Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Best cold or warm tire pressure for drifting?
Old May 12, 2004 | 10:24 PM
BlackZ33's Avatar
BlackZ33
Default Best cold or warm tire pressure for drifting?
What's the best tire pressure to set when trying to learn drift?
For stock tires...
Thanks
Old May 13, 2004 | 10:25 PM
Topics II's Avatar
Topics II
I generally do anywhere from 26-30 psi (cold). Depending on the grip of the tire.
Old May 14, 2004 | 06:30 PM
BlackZ33's Avatar
BlackZ33
Cool, I think that was the pressure that I was running ,
It was easier to slide my car during that time.
Right now I am running 35psi cold...too high I guess
I will try to change it to 26psi and see how the car feel
Old May 16, 2004 | 07:29 PM
zfastest's Avatar
zfastest
Just got back from a weekend where I actually got a chance to play with tire pressures a bit. I found that running a really high pressure (40psi front, 38 rear) worked well for the size I was running: 235/50/17 front, 245/45/17 rear
If I was using a lower profile tire with stiffer sidewalls I'd use less pressure, but with my setup and stock suspension it was causing the tires to roll-over A LOT, and caused very uneven tire wear. Depending on skill level it could be a good or bad thing but it did result in a much lower grip level. I personally like having more grip for higher speeds and stuff, but it did save me on the tire wear, and it is was much more even.
If you've got lower profile tires, then Topics setup works best with the lower pressure.
Happy Drifting.
Old May 18, 2004 | 10:29 AM
Topics II's Avatar
Topics II
Yeah... in the rear i used to run 245/40, then i switched to 255/35, and now i think im going to run 265/35. i tested them last tuesday and it felt great, so ill probably stick with that. the fronts were 225/40, and now are 235/40.
Old May 19, 2004 | 06:07 AM
BlackZ33's Avatar
BlackZ33
I am still running with stock tires.
F 225/45/18 R 235/45/18
Zfastest you suggest me to run (40psi front and 38 rear) when tires are warm ?
or is it cold air pressure?
lapham3
Oct 7, 2022 03:15 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
