Drag NHRA, IDRC, IHRA, NDRA
2nd time @ track !
Old Jun 14, 2008 | 01:14 PM
  #41
aguita's Avatar
aguita
Originally Posted by SlowZster
just try swapping out to a DR set-up. I find the 120trap hard to believe with 450rwhp on a dynojet though. If you are just all about parts that make you faster, then get those. If you like to make yourself faster so that you don't need to buy extra parts, or wait till you can actually use them to their capabilities, then just go to the track more often, and pick the brains of the people that are down there racing with you. I found that for me the best thing that worked on street tires was to rev the motor to about 2500-3krpm, and slowly let out the clutch so you don't spin or hop all the way down the track. About 3/4 throttle once clutch is all the way out, then in 2nd gear, smash it, if you break lose then reduce throttle a littel bit then lay into it again. I'm sure my way is wrong since I am also pretty new to drag racing with a car that can actually do something at the strip, and also my first manual transmission car. Hope this helps, and just have fun (if you truely own the vehicle).
I will try your technique today..
We have down here a Mazda Rx7 that Made 12.3 on street tires running on 19inch..The guyz here that make the best times are using DR..so i mostly want to lower my times b4 switching to DR ..
Tonight I will post a video of a Built Z that the guy i got the parts from on Puerto Rico made...10.03 5AT
Old Jun 14, 2008 | 01:30 PM
  #42
coachk's Avatar
coachk
Is the guy with the built Z named Tony@Performance.Is it a white Z?
Old Jun 14, 2008 | 02:27 PM
  #43
SlowZster's Avatar
SlowZster
Originally Posted by aguita
I was told that there is no need to heat up street tires..is this true??
that is true from what I know as well. Useless to heat up street tires, but you need to heat up slicks/dr's. Again, I could be wrong though, but I never heat up my street tires.
Old Jun 14, 2008 | 02:32 PM
  #44
coachk's Avatar
coachk
You are correct sir........
Old Jun 14, 2008 | 05:36 PM
  #45
warmmilk's Avatar
warmmilk
there is no need to heat up street tires, but you do need to clean them of all the debris that they pick up. the first run of the night, you should be fine without a burn out, but after one run, you get a bunch of VHT on your tires, and a bunch of little rocks stick to it. the reason for the burn out on street tires is to clear off all the little rocks and pebbles that stick to it
but then again, ranger (link from my previous post) ran an 11.1 on street tires on a bone stock z06, so i think the whole burn out thing varies from tire to tire, even with street tires... thats just my 2 cents
Old Jun 14, 2008 | 11:01 PM
  #46
aguita's Avatar
aguita
Yep..Tony ( best know as Tony Lexus ) Ferdinan Garcia is the guy I got the TT kit from..Im waiting for a guy from aeromotive named Luis Ramos to come to my country to tune both cars and he is bringing the Fuel Pump that tony owes me..
Do you know him??
He Sold me the Same setup of the White Z from there..Same Internals,TT,Etc..
Old Jun 14, 2008 | 11:32 PM
  #47
aguita's Avatar
aguita
as soon i get the fuel pump I will install the 750cc injectors and run boost up to 15 psi...currently only 8 psi..tony told me that with the setup that i have and 15 psi i should be putting down 600whp..hope so..
Old Jun 15, 2008 | 03:34 AM
  #48
coachk's Avatar
coachk
Do you know him??
No I don't know him...In the video section there is a video of him making 10 sec passes down the 1/4 mile. I need to find out what tranny he is using to make 10 sec passes.You mentioned that he has a 5AT and I was wondering what he has done to the 5AT, so that he can put down those kind of times.
Is he a member on this site? If not try to get him on here.
Old Jun 15, 2008 | 10:03 AM
  #49
aguita's Avatar
aguita
I will call him tommorow to ask what kind of tranny work he has..I really doubt that he is a member here..I will let you know once I talk to him
Old Jun 28, 2008 | 12:59 PM
  #50
coachk's Avatar
coachk
Were you able to find out what tranny he's using??
Old Jul 8, 2008 | 11:08 PM
  #51
carrera4s's Avatar
carrera4s
I pulled a 12.9 with 245mm 19 inch rear wheels in my g35
Old Jul 8, 2008 | 11:19 PM
  #52
Asian Invasian's Avatar
Asian Invasian
I am so jealous of you have two FI Z's.. I dont even get one
Old Jul 9, 2008 | 06:13 AM
  #53
ct350z's Avatar
ct350z
Im not in Miami..Im in dominican Republic..a island next to Puerto Rico
My local track is called Autodromo Mobil1 (Mobil1 SpeedTrack)
i was about to call you out until i rea this, theres no tracks in miami that look like those pics you posted at the track..lol
Old Jul 9, 2008 | 07:06 AM
  #54
Alberto's Avatar
Alberto
Cranky FI Owner
I want to see a timeslip....
Old Jul 9, 2008 | 07:51 AM
  #55
2004Black350z's Avatar
2004Black350z
Exhaust Whore
+1
Old Jul 9, 2008 | 03:42 PM
  #56
coachk's Avatar
coachk
hows this...
just messin with you Bert....
HoBrahYouStink
Jun 24, 2016 10:58 PM
