---Project Polish---
Old Mar 22, 2010 | 05:35 PM
XERMAN2001's Avatar
XERMAN2001
Default ---Project Polish---
I have seen a few zeds online here with a polished oem upper plenum and liked it so I decided to do mine. Some have done them themselves others have paid around $300 to get them done professionally.
Here is some of the equipment I needed to complete this project
-Safety glasses
-respirator
-ear protection
-gloves
I bought an extra plenum to polish that way my car would still be drivable. What it looked like when I stared, rough and dirty.
After 4 hours of using an air grinder with a 40 grit flap disk and a Rotary tool with a grinding stone. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-Air grinder
-40 grit flap disk
-Rotary tool with and assortment of grinding stones
On a small part of the plenum you can see I did a few more steps to see some shine, (I wanted some motivation lol)
After another 4 hours of using an air grinder with a 80 grit flap disk and a Rotary tool with a grinding stone and 80 grit flap wheel. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-Air grinder
-80 grit flap disk
-Rotary tool with and assortment of grinding stones, sanding wheels and flap wheels.
Old Mar 22, 2010 | 05:36 PM
XERMAN2001's Avatar
XERMAN2001
After another 6 hours of using an electric orbital sander with 80 grit sand paper, 120 grit sand paper and 220 grit sand paper. A Rotary tool with a 80 grit flap wheel and wire wheel. (should have took less time but even with 2 compressors I still had to wait for them to keep up)
-5 inch electric orbital sander
-80 grit sand paper
-120 grit sand paper
-220 grit sand paper
-Rotary tool with and assortment sanding wheels, flap wheels and wire wheels.
After another 3 hours of wet sanding by hand with 400 grit and 800 grit. A Rotary tool with a 80 grit flap wheel, wire wheel and sanding wheel.
-400 grit wet sand paper
-800 grit wet sand paper
Old Mar 22, 2010 | 05:37 PM
XERMAN2001's Avatar
XERMAN2001
After another 2 hours of using an air die grinder with a felt/cloth wheel and a black compound/bar.
-Air grinder
-an assortment of felt/cloth wheels
-black compound/bar
Old Mar 22, 2010 | 05:54 PM
phreaktor's Avatar
phreaktor
Design Engineer
Polishing cast aluminum is a pain in the *****, but worth it in the end if you take-your-time.
Old Mar 22, 2010 | 06:52 PM
Kiriller's Avatar
Kiriller
Looks sexy wish hr plenum looked nice
Old Mar 23, 2010 | 05:52 PM
XERMAN2001's Avatar
XERMAN2001
i am getting there lol
Old Mar 23, 2010 | 06:24 PM
lgear080's Avatar
lgear080
always wanted this. good work. end result worth effort.
Old Mar 23, 2010 | 07:32 PM
stclairwest's Avatar
stclairwest
Hey how much would you charge for this?
Old Mar 24, 2010 | 02:55 PM
Risky_Business's Avatar
Risky_Business
Quadrant 987c
Default Finish...
the job...
- RB.
Old Mar 24, 2010 | 03:08 PM
Waiz's Avatar
Waiz
Looks like the Tin Man from the Wizard of OZ
Old Mar 24, 2010 | 09:51 PM
AVmagneticZ's Avatar
AVmagneticZ
**** should get mine done. Nice work gonna look sweet when ur finished
Old Mar 25, 2010 | 05:21 AM
Smasher's Avatar
Smasher
That is a ton of work, looking great so far.
Old Mar 25, 2010 | 05:26 AM
ed@aph's Avatar
ed@aph
Vendor - Former Vendor
OP should talk to smasher, he extended his polish to vtc cover & powder coated his valve cover. Dave def has one of the best looking engine bay in TO area.
Old Mar 27, 2010 | 05:02 PM
XERMAN2001's Avatar
XERMAN2001
--more pics added -- post #2 and #3
A sneak peek of things to come
Old Mar 27, 2010 | 06:54 PM
Kiriller's Avatar
Kiriller
Need more pics
Old Apr 9, 2010 | 10:09 AM
XERMAN2001's Avatar
XERMAN2001
After another 2 hours of using an air die grinder with a felt/cloth wheel and a White compound/bar.
After another 2 hours of using an air die grinder with a felt/cloth wheel and a Red compound/bar.
After another 2 hours of using an air die grinder with a felt/cloth wheel and Metal polish
--- another 6 Hours total---
-Air grinder
-White compound/bar
-Red compound/bar
-Metal polish
--HERE ARE THE PICS AFTER 25 HOURS OF WORK---
Old Apr 9, 2010 | 10:48 AM
XERMAN2001's Avatar
XERMAN2001
I also polished my strut bar. The bar is made of steel not aluminum so it can rust. The bar is not on the bar and was finished 4 weeks ago. It has been stored in the garage since then and shows no signs of rust. I am thinking/hoping that if I keep a protective coating of polish on the car it will not rust. If it does rust I will sand it again and clear coat it, or just reinstall my other oem bar.
-Air grinder
-1000 grit wet sand paper
-black compound/bar
-Red compound/bar
-Metal polish
i am not sure how long this took me, maybe 2-4 hours total.
before and after pics
Old Apr 9, 2010 | 11:16 AM
TheUntouchableZ's Avatar
TheUntouchableZ
damn that looks clean!
Old Apr 9, 2010 | 11:27 AM
Entaille's Avatar
Entaille
holy **** 25 hours, you are a man of dedication
Old Apr 9, 2010 | 01:27 PM
AVmagneticZ
So how much did u pay for the spare plenum? And where did u get it a wreckers? Also would u be willing to do this again for some moolah? Also have the two pieces of an aftermarket strut bar I might want done as well. Let me know
