13.17@103mph at san antonio raceway tonight
Just got back from the track and had quite an improvement from last time. Ran a 13.17@103mph with a 1.85 60ft i beleive and a few other 13.2's. Best 60ft was a 1.81 but I still haven't mastered launching the 350 with the ET streets. Guess i just need to practice. It was pretty cold out so i'm sure that didn't help traction any. Should have a scan of the timeslip in a day or two as a friend took it to scan it for me.
here are the details from my second fastest run:
60ft 1.8917
330ft 5.4637
1/8 et 8.4326
mph 85.00
1000 et 11.0137
1/4 et 13.1960
mph 103.81
60ft 1.8917
330ft 5.4637
1/8 et 8.4326
mph 85.00
1000 et 11.0137
1/4 et 13.1960
mph 103.81
nice ET! I'm a little confused by your 1/8 mile trap speed...a Z should pick up AT LEAST 20mph in the second 1/8 mile and 85 mph is a REALLY HIGH 1/8 mile trap for a bolt-on Z. Plus you supposedly only picked up a little over 18mph in the second 1/8.
I ran the 13.3 in my sig last weekend and trapped just over 81mph in the 1/8 and near 104 in the 1/4...so I picked up nearly 24mph in the second 1/8.
Not doubting your times....just confused.
Some may think it's due to the slicks "hurting" top end, but I'll have to disagree...when I ran slicks last summer I still picked up well over 20mph on the top half of the track.
BTW - how did you heat up your slicks if you did??
I can only assume it's the slicks that are slowing me down on the top end. Time slip is on www.splparts.com main page for my fastest run. I ran at least 6 runs that night with no major changes in traps-all within a few mph, even the one I missed 3rd gear on and ran a 13.5. I was running between 11.5 and 13lbs in the tires-gets pretty floaty on the top end at that low a pressure.
Oh yeah, we were racing straight into the wind-i think the forecast was for 10-15mph and looking at flags in the wind we were driving straight into it. A few others were complaining of slow traps that night also.
And to answer your question on heating the slicks, I did burnouts for each run but didn't really get a good one till the last run. It's a lot tougher in the 350 than in the 300. Not sure if it's the difference in power or the brake bias, but I have trouble holding the burnout in the 350. Too bad some idiot in a Z06 took 30 seconds to stage on my last run while my tires cooled down and I just got another 1.85 60ft.
What are the best 60ft's people are getting with DR's or ET Streets? How are people launching on ET Streets? what tire pressure and RPM?
I think the best DR 60's are typically in the 1.8s....
I think I ran around 15psi in the slicks when I ran them...and I just sidestepped the clutch @ 6000rpms...
yeah you definately want more air in those slicks...i run 14-5 in mine and the car launches perfect, no spin or bog...different car but you dont need to go any lower than me
I was 3215 with driver i think. I ran 15psi last time and had 2.0 60fts last time, although I only got 2 runs in that night. I was just experimenting with different pressures. I usually run 14-15 when i race the 300, but thought i'd drop it a bit as the 350 is a few pound lighter. Do you guys run tubes in the ET streets? I have them but am debating getting rid of them at recommendations from a other z32 drag racers.
Originally posted by Daking350z
I have tubes in mine but you really dont need them unless your running crazy low air pressure.. which I dont suggest, I ran 13 and almost hit the wall..Seriously..
Made 2 runs the first time (2.0 60fts) and 6 runs the second time out. 60 ft times ranged from 1.81 to 1.89 last time out. Hoping to improve upon these.
