FS: Exedy stage 4 twin disc clutch NM072HD
Old Jul 5, 2013 | 10:39 AM
DaveSB's Avatar
DaveSB
Default Exedy stage 4 twin disc clutch NM072HD
This is an Exedy stage 4 NM072HD twin disc, ceramic, clutch kit for an 03-06 350z and 03-07 G35. I had it in my 350z and it's too much clutch for what I need. It has less than 500 street miles and no track miles. It doesn't even look fully broken in, yet.
These go for over $1800 new! I'm asking $1000 OBO
Exedy's Product Description:
Exedy NM072HD Multiplate Clutch Kit 03-07 Infiniti G35 VQ35DE
For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Specs:
Years: 03-07
Number of Discs: Twin
Spring Damper Discs: Sprung Center Disc
Push / Pull: Push Type
Disc Outer Diameter: 200mm
Spline Teeth / Major Diameter: 24T / 25.6 mm
8 flywheel crank bolts required
Attached Thumbnails Exedy stage 4 twin disc clutch NM072HD-photo.jpg   Exedy stage 4 twin disc clutch NM072HD-photo-1-.jpg
Old Jul 8, 2013 | 05:02 AM
Vortec27's Avatar
Vortec27
Default Other side
[QUOTE=DaveSB;10164153]This is an Exedy stage 4 NM072HD twin disc, ceramic, clutch kit for an 03-06 350z and 03-07 G35. I had it in my 350z and it's too much clutch for what I need. It has less than 500 street miles and no track miles. It doesn't even look fully broken in, yet.
Specs:
Any photos of the disc condition ie other side of clutch!! .?
Old Jul 8, 2013 | 09:26 AM
DaveSB's Avatar
DaveSB
few pics of the insides.. as you can see, the heat checks haven't even made their way all around the outside. It has very little miles on it.
Attached Thumbnails Exedy stage 4 twin disc clutch NM072HD-photo-2-.jpg   Exedy stage 4 twin disc clutch NM072HD-photo-3-.jpg
Old Jul 14, 2013 | 02:25 AM
Vortec27's Avatar
Vortec27
How much bhp was you running on this clutch?
Old Jul 15, 2013 | 04:55 AM
DaveSB's Avatar
DaveSB
I am running NA mods of a whopping 280ish at the wheels. I track my car pretty often, but like I said, it was just too much clutch for me. It's rated for 615tq according to Exedy.
Old Jul 30, 2013 | 05:33 AM
DaveSB's Avatar
DaveSB
FYI, it sold. Thanks for all the interest
EnjukuRacing
Sep 30, 2015 06:55 AM
