What is neccesarry in tuning?
Old Aug 26, 2005 | 04:12 PM
plumpzz's Avatar
plumpzz
Default What is neccesarry in tuning?
Well I'm ready to order a few bolt on parts.. JWT popcharger, high flow cats, true duel exhaust but I'm concerned about running too lean. I have read up that i should let the stock ECU 'learn' one mod at a time so it can adjust, but even with that precaution there is a danger of running too lean. Will a tune fix this problem? Will I get better output from the mods w/ a tune nontheless?
Thanks
-Rajan
Old Aug 27, 2005 | 06:28 AM
RyanAtAltered's Avatar
RyanAtAltered
Thumbs up
The stock 350z ecu will run the car lean because of emissions purposes. However, adding the intake, cats and exhaust will give your power gains regardless. So if you can't do the ECU upgrade right away, that should be fine. As far as adding mods one at a time, thats really up to you, the ECU will learn the new mods regardless, the one advantage of doing one at a time is if there is a problem its easier to troubleshoot, because you only installed one thing, not 3, so there are less plaes to look.
Ultimately, I'd suggest an ECU reflash and our Angled Intake Spacer, in addition to your mods planned. We do the ECU here, and we can also custom dyno tune your car for extra cost, so the tune is specific to your car and your mods. If you have any questions on the spacer, ecu tuning or anything else. Let me know. We're here to help!
Old Aug 27, 2005 | 03:20 PM
plumpzz's Avatar
plumpzz
Where are you located? Im in Old Bridge, centeral jersey. And whats an angled intake spacer?
Old Aug 27, 2005 | 03:21 PM
plumpzz's Avatar
plumpzz
Oh a plenum.. how much hp/tq does your angld intake spacer add? the dyno on ur site isn't clear. Looks like peak 10-12/8-10
Old Aug 30, 2005 | 08:13 PM
TwoNosBottles's Avatar
TwoNosBottles
i didnt know old bridge had so many silver zs running around, at least i know i was the first . none the less good aquisition an congrats
Old Aug 30, 2005 | 08:22 PM
plumpzz's Avatar
plumpzz
hey where do you live? lol.. Southwood has a Silvertone and a PPW...i have the CS...I've seen a blue and another ST around...lol
2ndchanceZ
Oct 26, 2015 08:03 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
