Samco Hose Kit...rubbing issue...
Old Dec 26, 2004 | 09:04 PM
Sins4u33's Avatar
Sins4u33
Default Samco Hose Kit...rubbing issue...
Does anyone else have a problem with rubbing issues with the hose that goes from the themostat to the radiator? i noticed it today after having it on for about a day...i dont want my pulley or belts cutting a hole inthe hose....what should i do i think i might go in tom and pull it out a bit to make sure it doesn't rub cause i noticed alot of red particals around the pulley thats closest to the themostat....anyone else have this problem??
Ben
Old Dec 26, 2004 | 10:30 PM
westpak's Avatar
westpak
SFZCC
Nope. And had them on for over a year.
Old Dec 27, 2004 | 02:47 AM
DeeZee's Avatar
DeeZee
are you refering to the large hose on the right side? if so, it sounds like it is upside down. there is a bend in it that pushes it away from the pulley. if it is indeed backwards, it will have very little to no clearance. you should have a few inches between there. post a pic if you can. i remember seeing a pic you might find helpful. ill see if i can find it?
Old Dec 27, 2004 | 02:50 AM
DeeZee's Avatar
DeeZee
here you go. look at the pic of the hose im refering to, and see if it is backwards.
http://crackaddict.com/~flynn/samco/samco.how-to.htm
Old Dec 27, 2004 | 07:33 AM
Philthy's Avatar
Philthy
Boost Junkie
Does anyone know if the 350Z kit will fit the G35 Coupe ?
DeeZEE, awesome link.
Old Dec 28, 2004 | 03:00 AM
DeeZee's Avatar
DeeZee
i found it on here!
Old Dec 28, 2004 | 06:30 PM
ericinmia's Avatar
ericinmia
i'm curious too...
Chris350z03
Oct 8, 2023 07:19 PM
SonnyWu
Nov 24, 2015 08:19 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
PureR3d
Sep 10, 2015 06:23 PM
