278.3 Rwhp & 249.7 Tq Naturally Aspirated
Old Dec 5, 2004 | 03:50 PM
ZBoater's Avatar
ZBoater
Originally posted by 287HP
I did the cams a year ago from from an independent shop, but the guy was a nissan master-tech. The install cost was about 1200 dollars(13 hours).
OUCH!!! I better start saving my pennies then, cause cams are on the list.
Old Dec 5, 2004 | 05:05 PM
287HP's Avatar
287HP
Default Re: Re: 278.3 Rwhp & 249.7 Tq Naturally Aspirated
Originally posted by TXSTYLE
VERY nice my man! Congrats. I'd be interested what a 'G-Tech' has to say about your times.
What would be your guesstimate @ crank-hp?
TXSTYLE,
Looking at other charts, I noticed that most E46 M3s put down about Mid 270s rwhp and they are rated at 333 crank hp. So probably about 340 hp at the crank on a nice cool day! Nice car by the way!
Old Dec 5, 2004 | 05:09 PM
287HP's Avatar
287HP
Originally posted by metalz
Damn that install is rediculoso...what hp gains did you get from the cams?
I have to dyno my car but have the aem intake/injen exhaust and am working on a sponsorship with Alphawerks for their headers/test pipe combo package...
Nice gains overall though
I never dynoed the cams by themselves, but I did a dyno of them with the borla exhaust and picked up 19 rwhp. I think the thing that was holding me back was the stock cats. Letting the cams breath(test pipes) really helped a lot.
Old Dec 5, 2004 | 05:52 PM
ZBoater's Avatar
ZBoater
Default Re: Re: Re: 278.3 Rwhp & 249.7 Tq Naturally Aspirated
TXSTYLE,
On the topic of calculating crank hp from rwhp numbers, I wrote this in another forum a few weeks back...
Originally posted by ZBoater (in another forum)
I have been reading a gazillion threads on hp and torque on the Z, and I realize that a stock Z can vary between 230-245 rwhp and 220-235 lbs/ft torque. The "advertised" numbers are 287 and 274 (crank, not rear wheel). Also, some have estimated the drive train loss at 15-20%
So, I was speculating... (cause I had nothing better to do...)
If you put the numbers on a spreadsheet and play with them, I think you can learn some interesting things. Dynos are not accurate, and comparing different dynos is even worse, granted. But I just wanted to have an idea (+/- 5hp) of what a stock Z should be, since I neglected to dyno mine before I screwed with it.
Soooo, 80% of 287hp reaching the rear wheels is 230. 80% of 274 lp/ft torque is 219. That is consistent with the low numbers of all the dynos on stock Z's I read in the dyno thread.
When looking at all the stock dynos, it seemed to me like 235 hp and 230 ft/lb torque was more "common" (not a statistical avergage, more of an observation). I am including the numbers I observed at the end of this post for your viewing pleasure. If we consider these numbers and compare them to "advertised" crank numbers, then there is a 82% power transfer (18% loss) of hp and 84% transfer (16% loss) of torque. Pretty close to the 80% quoted figure.
Soooooo, I'll split the difference and say stock Z's suffer a 17% powertrain loss. Using advertised crank numbers of 287 hp and 274 lbs/ft of torque that should yield 238 hp and 227 ft/lb torque on a dyno for a stock Z. Give or take a few hp.
Is this making sense to anybody?
So what does all this mean? It means I was really bored and was wondering about this, and my mind works in weird ways. Anyone care to comment or add to this discussion?
Here are the numbers for dynos I've found in threads for stock Zs. The first is hp and the second is torque.
230
220
244
235
235
228
235
230
231
213
238
228
230
230
230
224
Old Dec 5, 2004 | 06:37 PM
NOR-CAL Z TUNER's Avatar
NOR-CAL Z TUNER
Originally posted by barthelb
What up fellows.
I took a ride in this mean N/A mother. Let me tell you I think the numbers are wrong too. I think they should be higher. This thing pulled just about like the supercharged Z's I've rode in with 300+rwhp. A wise man once said something (Rob) a car can have 1000rwhp but if it feels slow and is then what's the point. This car may say it has 280 or so but it pulls much harder. This car feels great and sounds great. I would think the 40 or so Horses mine lacks from his feels like 100. If yal can ever get a ride do it. It's bad ***.
Peace!!
Old Dec 5, 2004 | 06:58 PM
axxizzer's Avatar
axxizzer
not bad at all
now you should get a 350evo final drive and nismo diff-cover
POW kill much more expensive cars
Old Dec 5, 2004 | 07:04 PM
axxizzer's Avatar
axxizzer
ooh ooh
add me to your stock power list
i got
234 whp
228 wtq
Old Dec 5, 2004 | 07:22 PM
Zmego1985's Avatar
Zmego1985
When my Z was stock i dynoed 237 hp and 219 torque for my auto.
Old Dec 5, 2004 | 08:32 PM
ReavTek's Avatar
ReavTek
Wow, great numbers from such a small number of mods. Imagine what would happen with some crazier Tomei cams! Hah, I think I will stay N/A for a little while longer... pick up some headers and buy all those little grounding kits from Sun Auto (Hey, if they at least gain 4 hp im happy cause my enine bay looks so plain :/)
Old Dec 6, 2004 | 09:55 AM
NOR-CAL Z TUNER
i have a question about the cams and the tuning done to your car. was the piggy back computer able to control the fuel and timing ?
Old Dec 6, 2004 | 10:43 AM
287HP's Avatar
287HP
Yes. We, however, left the timing alone and just added a little extra fuel. When we first dynoed after all the parts were installed, the A/F ratio was in the mid 14s all the way up to redline. The xede obviously intercepts the MAF signal, so Rob(tuner@ZCargarage) just added some more fuel to the mix and got my numbers right into the mid 13s up to about 6000 and then richened it up to 12.9 all the to redline. Car runs extremely smooth.
Old Jan 30, 2005 | 08:49 PM
mena661's Avatar
mena661
Hello, I'm new here. I have a question about the XEDE. Did Vishnu install it or did ZCARGARAGE? Also, was there any wire splicing involved in the XEDE install or did Vishnu/ZCARGARAGE have a "jumper" harness already made? Thanks.
Old Jan 30, 2005 | 09:02 PM
sentry65's Avatar
sentry65
the burninator
I still need to get my ecu and A/F tuned better and also try out a different dyno shop sometime, but according to the dyno shop near my house, I'm doing 268rwhp and 240tq SAE at about 80 degrees or so that day with my current mods (see sig).
I'm not sure what's up whether AZ just sucks for dynoing, that particular dyno shop sucks, my car somehow is weak/bad engine, or it's my A/F or ECU tuning. who knows.
My car feels like a monster though...
Old Jan 31, 2005 | 05:45 AM
FairladyZ's Avatar
FairladyZ
You numbers are practically the same with his in fact yours is a few rwhp more, both very impressive. I notice you are running colder plugs, why? Thats got to be hurting you a little.
Guys that run colder plugs usually are spraying.
Old Jan 31, 2005 | 06:14 AM
sentry65's Avatar
sentry65
the burninator
I'm planning on spraying, but technosquare recommended using colder plugs to help counter my engine misfiring - which it didn't really seem to help against
Old Jan 31, 2005 | 06:25 AM
FairladyZ's Avatar
FairladyZ
On the 'LS1' it was normal for throwing misfire codes. Because of the cam profile/spec. We just deleted it using LS1-edit. I would think it would be the same for all cammed cars.
But you say you will be spraying anyways.
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
foxsmp26
Sep 25, 2015 09:48 AM
3.9LTwinTurbo
Mar 3, 2003 08:33 AM
mike952
Aug 27, 2002 10:52 AM
