Drag NHRA, IDRC, IHRA, NDRA
350z drag race question
Old Jul 23, 2010 | 04:47 PM
chriss450's Avatar
chriss450
Default 350z drag race question
I am new to owning a nissan 350z. I have an 05 with very minor mods. I went to a drag strip this weekend and was somewhat disappointed with the cars performance / mine too!!
The car is a 6 speed, and I cannot do a burnout for the life of me...does anyone have any suggestions or tricks to it?
The other thing is that when I take off, the rear end like hops trying to get traction, I have the traction control turned off, I have goodyear eagle f1's
My best was a 15.59....not good
What are any of you guys running and what mods do you have? I would like to turn the car into something that runs close to a 10 - 11's.
Like I said I'm new to owning the car....it is embarrassing not knowing how to do a burnout!!
Old Jul 23, 2010 | 04:50 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
if u want 11s ur gonna need a lot of CF and NOS. Good luck though iv been in the 11s once and my exhaust flew off
Old Jul 23, 2010 | 05:21 PM
350z-Jason's Avatar
350z-Jason
He is getting 12.5 with his RSX with this mod list:
turbonator
ebay superchip
Since you have a 350z... you'll easily get into the 9's.
http://www.youtube.com/watch?v=9srm-TCyjQc
Old Jul 23, 2010 | 05:26 PM
2004Black350z
Exhaust Whore
WHAT THE FCK IS THAT ANNOYING NOISE IN THE VID? omfg. my ears are bleeding
Old Jul 23, 2010 | 05:28 PM
cdoxp800's Avatar
cdoxp800
That's the turbonator. LOL
Old Jul 23, 2010 | 05:31 PM
2004Black350z
Exhaust Whore
omg i just ordered one but i cant take that noise. OP u sure ur ready to hit 11s? if so ill sell u a BNIB turbonator
Old Jul 23, 2010 | 05:40 PM
fatjoe's Avatar
fatjoe
That sounded like a little raddle from the professionally installed High Performance exhaust from Autozone Motorsport.
Or maybe he didn't secure the camera in a good place and its raddling.
Old Jul 23, 2010 | 05:46 PM
Z1NONLY's Avatar
Z1NONLY
Check your rear diff bushing. Z's have wheel hop issues when new, but if the fluid-filled bushing on the rear of the differential goes, it gets really bad.
If you see any gray streaks that look like dried fluid, it's probably fluid from the blown bushing.
You could just be trying too hard. Try some lower rpm launches (3k-ish) without "dumping" the clutch. Just let it out quickly with minimal slip and feed in throttle as the clutch grabs.
Old Jul 23, 2010 | 05:59 PM
When you hit second gear hit the NOS switch.
Old Jul 23, 2010 | 06:57 PM
03threefiftyz's Avatar
03threefiftyz
My bad OP I hit the edit button instead of quote...........I fail.......second time I have done that.....
I am feeling generous today............
It's hot.....you car will never run as well as it will in the late fall/early spring. Just a fact. To do a true burnout in our cars you must remove the stop lamp fuse in the driver side kick panel. You do NOT need to remove this on street tires. Just give them a spin to get rid of the water/debris. Heating up street tires is not a good idea........they only handle a certain amount of heat before they become greasy......even the best of the best extreme summer tires. Those tires, while able to handle more heat and with the stickier compound, are not really suited to drag racing either.......the sidewalls are to stiff.
If you are running a 15.59 right now.........you have a long way to go before you should think about 10/11's. Improve the driver........then the car.
Old Jul 23, 2010 | 07:14 PM
fabcas311's Avatar
fabcas311
what did i miss?????lol
Old Jul 23, 2010 | 11:30 PM
ffwturboZ's Avatar
ffwturboZ
turbonator
ebay superchip
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/9srm-TCyjQc&amp;hl=en_US&amp;fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/9srm-TCyjQc&amp;hl=en_US&amp;fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
Huh, are we talking 1/8 miles times? There is no way 9's are possible in the 1/4 mi without major engine, FI and suspension mods ($$$$$)
Old Jul 24, 2010 | 08:34 AM
tylerxfire's Avatar
tylerxfire
this is a joke right..who did this really? this dude cant be so stupid
Old Jul 24, 2010 | 12:43 PM
kbogarto's Avatar
kbogarto
I ran a 14.3 with my stock Z(2003 touring, 6spd) and i am not a great driver. you should at least be in the 14s. are you shifting at redline?
Old Jul 24, 2010 | 01:21 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
So, you're running close to 16 seconds in the quarter mile and you want to be running 10s? Your lack of experience on the track (and with the car) is painfully obvious and to be concerned with running faster times when you lack any skill is absurd.
You need to work on how to launch your car, shift faster, etc and master those things first. Once you can CONSISTENTLY hit mid-high 13s lightly modded or high13/low14s stock, then you can worry about making your car faster.
Please search around this drag sub-forum and read everything that you can. The more you read, the more you will learn and will be able to incorporate what you've read at the drag strip. Almost everything you will come up with has been discussed in this section at one point or another -- trust me.
Check out the top 25 drag racers list for ideas, methods, modifications, time slips, etc. If I were you, I'd listen to the guys at the top of those lists, rather than whoever chooses to answer you in your thread (if that wasn't obvious enough in this thread ).
Old Jul 26, 2010 | 06:42 AM
ffwturboZ's Avatar
ffwturboZ
^^^^+1
Old Jul 26, 2010 | 08:33 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Can somebody please tell me what I need to do to run 7's in my 350z?
My best is only low 11's, thanks....
Old Jul 26, 2010 | 11:45 AM
*Boose*'s Avatar
*Boose*
You could benefit from a header. You could also get some smaller wheels like 14s. My buddy did that with his supra making like 1000hp and some federal all season tires and ran a mid 7 @ 190 with a 9.3 60ft. Very fast.
Old Jul 26, 2010 | 11:52 AM
ajcool2's Avatar
ajcool2
One Word.....NAWZ
Old Jul 26, 2010 | 03:01 PM
jbaker1121's Avatar
jbaker1121
you are all wrong, all he needs is a 500 shot of naws and needs to install some vtech and wait until it kicks in....
