Drag NHRA, IDRC, IHRA, NDRA
first time at the strip
Old Jan 20, 2011 | 07:24 PM
paintdaworld88's Avatar
paintdaworld88
Default first time at the strip
[IMG][/IMG]
Went to Bradenton motorsports tonight hoping to break 13's which was a lot easier then i thought it was going to be first run of the night was a 13.9 with a 2.1 60ft..... had a few 13.9s and a couple of 13.8s and a 13.6 which im so happy about.... I have an 08 base 6mt with jwt pop chargers and also stock air pressure in the tires didnt lower them at all hopefully the picture works if it doesnt ill try and post it again
Old Jan 20, 2011 | 08:10 PM
*Boose*'s Avatar
*Boose*
Low trap speed. Need to work on that launch son and maybe shifting.
Old Jan 20, 2011 | 08:27 PM
paintdaworld88
please explain!!! Is a 2.05 60' not good? and work on shifting? at what rpms should i shift at then to better my trap?
Old Jan 20, 2011 | 08:28 PM
OzzysCar's Avatar
OzzysCar
I've been wanting to go down there for some time to run my Z. I've heard good things about Thursday nights but I've never gone. Maybe one of these nights I'll head down there.
Props for racing your Z at the track and not on city streets.
Old Jan 20, 2011 | 08:34 PM
03threefiftyz's Avatar
03threefiftyz
Both the 80mph 1/8 and 100mph 1/4 speeds are very weak for an 08. Gaining only 20mph in the second 1/8th is troubling......you should pick up 22-23mph easy. This points to either a lack of power or very slow shifts. 2.05 60' isn't bad on street tires.
Old Jan 20, 2011 | 09:02 PM
*Boose*'s Avatar
*Boose*
Exactly. I thought I saw 2.1 60'. I need to go to bed.
Old Jan 20, 2011 | 09:12 PM
paintdaworld88
well lack of power i've only put pop chargers in so I really shouldnt be much more then stock and slow shifts wise im at a drag strip I assure im not shifting slow.... The only thing i can come up with is the shift points im shifting at are wrong for me not to be traping at 102+ like your saying i need to be at.... I shift right now right before rev limiter! im guessing now i shouldnt do that?
Old Jan 20, 2011 | 09:14 PM
03threefiftyz
We have stock HR's running 104mph+ with some regularity. I would put the car on the dyno and make sure you aren't way down on power. Even a stock HR should, again, pick up 22-23mph in the second 1/8th.
Old Jan 20, 2011 | 09:18 PM
paintdaworld88
hmm..... ok.
Old Jan 22, 2011 | 11:43 AM
EL Matador's Avatar
EL Matador
There is a group from Tampa driving down this Thursday you should go back out..
Old Jan 22, 2011 | 12:01 PM
You did good. Congratulations.
Old Jan 22, 2011 | 09:29 PM
paintdaworld88
Thats awesome. Ill definitely be their.... And thank you for the Congratulations Davidv
Old Jan 22, 2011 | 10:23 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I assure you that you are shifting slow. Everybody thinks they can shift fast.
Keep practicing and you will improve. MAYBE affter 1 steady season you will look back and laugh at what you thought was quick shifting.
60ft is there for a much lower time, so its the shifting.
Old Jan 23, 2011 | 12:48 AM
03basesedan's Avatar
03basesedan
Your trap speed is very low, and your ET could be quicker.
Are you sure your Pop Chargers are giving you any power?
Old Jan 23, 2011 | 02:14 PM
nismonian's Avatar
nismonian
there's ALOT of us heading down there this thursday, come join us and run that thing
+1 on what el matador said, alot of us are going down there this thurs, what color is your Z so we can spot you
Old Jan 23, 2011 | 03:04 PM
paintdaworld88
+1 on what el matador said, alot of us are going down there this thurs, what color is your Z so we can spot you [/QUOTE]
silverstone!!!!! And as far as the pop chargers no idea... Didnt get the z on a dyno before or after. I know intakes dont do much i got it more for the sound..... And as far as the shifting ill agree with you guys then that im shifting slow, but has anyone heard of the transmision problem with the loud whine? could this have anything to do with the slower trap speed? maybe.... But with that being said it was my first time out their with the z and with the redline i improved a lot with practice like everyone does.. Thank you for the input everyone
Old Jan 23, 2011 | 03:45 PM
03basesedan
There is a big debate about intakes and power gains. I know which side I'm on, but I think both parties cannot deny that short rams intakes, w/o adequate heat shields (completely isolate the filter element from the engine bay air), suck in hot air in the staging lanes. You're ECU pulls timing off the launch, even if only for a few seconds, and you're slower. Another consideration is that cone filters change the way the air flow hits the MAF, and this potentially confuses the ECU into overestimating the amount of air entering the intake tubes. As you can imagine, that has consequences. Try this, if the strip is empty, and you can do a bunch of passes, bring the stock intakes too. Run both and see what you notice.
How cold is it down there?
The 1st -> 2nd shift is essential for a good time. All shifts are essential in a 1/4mi run, but if you mess that one up, you're screwed. Try to minimize wheel hop, but make it as fast as possible.
What are you shift points?
Old Jan 23, 2011 | 08:03 PM
nismonian's Avatar
nismonian
awesome, i have the injens and to be honest i didnt feel any gains.. maybe 5whp if i put it on the dyno but thats it. a friend ran a 13.1 with injens and 13.2 without... as far as the tranny if your talking about the whine when your in neutral and realease the clutch it's normal, just the throwout bearing is a little loud. my clutch got stuck to the floor last time we were out, im going to try to launch a little differently this time and see what happens.
Old Jan 24, 2011 | 07:39 AM
paintdaworld88
thursday when i ran it was low 70's and shift points are just below redline.... and with what you just said about the intakes im probably just going to throw the stock ones on for the day
Old Jan 27, 2011 | 03:37 PM
paintdaworld88
[IMG][/IMG]
13.4 at 103 with a 2.0 60ft will post slip when I get home if it stays my best the only z out here though wondering if anyone else is coming
? Thought their was suppose to be
