Tire feathering on Canadian Z's
Old Nov 28, 2003 | 07:59 AM
Wotnot's Avatar
Wotnot
Default I'll be happy to that
as soon as it stops raining long enuff to check my tires for signs of feathering.
Old Nov 28, 2003 | 09:21 AM
Wotnot's Avatar
Wotnot
Default Does anyone
happen to have the actual TSB nubmer on this issue?
Old Nov 28, 2003 | 10:08 AM
Boske's Avatar
Boske
Default canadian tires
What I found with my tires is that the tread blocks on the inside edge are cupped. So if you run your fingers along around the tire on the inside edge, you should feel the leading edges of the tread blocks.
chris
Old Nov 28, 2003 | 11:19 AM
Wotnot's Avatar
Wotnot
Default As soon as it stops raining
I'll go check.....thanks for the tip
Old Nov 30, 2003 | 09:07 PM
Strife350z's Avatar
Strife350z
Originally posted by Strife350z
For those who have had this service performed - when they swapped your tires, did they scratch your rims? I've heard horror stories from the tire feathering thread about people who've had their rims disfigured by this process...
FYI: they scratched my rims pretty badly (about a 2 mm ring of paint was scratched off all around the circumference of both front rims).. i'll probably need to put some silver touch up paint on it next spring...
I really wanted to stay and watch them do it, but I didn't have time so I went to work and picked up my car later... and by then it was too late... oh well... hopefully i won't need my dealer to mount and dismount my tires very often
Old Dec 2, 2003 | 01:47 PM
Wotnot's Avatar
Wotnot
Default Ok.....any luck on the TSB ?
Do we have any idea what the TSb number might be?
Old Dec 2, 2003 | 01:57 PM
Boske's Avatar
Boske
Default tsb #
check here
http://www.nissan-techinfo.com/nissa...3.asp?mscssid=
Old Dec 2, 2003 | 01:58 PM
Boske's Avatar
Boske
ntb03046
Old Dec 8, 2003 | 09:41 AM
Wotnot's Avatar
Wotnot
Default Has anyone else
called Nissan Canada about this? I'm taking my Z in this week to replace the antenna (vandalized) and I intend to bring the subject up.
I'm confused a bit. Are some of you guys now experiencing pulling to the right after the alignment when you didn't have this problem before?
Old Dec 8, 2003 | 10:03 AM
Wotnot's Avatar
Wotnot
Default Just called the dealer
and they were fully aware of the problem. They've had three or four in already and he has me booked for tomorrow.
On the subject of tires, The service tech had not heard anything from Nissan about replacing tires.
I'll keep you guys posted. We need more threads on Canadian owners Z's
Old Dec 8, 2003 | 10:10 AM
Boske's Avatar
Boske
To clarify..
My car handled fine. No pulling to either direction, but the tires started to wear inproperly. So the dealer did an alignment and all 4 wheels were out of spec to varying degrees. Now they are aligned to Nissan spec, but the car pulls and the tires are starting to get really loud...
My parts are now in at the dealer and I am hoping to get the TSB work done before the end of teh month.
Old Dec 8, 2003 | 07:58 PM
Wotnot's Avatar
Wotnot
Default so...you have had one tsb performed
which has now led to another problem requiring another TSB?
Old Dec 9, 2003 | 06:23 AM
Boske's Avatar
Boske
The first work was only an alignment. It is not part of any TSB. It was in response to the tires wearing.
The TSB for 'Tire Feathering' actually only states that the front tire should be swapped. They wanted to do an alignment first and then address this and the Pulling to the right TSB after.
Old Dec 10, 2003 | 07:32 PM
nissan350zca's Avatar
nissan350zca
for this and much more 350Z info, check out www.Nissan350Z.ca - a forum for Canadian 350Z Coupe and Roadster owners...
Old Dec 11, 2003 | 01:50 PM
Wotnot's Avatar
Wotnot
Default mine is in having the TSB performed
as we speak.......I hope the rims come back ok......and I hope this noise doesnt come back
Old Dec 19, 2003 | 09:08 AM
Wotnot's Avatar
Wotnot
Default well....no problems with scratched rims
and the tsb took the noise away......My alignment was also out a bit so I'll monitir the situation and keep you guys in the loop.my tires didnt show any signs of wear.
Old Dec 19, 2003 | 12:58 PM
Boske's Avatar
Boske
I would have thought that the noise would only be associated to the wear...
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
