intentions resonated test pipes, prototype (under testing) JWT cams. and our Specialty-Z valve body upgrade.
Run was performed with MT ET Street Radials.
Next time out I plan to have gears or raise the stall on the converter to get the 60s in the 1.xxs
Originally Posted by zman1910
Man that would've been a great time for an auto with stock tires. Not bad either way though. I was expecting somewhere around 13.3 or lower for an auto set up with MT's....
Anyways, to utilize the setup better the stall needs to be moved up to really benefit with the DRs. Gears will be next and stall change if needed.
Impressive. Post your times here: https://my350z.com/forum/drag/233840-top-25-1-4-mile-times-for-tt-st-supercharger-nitrous-bolt-ons-stock.html
Originally Posted by davidv
Impressive. Post your times here: https://my350z.com/forum/showthread.php?t=233840
Originally Posted by marques1
yeah i would say the stall and the gears are hurting you to that would be a great next upgrade.
Nice times.. Maybe you should try torque braking? My brothers automatic 07 left a good 20 feet of rubber before letting off at 6xxx rpms while brake torqeing..no traction, but with tires for the strip you might want to try this technique. the HR motor rips those potenzas up. hold the brakes rev to 1500rpms and GO! Im curious about those JWT cams.. they don't even have a friggen intake yet but they are prototyping cams? How are they and what are the gains like so far in your opinion if you don't mind me asking?
Originally Posted by bacalhau16
Nice times. But with test pipes and cams, I wouldve expected a higher trap speed in a 07.
Do you have the track conditions or DA?
Track conditions from what I can remember, 1800' elevation (calculated w/ pressures mixed in), temp was about 88 degrees. Alot of the other guys (Viper guys) were complaining that there cars were running lower MPHs that day, and conditions weren't optimal.
Originally Posted by Seb-Specialty-Z
Well, the trouble is that the AT soaks up more power over a MT.
Congrats
Todd
Originally Posted by eagletanggreen
Cali speed way is not 1800 feet....Right?
I grew up in riverside,it doesnt seem like 1800ft, but who knows.
A quick lookup on Google says its 1237 feet.
Originally Posted by aceman
That and the fact your gears are taller ( 3.357 Gear ) in the Auto. The elevation does not help your times either. I think you did really well considering those two factors.
Congrats
Todd
Congrats
Todd
