Drag NHRA, IDRC, IHRA, NDRA
It seems I have blown my rear end...
Old Sep 3, 2008 | 07:30 PM
  #41
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Mkriebs
Yep, just picked one up with 7k miles off ebay for $120 shipped.
you made sure it was the correct side right???
Old Sep 3, 2008 | 10:27 PM
  #42
Mkriebs's Avatar
Mkriebs
In the description it said passenger rear axle, so, as long as that is correct, I am good to go. If its not, I'm gonna be a bit salty.
Old Sep 4, 2008 | 03:52 AM
  #43
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
good stuff. Swapping it out is a piece of cake.
Old Sep 4, 2008 | 12:44 PM
  #44
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by mrg1981
From the description of their 900HP Level 5 rear axles:
"Nissan 350Z Level 5 900HP Rear Axles
Description:This is our Level 5 system for the 350Z and Infinity G35 coupe."
It sounds like they are exactly the same. Han from Intense has the exact same axles in his G35 and I have them in my ZR.
Thanks for the info...
Old Sep 4, 2008 | 08:25 PM
  #45
mrg1981's Avatar
mrg1981
NP
Old Sep 5, 2008 | 07:45 AM
  #46
coachk's Avatar
coachk
Alberto has snapped a Level 5 axle....I think he's the only one
Old Sep 5, 2008 | 07:56 AM
  #47
__jb's Avatar
__jb
Z + Rear Seat
Is this when he was NA or FI?
I don't think our rear ends are made for drag racing... but if I break one, I'll probably go with the level 5 axles.
Do you have the stock axles, Tom?
Old Sep 5, 2008 | 08:20 AM
  #48
coachk's Avatar
coachk
When he was FI.....Stock axles for me but I only launch around 3k'ish
Old Sep 5, 2008 | 08:33 AM
  #49
__jb's Avatar
__jb
Z + Rear Seat
Thanks, Tom.
The machine work is done on my motor and my G's over at PF for the swap out. Hopefully get it back next week...
Old Sep 5, 2008 | 10:22 AM
  #50
coachk's Avatar
coachk
Great ...keep me posted
Old Sep 5, 2008 | 10:19 PM
  #51
mrg1981's Avatar
mrg1981
That sucks to a degree, but keep in mind that they will replace it at 0 cost to you if you do. It is warrantied up to 900whp. Alberto is in the 5xx range, so I'm sure that if he went through the proper channels he didn't pay anything other than 1-2 hours of labor to replace them.
Old Sep 6, 2008 | 09:16 AM
  #52
Blwn_By_Twins's Avatar
Blwn_By_Twins
<------Must be blind!
Old Sep 7, 2008 | 10:29 PM
  #53
Mkriebs's Avatar
Mkriebs
Might wanna get the checked out. Really.
Old Sep 9, 2008 | 09:44 PM
  #54
Mkriebs's Avatar
Mkriebs
Well, I got my car back today. I had the dealer install my $120 ebay axle. The service manager said I did a "damn fine job finding that part" and he said it went in like pie. But, I got my old part back with the car, and it seems to be there is a bubble in the casting. Right where it broke, on each half, there is a dimple in the same spot. So, as I fork over about $250 to fix this problem (thank God for used parts) I wonder if I can get Nissan to at least cover the labor since it should have been covered under warranty.
Any thoughts? I will attempt to get a good picture of each half and post them here sometime when I pull some time out of mid air.
Old Sep 10, 2008 | 10:04 AM
  #55
S8ER95Z's Avatar
S8ER95Z
Glad you got it back together...let me know when you head over to Cordova again...if you are interested my club rents out Cordova again in Oct I think... it's 30 bucks for as many runs as you can make (Fiancee made 27 passes last time).
Old Sep 10, 2008 | 10:06 PM
  #56
Mkriebs's Avatar
Mkriebs
Oh yeah, definitely let me know when that is... i work at the Wal-Mart DC on weekends, so if its during the week it would work perfect. I absolutely refuse to run again this summer, I refuse to have a broken car any more... so what happens tonight? I hit a flippin coon and broke my bumper, and shoved it almost into my radiator. I can't catch a break (no pun intended).
October 3rd there is another midnight mayhem. I will be there, just not running. PM me or something sometime before then.
Old Sep 11, 2008 | 06:47 AM
  #57
S8ER95Z's Avatar
S8ER95Z
Well if you don't want to run this summer you are in luck...looks like we are going to have some retarded air to run in this year..
November 1 - Cordova Rental!
Old Sep 11, 2008 | 03:07 PM
  #58
Mkriebs's Avatar
Mkriebs
Sounds like a good time! Unfortunately, I will be working that day, so I won't be able to make it.
You gonna go to test and tune this Friday, I may go, not sure yet.
Old Sep 11, 2008 | 09:22 PM
  #59
jakesford's Avatar
jakesford
Those halfshafts are very strong but if you get some bad wheelhop with them and they'll let go in a hurry Just ask the 03' 04' cobra guys that still run an IRS
Old Feb 25, 2009 | 06:40 PM
  #60
zcoupe's Avatar
zcoupe
So, my first time at the track, completely stock 2006 Z. I pull up to the water box, botch my burnout because I forget to turn traction control off... and get to the line. I am figuring I will not hook because my tires are wet and the track is cold, and usually prepared poorly on test and tune nights.
So, I get to the line, and with very little experience launching, figure I will take it easy and go for the clutch drop... I revved to 2250 and dropped the clutch, only to be welcomed a wonderful jerk and pop. Of course, I know to pull to the side in case there are any fluids leaking (unlike the numb skulls running their Honda's ). Well, I try to go forward off the track, and no dice. The engine revs, clutch feels fine, and the speedo is going up as the engine revs...
So, i put it in reverse, and it moves, so I end up backing off the track, much to the enjoyment and sarcasm of the American Muscle crowd.
So, it seems I have blown my rear end. Shouldn't this have been able to handle the stock 300 hp? Was I a complete moron for launching it like that? What did I do wrong, or was it crazy circumstance?!
well i cant tell you what happened to your car but i can tell you that your first mistake was driving into the wetbox! on stock tires your supposed to drive around the wetbox
