Drag NHRA, IDRC, IHRA, NDRA
Osiris "Launch Control"
Old Mar 2, 2010 | 02:52 PM
Jairen's Avatar
Jairen
Default Osiris "Launch Control"
Just wondering if anyone has actually used the "launch control" feature at the track with success.
Shawn at Church set my rev limit to 3200 rpm on launch control.
Seems more like a simple rev limiter since it doesn't control wheel spin.
What I'm looking for is more consistency off the line at the track. My 60 ft's range from 2.0-2.2 on the crappiest street tires you can drag with (Goodyear Eagle RS-A's). Now have Michelin PS2's in the rear.
Old Mar 2, 2010 | 06:02 PM
Italianjoe1's Avatar
Italianjoe1
You won't find an aftermarket "launch control" that controls wheel spin, they are all basically a 2-step. The benefit is you can be full-throttle and just manage the clutch, along with it being exactly repeatable every time, as opposed to you only being at part throttle at a random RPM point.
Old Mar 2, 2010 | 06:09 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
How does this "launch control" actually work? That is, what physical process signals the ECU to WOT (just after launch) from the partial throttle (before launch)? Is it the act of letting off the clutch that triggers the ECU to WOT? One of our vendors, KPierson, actually developed this 2-step a while back. If it's another 2-step, then I'll pass.
Old Mar 2, 2010 | 07:16 PM
209Z33's Avatar
209Z33
hey jairen you goto test tune on april 17?
Old Mar 2, 2010 | 07:20 PM
Jairen's Avatar
Jairen
I am really thinking about it. Seriously. If I get the days off to drive up there to visit family, I'll go.
Old Mar 2, 2010 | 07:24 PM
209Z33's Avatar
209Z33
same here if i get the day off i'm gonna go
Old Mar 2, 2010 | 07:26 PM
209Z33's Avatar
209Z33
there also one in march 20
Old Mar 2, 2010 | 07:36 PM
cdoxp800's Avatar
cdoxp800
Here is the link for reference
http://www.kptechnologies.com/products.php#/21
ITEM#TSNL-25
Old Mar 2, 2010 | 08:13 PM
209Z33's Avatar
209Z33
now it all make sense
Old Mar 2, 2010 | 09:40 PM
Jairen's Avatar
Jairen
So has anyone use these at the track yet?
Old Mar 3, 2010 | 08:38 PM
redman333's Avatar
redman333
These are just to control rpm on your launch. I believe the 2 step will also build boost if you turbo'd. They do make actual traction control that reads throttle and wheel speed sensors but they aren't cheap. I believe race logic makes one.
Old Apr 7, 2010 | 09:05 AM
rich2342's Avatar
rich2342
I was just reading in the tuning forum and another guy just was tuned with this. I was wondering about it as well.
First track day is Sat. What RPM's do you fella's typically launch at?
Im modded/tuned as well on stock driveline, so I want to be carefull while getting a decent launch
Old Apr 7, 2010 | 12:29 PM
str8dum1's Avatar
str8dum1
they are all just 2 steps. it holds a certain rpm until the clutch switch is released.
The rpm you launch it is dependent on your tires mostly. 2-3000 rpms is pretty safe but some guys can launch at 5-6000 which I think is crazy
Old Apr 7, 2010 | 12:36 PM
03threefiftyz's Avatar
03threefiftyz
No power with lots of traction=high launch rpm.
Old Apr 10, 2010 | 09:14 PM
Smoothy34's Avatar
Smoothy34
i saw that Ztune sells this unit from Racelogic...this what you're looking for?
http://www.ztune.ca/product.aspx?pro...d-0003ff2732c9
Old Jun 1, 2011 | 02:39 PM
zheka911@hotmai's Avatar
zheka911@hotmai
Default Just curious
Hey man what do you have on your Z that your running 5.03 0-60? just curious what it takes. let me know thanks
Old Jun 1, 2011 | 03:38 PM
03threefiftyz
Truth be told....my car is probably a fair bit quicker to 60 than 5.03. 275ish whp on drag radials.
Old Jun 3, 2011 | 02:31 PM
djamps's Avatar
djamps
Osiris as launch control is pretty lame (go towards the end):
http://www.youtube.com/watch?v=sXY3WGF6huE
Get the 2-step if you're serious.
NissanZcrazy
Nov 2, 2015 06:03 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
