Differential
Old Aug 6, 2005 | 01:23 PM
Binictican's Avatar
Binictican
Default Differential
Can I take a 6 SPD differential and put it straight into a 5 AT instead of changing the Final Gear?
Old Aug 6, 2005 | 02:08 PM
Machupo's Avatar
Machupo
you mean just take the VLSD out of a 6MT car and put it into a 5AT?
yes, but since you've got a base model you'll need to buy new stub axles that will work with the VLSD unit (from Courtesy Nissan -- or some other place that sells OEM parts)
if you use the search function you'll find plenty of threads on this already posted
Old Aug 6, 2005 | 02:15 PM
John's Avatar
John
I believe you may need to use a different pumpkin, but don't quote me on that. If you want an OEM VLSD, I have one available for you...
Old Aug 6, 2005 | 02:29 PM
Binictican's Avatar
Binictican
Sorry....wil search
Old Aug 6, 2005 | 02:30 PM
sentry65's Avatar
sentry65
the burninator
you can switch out the pumpkins, yes
most people with 5AT cars do that - junk yards are a place to look
Old Aug 6, 2005 | 09:03 PM
Gsedan35's Avatar
Gsedan35
No, your A/T ring and pinion gearset will not work on a M/T core. This is why Cusco makes Z33 clutch type LSD's in M/T and A/T version's.
The oem diff cores for A/T's and M/T's are not the same parts and differ in where they place the final drive in the case (pinion gear). The diff on the left is a oem A/T diff, and on the right is a KAZZ lsd for a M/T, notice how they do not mount the gear at the same height in this work bench view.
Old Aug 6, 2005 | 09:07 PM
Gsedan35's Avatar
Gsedan35
Your best bet for going oem VLSD with the least amount of money spend and the least hassle is to go to Car-parts.com and search 350z 2003+ Carrier. You should be able to find one for $500 complete pumkin shipped. Their # is 1-888-733-2540.
Old Aug 7, 2005 | 09:52 AM
Binictican's Avatar
Binictican
Default explanation
Thank you for the explenation and pics especially!!!!!!!!
Old Aug 8, 2005 | 08:34 AM
zachcrosen's Avatar
zachcrosen
Or just find someone local to you that wants to swap out pumpkins. I will be going this on Sat if all goes as planned.
Old Aug 8, 2005 | 12:50 PM
booger's Avatar
booger
Yes...I took a whole rear end from a 6MT LSD and swapped it out on my Open 5AT . Very easy
Old Aug 8, 2005 | 12:54 PM
sentry65's Avatar
sentry65
the burninator
are you talking about wanting a different final drive or specifically have a reason to use a 6MT LSD in your 5AT housing, cause that won't work.
just swap the whole pumkin with a 6MT
don't even try to mess with changing the final drive. There's too many wrecked Z's laying around in junk yards with good 6MT pumkins
Old Aug 8, 2005 | 12:59 PM
booger's Avatar
booger
even easier to do the the whole rear end
Old Aug 8, 2005 | 08:23 PM
1sloZ's Avatar
1sloZ
Sorry to steal this thread but i have a 03 touring 5AT. Now i have already got both the 3.59 gears and also a VLSD out of a 6MT. Now from my understanding there isnt any more parts i need for the swap or is there? From the way I am taking this post is that i cant do this at all???? Please tell me that I am wrong.
Old Aug 8, 2005 | 10:54 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
sounds like he is wanting to just swap the complete assembly from 6mt to 5at... yes you can do that...
cheepest way to do it is go to a junk yard, find a manual that is wrecked in the front end... take the complete housing... put it on your 5at... call it a day...
Old Aug 9, 2005 | 12:18 AM
sentry65's Avatar
sentry65
the burninator
think you need additional parts to make it work
Old Aug 9, 2005 | 09:19 AM
1sloZ's Avatar
1sloZ
So what eles would i need to complete this?
Old Aug 9, 2005 | 09:28 AM
Jason@Performance
Performance Nissan
if you get a complete housing... nothing...
Old Aug 9, 2005 | 03:57 PM
1sloZ's Avatar
1sloZ
why couldnt i just use the housing i have on my car? i have a touring not a base, i thought the only Z's with a different housing was the base.
Old Aug 9, 2005 | 04:21 PM
sentry65's Avatar
sentry65
the burninator
yours is auto right?
then the housing is different than 6MT
it's easier to swap the entire pumkin with a 6MT one. Just do it that way. You'll save 100's of $ by doing it that way. You can do it the other way too and spend a lot more money and risk it not being installed quite right
Old Aug 9, 2005 | 04:24 PM
1sloZ's Avatar
1sloZ
sounds like that is what i am going to do than thanks.
