Drag NHRA, IDRC, IHRA, NDRA
going to firebird tonight...
Old Oct 26, 2007 | 12:29 PM
steppinrazor's Avatar
steppinrazor
Default going to firebird tonight...
and i have a few questions. first, the last time i went to race(that was the first time, i had just gotten my car a few weeks before that and its my first m/t) one of the kids with a z i was talkin too said something about it being better to have only a small amount of gas in the tank when racing, is that true?? i got to thinking about it and was he just talking the extra weight? or was he just pullin somethin out his ***.. if it was the weight he was talking about, im aure thats not going to matter much..
this is my first time going knowing my car really well, my first time was horrible.. any small tips would be apreciated
Old Oct 26, 2007 | 01:22 PM
Frostydc4's Avatar
Frostydc4
You know gas is denser than water right?
Where is Firebird BTW and what time do they open & close? Do they have helmets to rent (I cant find my old one ). I have not been to the dragstrip in over a year and I have been itching to go.
Old Oct 26, 2007 | 02:11 PM
I race Summit ET, and always run with 1/4 tank of gas. Not sure if it helps ET, but it helps be consistent throughout the racing season.
Old Oct 26, 2007 | 02:19 PM
azsupra's Avatar
azsupra
It's in Chandler right off of the I-10 just south of Pecos Rd.
Old Oct 26, 2007 | 03:25 PM
Frostydc4's Avatar
Frostydc4
When do they open on fri?
Old Oct 26, 2007 | 04:15 PM
steppinrazor
they open at 6 and am not sure when they close
there adress is, id give you directions but im not sure where your comin from, try it on mapquest tho..
20,000 Maricopa Rd.
Chandler, AZ 85226
Ph: 602.268.0200
and im not sure if they rent out helmets, you only need it if you plan on hittin 13.00'S ... i dont belive i will be doing that yet so i dont really need to worry bout it
Old Oct 27, 2007 | 12:43 AM
SergEK's Avatar
SergEK
20,000 Maricopa Rd.
Chandler, AZ 85226
Ph: 602.268.0200
Normally most tracks have you wear a helmet at 13.99 or better
And I believe gas weighs like 4 or 5 lbs a gallon??? so a full 20 gallon tank is like 100lbs vs 25lbs for a quarter tank......75lbs is no joke, drop your spare, passenger seat and your quite a bit lighter than when you rolled in.....its not like 500lbs or anything but every pound helps
The density of gasoline (petrol) is about 737.22 kg/m3
1 GALLON of gasoline weighs 6.152 lbs. (for reference, 1 gallon of water weighs 8.34 lbs).
30.76lbs for a 1/4 tank 5 gallons
123.04lbs for a full tank!!!!
So doing a little research we find the difference between a 1/4 tank and a full tank is actually about 92lbs!!!
Easiest way to shave weight, and free!
Trunk mat 5lbs
Floor mats 10lbs
Passenger seat 50lbs
Spare + tools 40lbs
1/4 tank of gas instead of full - 90lbs
195lbs lighter than before
Figure thats 1.5-2 tenths in theory ....
Old Oct 27, 2007 | 11:19 AM
Skorch's Avatar
Skorch
Trunk mat 5lbs
Floor mats 10lbs
Spare + tools 40lbs
Thank you for posting this... I know a 1/4 tank weighs alot less than a full tank, but I never actually took the time to do the math.
Old Nov 2, 2007 | 09:34 AM
Frostydc4's Avatar
Frostydc4
I'm going to be going to firebird today. Are there any gas stations nearby that carry higher octane (prefably 93+) gas? I'd like to advance my timing for today's runs. Thanks.
Old Nov 3, 2007 | 02:33 AM
I dont see any time slips.
Old Nov 4, 2007 | 11:19 AM
steppinrazor
r/t-.656
60'-.2.640
330-6.898
1/8-10.289, mph-75.06
1000-13.159
1/4-15.58, mph 93.56
no need to make fun of me i think i punished myself enough, haha.. but fu ck it, this is my first manual car, that slip was from within my first 2 weeks of getting the car, im a whole lot better driver now
Old Nov 4, 2007 | 04:11 PM
r/t-.656
60'-.2.640
330-6.898
1000-13.159
You did good. 100 percent better than the dyno queens who have never seen a dragstrip. What rates in my book is that your are out there giving it your best. 10 points for effort.
Old Nov 4, 2007 | 09:35 PM
steppinrazor
thanks alot man, ill be goin a hell of alot so im sure itll get better
Old Nov 5, 2007 | 08:01 AM
S8ER95Z's Avatar
S8ER95Z
x2... I've always been pretty lucky..first pass ever at a strip matched the expected results of a stock LT1 auto like I had.. but other people don't beat on their cars or 'race' as much as I did back in the day so I was pretty comfortable. It also helped that I sat and watched numerous passes before I went down myself so I wasn't as nervious and kind of knew what to do when I got to the line. It's pretty intimidating!!!
Rampage
Sep 29, 2005 05:25 PM
phoenixZ33
Jun 23, 2004 12:16 PM
