FS: HKS Twin Power DLI II
Old Oct 30, 2010 | 03:29 PM
Smasher's Avatar
Smasher
Default FS: HKS Twin Power DLI II
I have an HKS twin Power DLI II sitting colecting dust.
I decided not to put this on when I had the rocker covers painted red because the extra harness would cover up my nice red rocker covers.
Asking $275
Old Oct 30, 2010 | 03:50 PM
BashaZ's Avatar
BashaZ
What does it do?
Old Oct 30, 2010 | 04:03 PM
Smasher's Avatar
Smasher
Originally Posted by BashaZ
What does it do?
This is right off HKS website
Twin Power DLI II (more)
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-29)
Old Oct 30, 2010 | 07:07 PM
R3belzBRN's Avatar
R3belzBRN
im intersted.. any pics?
Old Oct 30, 2010 | 11:12 PM
BashaZ's Avatar
BashaZ
So it pretty much does what the Sun Auto HyperForce Ignition Tuning System I just bought does?
Old Oct 31, 2010 | 11:38 PM
R3belzBRN's Avatar
R3belzBRN
brand new or used?
Old Nov 1, 2010 | 07:25 AM
Smasher's Avatar
Smasher
It's used maybe 8-10K miles on it.
Old Nov 7, 2010 | 07:08 AM
Smasher's Avatar
Smasher
Added Pic
Old Nov 12, 2010 | 04:49 PM
Smasher's Avatar
Smasher
PM's replied
Old Nov 22, 2010 | 02:18 PM
Smasher's Avatar
Smasher
Still available.
Old Dec 11, 2010 | 06:05 AM
Smasher's Avatar
Smasher
TTT...
Old Dec 14, 2010 | 11:00 PM
woRthy's Avatar
woRthy
Sun Auto Hyper Force Ignition Sytem with Plug-n-Play sell brand new from 250! and does the SAME THING!
Old Dec 15, 2010 | 06:26 AM
BashaZ's Avatar
BashaZ
^^ Is it necessary to **** on other peoples threads?
Old Dec 15, 2010 | 02:48 PM
Smasher's Avatar
Smasher
Thanks Basha.
Different brands have different price points common sense stuff.
HKS list price on this is $600 US and checking other sellers I'm right in line or on the low side considering CDN funds and all.
Old Dec 15, 2010 | 05:55 PM
Wu-Watt's Avatar
Wu-Watt
^^That dude is lousy at life... You should check out his Turbonetics FS thread... It's great!!
Old Dec 16, 2010 | 09:39 AM
woRthy's Avatar
woRthy
lol its awesome!
Old Jan 29, 2011 | 05:31 AM
Smasher's Avatar
Smasher
Bump for me
Old Feb 20, 2012 | 04:30 AM
Smasher's Avatar
Smasher
Still for sale
Old Jun 10, 2012 | 05:27 AM
Smasher's Avatar
Smasher
Sold
Old Jun 10, 2012 | 05:56 PM
4DGS's Avatar
4DGS
Smasher, did I see you cruisin' through Fergus today?
