Drag NHRA, IDRC, IHRA, NDRA
power braking or stand still burnout HELP
Old Dec 1, 2008 | 06:37 PM
bldg250z's Avatar
bldg250z
Default power braking or stand still burnout HELP
i'VE HEARD OF REMOVING A FUSE TO BE ABLE TO POWER BRAKE. DOES ANYONE KNOW WHERE THIS FUSE IS LOCATED. I WANNA DO THIS WHEN TAKING MY CAR TO THE TRACK ONLY!
THANKS
Old Dec 1, 2008 | 06:52 PM
my350isblack's Avatar
my350isblack
uh-oh
Old Dec 1, 2008 | 06:59 PM
I would begin looking in the fuse box. I know. Call me crazy!
Old Dec 1, 2008 | 07:11 PM
Z You Later's Avatar
Z You Later
why pull a fuse out? you won't need to if you know how to power brake an auto on a wet surface...not hard at all
Old Dec 1, 2008 | 07:53 PM
SchismX's Avatar
SchismX
sir, there is no need to yell. thanks
Old Dec 1, 2008 | 10:22 PM
J350z101's Avatar
J350z101
the "Search" feature is your friend
Old Dec 2, 2008 | 01:02 AM
blktrack350's Avatar
blktrack350
x2 and maybe a look into your owners manual. and what tires are you running
Old Dec 2, 2008 | 02:38 AM
mcarther101's Avatar
mcarther101
Have you even tried this in the Z yet? Engine power is cut by the ECU when brake/gas is used simultaneously.
Old Dec 2, 2008 | 05:48 AM
MarvinMartian's Avatar
MarvinMartian
Talking
I checked mine.
Can't find the "Doing A Burnout" chapter.
Old Dec 2, 2008 | 05:54 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
pull the brake light fuse
Old Dec 2, 2008 | 06:59 AM
bldg250z's Avatar
bldg250z
I'm running street radials Falken azenis and my z is manual so when you power brake the power gets cut off.
Old Dec 2, 2008 | 07:03 AM
ajcool2's Avatar
ajcool2
Ive done this in my Z at the track and it really wasnt worth it on my street tires. All it did was burn more tread off my tires faster. If you were running DR's or slicks than I'd say go for it.
Old Dec 2, 2008 | 07:54 AM
cracka350z's Avatar
cracka350z
turn off traction control...
Old Dec 2, 2008 | 09:34 AM
blktrack350
then you dont need to do a brake stand at the track if you are running street tires
Old Dec 2, 2008 | 09:45 AM
angelo350z's Avatar
angelo350z
+ 1. This will prevent the ECU from knowing your brakes are on, thus not cutting power off.
Old Dec 2, 2008 | 10:19 AM
Alberto's Avatar
Alberto
Cranky FI Owner
brake light fuse, drivers kick panel
make this a track only mod obviously your BL's wont work when doing this! i felt the need to explain this to you seeing as how your incompetent enough to not search.
Old Dec 2, 2008 | 10:30 AM
tylerxfire's Avatar
tylerxfire
brake light fuse like everyone else said, drivers side .. problem solved but don't do it on the street. . no brake lights
Old Dec 3, 2008 | 03:54 AM
SSZVirginia's Avatar
SSZVirginia
Originally Posted by MarvinMartian
I checked mine.
Look in the chapter entitled Tips for Teen Driving. It’s all right there.
Old Dec 3, 2008 | 07:21 AM
thom000001's Avatar
thom000001
OR get your traction control to error out like mine......I can brake boost on the highway......till we move the sensor lol
Old May 6, 2009 | 06:18 AM
Kung Fu Sifu's Avatar
Kung Fu Sifu
the fuse is a 10A fuse. i believe it is located approximately on the bottom right hand side. To the right of the fuse picker in the first cluster of 3. its the first fuse that has the 10 on it. located in the bottom row. If you still have trouble, you can buy a haynes do it yourself manual, complete taredown book and they are located in advanced auto parts stores. The book will show you everything you need to know about the fuses. Im me personely if you still have problems. I cant stand these know it all E-thugs!!!!! And of course the fuse panel is in the drivers side kick panel.
