Rubber on stk oem 18's for track use
Old Apr 28, 2008 | 07:29 PM
Smasher's Avatar
Smasher
Default Rubber on stk oem 18's for track use
Are any fellow Canadians running 275wide rubber on stk 18" OEM rims?
I maybe able to swap my OEM 17'' rims and tires for some OEM 18" 2004 RIMs and was thinking about putting rubber on them for track use.
Falken AZENIS RT-615
245/40/18 front
Rears 255's or if they will be ok 275/40/18's on the rear.
I did search other forums and some guys say they are running 275's but will they hold up at the track?
Thoughts?
(my 17's wont fit over my Stoptechs so....)
Old Apr 28, 2008 | 09:46 PM
XuperXero's Avatar
XuperXero
275 will bulge too much. Not good for track. You'll actually lose stability and grip. 255 is a wiser choice for the rear, after all it is only 8" wide.
Old Apr 28, 2008 | 11:42 PM
apharmdb's Avatar
apharmdb
I'd reccomend picking up a set of A-Tech (MB Motorsports) wheels. They run approx $120 US each and come in 17X9 with a +27 offset (I think). These will clear your Stoptech as I used to run that exact configuration. 275/40/17 on all 4 corners worked great on the track.
Old Apr 29, 2008 | 03:41 AM
Smasher's Avatar
Smasher
That sounds like an good idea, the rubber for 17's should be less and help cover the cost of the rims. Who sells these A-Tech?
thx
Old Apr 29, 2008 | 10:00 AM
Type-S's Avatar
Type-S
thx
if you look at for sale forums you should be able to find some
I thought about going this route before and found several sets available
Old Apr 29, 2008 | 11:02 AM
apharmdb's Avatar
apharmdb
thx
Should be able to find some on the classifieds here, heck I sold my set here a while back www.discounttiredirect.com has them new and they also have a decent price on the RT-615's if that is what you are planning on running. The A-techs are sold under the "MB Motorsport" label. Here's an example:
http://www.discounttiredirect.com/di...w=7&bp=5-114.3
Offset is wrong but give them a call. The +27 did clear my Stoptech kit with plent of room to spare.
Old Apr 29, 2008 | 05:46 PM
Smasher's Avatar
Smasher
Here is a pic of the stk 18 RIMs over the stoptechs They clear the caliper by about 1/4 inch
I have a dumb question though. The stock RIM's did not seam to fit flush against the rotors like the Volks do. The wheel seams to fit against the hub but not clear it. Is this normal? I attached a pic best I could and you can see the wheel bolt between the wheel and rotor.
I tried fitting my stk 17's and there was no way they would clear the Calipers and mount on the wheel studs. I find it hard to beleive 17"'s would work.
Old Apr 30, 2008 | 08:25 AM
Smasher's Avatar
Smasher
Comments on how these 18's mount?
Old Apr 30, 2008 | 08:27 AM
Reality350's Avatar
Reality350
I never looked closely at my stock setup, but I doubt that is how they should sit.....
Old Apr 30, 2008 | 03:30 PM
Smasher's Avatar
Smasher
Bump any one else know how the stock rims should sit against the hub?
I want to trade for these 18's but it looks kinda abnormal.
Old May 1, 2008 | 06:38 AM
edvy's Avatar
edvy
seems like the rim is not sitting all the way into the rotor's hub centric.
can u take another pic from diff angle?
Old May 1, 2008 | 07:35 AM
Smasher's Avatar
Smasher
Thats with all the nuts on and fairly tight. I think this is how my orrigional 17's fit but it was so long ago I can't remember.
I had some other pics but this is the best one.
Old May 1, 2008 | 08:28 AM
edvy's Avatar
edvy
hey smasher, your rim is not sitting on your hub centric ring at all if u tell me your wheel nuts are tighten up already...
i would recomm you to get a wheel spacer (see something similar for the H&R track spacer) they are bolt-on kit without replacing your wheel studs. and if u have to shave off the hub centric., please do so b4 you put on the 18stk wheels. i remember i had to do some alter to the rear stoptech rotors b4 i put on my z. its better to space out your 18stk wheel anyway on the track
Old May 1, 2008 | 12:10 PM
Smasher's Avatar
Smasher
Thanks Edvy
I will take a pic of the hub without the rim later this wekend. It seams odd that the stock wheels would not fit properly. I will check the rears out as well.
Old May 5, 2008 | 04:58 PM
Smasher's Avatar
Smasher
So it looks like I won't be able to use Nissan stock 18 RIMs over my stoptechs
There is lip around the center hub from the 2 pc rotor that makes the hub about 1/4 inch too big. The Volks fit fine they have a 2 7/8 opening and thats about the same size as the stoptechs rotor lip around the hub.
Guess I would need to buy new RIMs and tires for the track now when I was hoping to trade my 17's for 18's and then just get new rubber. UHG!
This next one is a close up of the hub.
And this one the back of the Volks
Old May 5, 2008 | 05:24 PM
noodleman's Avatar
noodleman
Dave, are you sure that's not the hub adapter off your TE's? it doesn't look like it's attached to your rotors....have you tried prying it off your rotors?
I know my Winnings came with a set of hub ring adapters for the Z...
Old May 5, 2008 | 05:36 PM
jasonintoronto's Avatar
jasonintoronto
uh...that's not good.
very few 17"s will fit with large calipers. i use spacers to get mine to clear my brembos
Old May 5, 2008 | 05:59 PM
Smasher's Avatar
Smasher
It sure looked like it was attached to the rotor plate. I didn't try to pry it off other than pic behind it with my finger nail. I didn't get any hub adapters with the rims from (Goulung Spelling?) that I can remember unless they were already on the back of the rims.
So you think I should have one more go at this and try to pry that off?
Old May 5, 2008 | 06:56 PM
noodleman's Avatar
noodleman
it wouldn't hurt. The more i see it the more it reminds of the hub ring I got from my winnings. It flares out abit at the base just like yours. You should probably use some WD40/used oil to slick it up and try to pry it off with a small flathead screw driver or something.
Old May 6, 2008 | 06:36 PM
noodleman's Avatar
noodleman
any luck dave?
