Shift to neutral without pressing the clutch?!
Old May 4, 2005 | 09:47 PM
Phatmitzu's Avatar
Phatmitzu
Exclamation Shift to neutral without pressing the clutch?!
So I was driving in slow traffic, shifted from 1st to 2nd. All under 4k rpm. As soon as I let out the gas I managed to shift into neutral from 2nd without pressing the clutch?! I did it by accident without any effort. It felt like the clutch was pressed tho it was not. I was like... So I tried to repeat it again...
I can shift into neutral from 2nd, 3rd and 4th without stepping on the clutch, but only right at the moment after I let out the gas tho.
Anyone have experienced the same thing?
BTW, I have Nismo clutch and flywheel.
Old May 4, 2005 | 10:03 PM
harrieyu's Avatar
harrieyu
if your at the correct rpms u dont even need the clutch
Old May 4, 2005 | 10:28 PM
narkotic's Avatar
narkotic
Yep, try shifting next time w/out the clutch... as the rpm's drop, gently pull the stick out of gear and ease it into the next gear, it will shift. This is what the syncros are for. I do it all the time
Old May 4, 2005 | 10:32 PM
harrieyu's Avatar
harrieyu
dont try it unless your know absolutely that the synchro is correct or youll grind the gear. WORST sound and feeling ever
Old May 5, 2005 | 03:41 AM
002-M-P's Avatar
002-M-P
I love doing this as well. It only works for me upshifting from 3rd to 4th or downshifting from 4th to 3rd though.
That is how cars had to shift in the old days, you didn't have synchros so you had to rev match.
Old May 5, 2005 | 05:59 AM
afreemason's Avatar
afreemason
Motor bike clutches are designed to allow you to do this - car clutches allow you to do it if you've got the skill to match the revs each and every time ..... if you get it wrong - no gearbox !!!!!!!! Your choice mate but I won't be doing it with mine any time soon !!!!!
Old May 5, 2005 | 06:58 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
don't do it too much. you WILL grind the gears.. do the right way, press down the clutch and shift, and change shift.
Old May 5, 2005 | 07:15 AM
aki's Avatar
aki
if you're shifting into neutral your synchros are NOT used and it's fine to do what you're doing. the gears are cut so that when you transmit power through the trans the gears pull together - it'll be really hard to pop it out of gear under full throttle. but when you coast the only thing keeping you tran in gear is some notch thing (usually spring loaded indent stop). so if you're coasting, it takes the same effort to put it into neutral as if you pushed the clutch in. this is fine/normal.
if you're shifting into a gear then your synchros are used ONLY IF your engine speed does not match your neutral shaft (idle shaft? I dunno what it's called) speed when you pop it into gear. the synchros will match up the speed of your neutral shaft and the output shaft (driveshaft). that's a whole different topic. that's where heel/toe comes into play (btw the stock Z is terrible for heel/toe with its megaton flywheel).
aki
Old May 5, 2005 | 07:21 AM
002-M-P's Avatar
002-M-P
Another comment, its one thing to play around and do this while cruising, but never shift under power without the clutch. That can just be devastating.
Old May 5, 2005 | 01:06 PM
King Tut's Avatar
King Tut
And you wonder why so many 350Zs have transmission problems. .
Old May 5, 2005 | 02:51 PM
ssc's Avatar
ssc
^yep, what they said about rpm match....though i have never met anybody who been able to shift through all the gears like that..
Old May 5, 2005 | 04:16 PM
bwilliams's Avatar
bwilliams
aki is 100% correct (several post up). And the NASA space shuttle never has a problem as long as everything works as planned...except for those two occasions where everything didn't work as planned...ooooops.
NOT in my Z!
Yes, you have stumbled upon one of those little known functions of manual trans that is better left a ignored.
Old May 5, 2005 | 04:25 PM
nbdyfcnsqnc's Avatar
nbdyfcnsqnc
I wouldn't even try that with this car. But after I read this thread I had a dream about shifting that way. Trust me, I'm a damn good driver when I'm sleeping.
Old May 5, 2005 | 04:49 PM
Phatmitzu's Avatar
Phatmitzu
Oh ok. Phew...I thought there was something wrong with my tranny.
Yeah, I have only tried to shift out into neutral w/o the clutch. My ***** arent big enough for me to try shifting into gears.
Old May 6, 2005 | 05:05 AM
King Tut's Avatar
King Tut
Your synchros apreciate that.
Old May 6, 2005 | 10:44 AM
jinsei888's Avatar
jinsei888
LoL! I think I'll be fine shifting the way I've always been, the idea scares me to skip the clutch haha
Old May 7, 2005 | 08:16 AM
FairladyZ's Avatar
FairladyZ
Your clutch is going bad.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
