Drag NHRA, IDRC, IHRA, NDRA
Finally hit 12's!!
Old Nov 25, 2007 | 10:33 AM
__jb's Avatar
__jb
Z + Rear Seat
Very impressive, Gooey! Congratulations!
My 4.08's should be done tomorrow... Looking forward to picking it up...
Old Nov 25, 2007 | 11:00 AM
bacalhau16's Avatar
bacalhau16
Thats awesome. 12's with a N/A Z! I gotta go drive an 07.
You gonna be able to get more runs in soon, or is the season almost done?
Old Nov 25, 2007 | 11:14 AM
taurran's Avatar
taurran
Nice!
Old Nov 25, 2007 | 12:18 PM
phat04350z's Avatar
phat04350z
Originally Posted by Gooey
well ill just post a breakdown of the slip. Local member has the other copy and will have it scanned for me tonite.
Mods: AEM Dual Intakes, Fast Intentions Intimidator Exhaust + FI resonated Test Pipes, 4.083 final drive, BFGoodrich Drag Radials 275/55/16 - 26" diameter
1/4 tank of gas, spare and tools in rear, 200lbs asian driver , and the best stock clutch you can ask for
photography by: DavidV
A little new here but dual intake? I thought we have a single? New motor has dual?
Old Nov 25, 2007 | 12:41 PM
meaj82's Avatar
meaj82
Yep the 07 up Z's have dual intakes.
Old Nov 25, 2007 | 12:43 PM
phat04350z's Avatar
phat04350z
thanks!
Old Nov 25, 2007 | 01:52 PM
VitViper's Avatar
VitViper
Originally Posted by Peak350
You'd expect a lower trap on radials right?
Correct.
Old Nov 25, 2007 | 02:16 PM
xDIEGOx's Avatar
xDIEGOx
Originally Posted by VitViper
Correct.
Why?
<-----n00b
Old Nov 25, 2007 | 02:30 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Correct.
Incorrect, I've ALWAYS trapped the same or even higher on sticky tires vs. street tires. I know some people believe that you trap higher with a worse 60' but that simply isn't true. Full traction is the most efficient way you can run down the 1/4 mile period.
Old Nov 25, 2007 | 03:08 PM
Gooey's Avatar
Gooey
oh I guess Im wrong but the track season is 50/50 here. It all depends when the first snow comes but they are scheduled to close sometime in december so I think I have 1 or 2 more weeks left.
Old Nov 25, 2007 | 03:13 PM
Peak350's Avatar
Peak350
I always heard the same - my friends mustang lot a MPH going to slicks - out of the hole faster = less distance to gain speed, at least thats how I always understood it.
Old Nov 25, 2007 | 03:19 PM
BornSlippyZ's Avatar
BornSlippyZ
Sweet! Nice run.
I noticed a difference when I test drove an 07 and this is the proof.
Old Nov 25, 2007 | 03:20 PM
Gooey's Avatar
Gooey
unless you have a car like bri had.....that thing just hauled a$$ so no matter what tires youll pull insane times and trap speeds
Im still stoked about my 12second pass. Even though I wish I tracked it more when it was stock but the 2nd day I gotmy car I modded it so why not go all the way. I hope to reach my goals of mid 12's by next season. Good luck to the other 07's to hit 12's. I know you guys will do it eventually.
Old Nov 25, 2007 | 03:54 PM
skaterbasist's Avatar
skaterbasist
Originally Posted by myladyz33
with radials and those mods shouldnt it do a lot better? that 1 guy on the boards trapped 107 stock and the 07 is much more mod friendly
You have your hopes too high. 107 trap on a stock 07's will rarely ever happen, unless you happen to have one of the best 1/4 mile drag strips in the U.S with very ideal conditions, + excellent driver [VeeTec]. You have to have all of those combined in order to get low 13's, 105+ trap.
FYI: 07 Z's trap <= 103 mph in SoCal at best.
Old Nov 25, 2007 | 03:55 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Wrong..that's due to bias ply tires vs. radial tires.
Your theory doesn't make any sense. If you get out of the hole faster then you are going faster at 60ft and thus you already have more MPH then if you came out of the hole slower and the same distance to pick up more speed. So by that theory you should always trap HIGHER with stickier tires.
Old Nov 25, 2007 | 04:04 PM
bboypuertoroc's Avatar
bboypuertoroc
Good job.
Old Nov 25, 2007 | 04:33 PM
VitViper's Avatar
VitViper
Guess it depends. I've seen it go both ways. *shrug*
Old Nov 25, 2007 | 04:51 PM
  #38
bboypuertoroc
^ My experience... the less sticky the tires, the higher trap you're gonna get. The stickier the tires, the better launch/60' you'll get.
Old Nov 25, 2007 | 05:41 PM
  #39
rkemp1's Avatar
rkemp1
Conditions are IMO more important. I dont think I am that good of a driver but I trapped 107 at the same track as Gooey yesterday. Just ideal conditions. By the way with that 107 trap it was a very bad 2.3 60ft
Old Nov 25, 2007 | 05:42 PM
  #40
Peak350's Avatar
Peak350
He had the same results with drag radials, just went to slicks to see if it made a difference.
With stock tires he trapped ~102, with DR's/slicks (same tire height) he trapped ~99.
His ET however was a tenth quicker, with a .25 drop in his 60'.
I don't know how to justify it, really I try but it doesn't make sense. My experience has backed it up though (faster ET's came with relatively lower traps).
I think it depends on the car and conditions, but in general a better launch nets a lower trap from everything I've seen. I'm not the only person thinking that - I've read both stated as fact, I'm saying I'm not sure, please don't state a fact you aren't sure about...
