Nismo LSD Adjustments
Old Aug 15, 2005 | 09:14 AM
KTaylor's Avatar
KTaylor
Default Nismo LSD Adjustments
I just got a new 350z. It came with the nismo LSD installed on it and it supposidly has three settings. Right now it is on the most agressive setting and i was wondering which one i should adjust it to, the least agressive or the one in between. I think i would perfer the one in between but if its going to make daily driving a hassle id just put it on the lowest setting. Anyways let me know what you think i should do. Thanks, Kurt
Old Aug 15, 2005 | 09:36 AM
sentry65's Avatar
sentry65
the burninator
do the least aggressive at 60% lockup if you drive on the street
80% would be annoying, and 100% could be dangerous... on the street assuming you turn the car
Old May 14, 2006 | 07:44 PM
ngcharleshk's Avatar
ngcharleshk
I have 100% setting, its my daily drive and I take it to the track about once a month, also drift events once in a while. I m totally in love with my setting, it doesnt get dangerous on the streets, but you just have to get used to the popping sound, after a while, you wont even notice it anymore. You will be driving ur buddy's bimmer and be like, "is there something missing in your rear axle?"
Old May 16, 2006 | 01:37 AM
Zincognito's Avatar
Zincognito
How can you adjust it though?
Old May 16, 2006 | 11:43 AM
ngcharleshk
you can adjust it by removing the right side flange, using a 19mm box wrench to adjust the lock up %. Here is the thread which has the instruction manual. Hope it helps!!
https://my350z.com/forum/showthread....mo+lsd+setting
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
