TampaRacing TrackDay Sat, Feb. 9th
Originally Posted by denchan350gt
GL on your goals tomorrow take plenty of video!!
Coach what rpm do you launch at? I know that you have raised stall on your TC.
What were your times before the upgraded TC and VB and what rpm did you launch at?
I'm just trying to compare before and after I'm thinking of raising the stall on my TC.
I launch at 3200-3300
I never raced my Z prior to the TC and VB...I do know that the stock TC is set between 2650-2900 per Nissan specs.
Originally Posted by jksstar
so who hit 10s today?
It was cancelled due to rain....it would of been a great day of racing because there were some pretty bad *** cars there.
I am going to try and go tomorrow since the weather is supposed to be perfect.
Here's Some of the Crew standing around Tom's Z before it started pouring down rain...I had a fun time, too... Shooting the breeze about racing is almost as much fun as racing...
Well the end has come to my stock internals motor. I made 2 passes down the track without the nitrous and the car was running strong. My third pass I hit the N20 button (75shot) and I bent a couple rods. Its a very loud lowpitched clunking noise.I checked the motor and theres no oil leaking anywhere, so I'm pretty sure nothing went thru the block.
The 75 shot put me at 500whp so for my motor that was toooooooo
much for the rods.The 35 shot had me at 468whp and I made numerous passes down the 1/4 and it held up well.
I wasn't able to hit the 10's so someone else is going to have to try..sorry
Sorry to hear about your motor coach. I know you will definately hit 10's once the motor is built.
Are you going to leave the nitrous installed after the build?
What did you run without nitrous?
First run was 11.6 and the second was 11.5.
Tom, I would say I'm sorry about your motor but I think no condolences are needed.
You and I have always tried whatever we could to push our cars to the limit and we're aware of all issues that can arise.
I will however, say good luck to you on your build and hope to run against you in the not so distant future...
Originally Posted by coachk
If I do the build I have been thinking about, it will run in the 9's. N20 is always a part of my build.
Originally Posted by one350zfan
Isn't 11.5 your best turbo only run?
