Apperantly a LightWeight Pulley is bad for your car?
Old Sep 29, 2005 | 09:44 AM
lunartick13's Avatar
lunartick13
This thread is getting interesting on this issue, I need to know more FACTS. If I knew for sure that an after market pully does not cause any damage to the main crank I will defenitely buy after market...
Old Sep 29, 2005 | 10:04 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Interestingly enough, when we take apart stock motors with stock crank pulleys, we notice a little bit more wear on the front main bearing. This is actually somewhat normal, as there is more pressure on this bearing, due to the tension of the belts on the pulley. But overall, it was nothing to worry about.
Old Sep 29, 2005 | 11:40 AM
JDMFairlady21's Avatar
JDMFairlady21
i demand this thread be stickied!
Old Sep 29, 2005 | 11:42 AM
002-M-P's Avatar
002-M-P
I still think a thread containing info about this and other stuff should be made for a sticky rather than one that you have to read like 15 posts down to get the info you want.
Old Sep 29, 2005 | 12:28 PM
Cronic's Avatar
Cronic
Originally Posted by tonywenzel
hmmm... sounds like you need to practice what you preach.
HAHA.. Ok let me rephrase. I know alot about JDM Sti's.. Believe me i am always in learn mode and will pick up anything new i can pick up, when i am wrong i admit it. Eh what am i saying i only have 60 posts, i can't know anything
D-
Old Sep 29, 2005 | 03:59 PM
VeilsideZ33's Avatar
VeilsideZ33
just got mine installed- Turbo spools up a LOT faster... can't wait to get the flywheel in! Kinda off topic, but would a JDM VQ35DE be any better than a USDM VQ35?
Old Sep 29, 2005 | 04:10 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Jdm Vq = Us Vq
Old Sep 29, 2005 | 06:34 PM
lunartick13
Thanks for sharing that little piece of info...Sharif. Do you know what the weight of the OEM pully is vs Alum. pully? I know titenium would be the ultimate but I guess that would cost a small fortune..
Old Sep 29, 2005 | 06:41 PM
Nano's Avatar
Nano
I weighted them when I installed mine... been a long time
stock = 6 pounds 3 ounces
UR = 1 pound 5 ounces
titanium would be more or less the same as aluminum... Magnesium pulley would be better
Old Sep 29, 2005 | 09:23 PM
VeilsideZ33
so a stock one is 6 times the weight! :O
Old Sep 29, 2005 | 11:51 PM
kosmic's Avatar
kosmic
6.3 / 1.5 = 4.2
Old Sep 30, 2005 | 08:11 AM
spacemn_spiff's Avatar
spacemn_spiff
People talk like they are analysts who know where the causes of a particular wear or failure are. Only thorough analysis correlated by tests will show the effect of a particular variable such as pulley/flywheel in the engine. And engine manufacturer is most probably the only source who is capable of doing analyses and tests. So discounting or dismissing little things out of hand is not a smart thing to do.
There is a common misconception that if the part is CNC machined, its perfect. I hate to disagree that even after you CNC machine a pulley, there is a need to balance it because of non-homogeneity of the raw/billet materials. And this balancing should be done taking into account the imbalances in the crank that include the flywheel too, I would imagine thats how the stock pulley was designed/manufactured. And if you observe a rotating part that is balanced, there are holes drilled to remove mass just like wheels of a car are balanced by adding weights.
And one more mod that I see is lighter flywheel mod. The reason why a particular flywheel is a certain mass and mass distribution is balance the loading on a rotating mass by absorbing and releasing momentum. How many of these flywheel manufacturers actually analyse this. One of the fundamental reason why an engine has a flywheel is to even out the loading and the more cylinders you have, the more balanced is the engine without the flywheel, so that means it needs a lighter flywheel. So this flywheel mod just bothers me. I cannot turn a blind eye to these things being an engineer. I need to find an explaination as to how this is better and will affect other parts such as bearings etc.
Bearings, a common man cannot simply inspect the bearings and expect to know how the wear pattern is, how the lubrication/loads/temperature is affecting its wear. I work on momentum wheels that run at 100,000rpms for 15-20 years of mission life in space where you cannot replace them. And there are special bearing experts who have 30-40 years of experience who we rely on for them to work reliably.
Old Sep 30, 2005 | 08:24 AM
Z1 Performance
Former Sponsor
I am no engineer, but I cannot fathom how all that overengineering would ever be possible in a stamped piece of metal...which is exactly what the stock pulley is.
While I agree in general with your statement, the anecdotal evidence does not lie. I have not once, ever, in the 9 or so years I have been around UR pullies, seen a single Nissan V6 motor fail due to the installation of the pulley. Be it a VG series or VQ series. In fact I have not seen any other motors let go because of said pulley either, but thats not relevant to the motor at hand.
As I have said before, some engines can have pullies installed without rebalancing, some cannot..the Nissan V6 s one that is balanced internally, not externally, from the factory. As such, it does not matter what you hang on either end of it, so long as that part is, itself, balanced
Old Sep 30, 2005 | 08:28 AM
Nano's Avatar
Nano
Originally Posted by kosmic
6.3 / 1.5 = 4.2
unfortunately pounds and ounces are not decimal, lol
6 pounds 3 onces is not = 6.3
there are 16 onces in 1 pound
Old Sep 30, 2005 | 09:22 AM
kosmic's Avatar
kosmic
Right you are. I was drunk when I posted that last night.
Old Sep 30, 2005 | 10:01 AM
002-M-P's Avatar
002-M-P
99oz/21oz = 4.71 times lighter
Old Sep 30, 2005 | 11:16 AM
spacemn_spiff
I agree that the engines might not have failed or might not even fail or be unreliable. I didnt mean specifically the pulleys though, all I am saying is that mods are not necessarily the design intent of a particular part of the car, but there are always ways of optimizing a part or component, but lightweighting isnt always the answer.
Nissan V6 is balanced internally? The external part that balances the crank loads is the flywheel. I dont know what your source is, may be you have more information than me. I know that crankshafts have balance weights for each con rod/piston assembly, I assume that is what you meant.
Old Sep 30, 2005 | 12:15 PM
  #38
Z1 Performance
Former Sponsor
the engine is not balanced with the flywheel on the car - hence why you can put a lightweight flywheel on the car without ill effects as well (again so long as it too is balanced). Several American cars of old were balanced externally...these are cars that cannot have pullies merely bolted on, nor can you do lightweight flywheels as a bolt on bolt (typicall). The Nissan VQ is not such a motor however
Old Sep 30, 2005 | 12:59 PM
  #39
spacemn_spiff
Then I would like to know why does VQ have the so called 'Heavy Flywheel'.
If what you say is true, eliminate the flywheel altogether.
Old Sep 30, 2005 | 01:59 PM
  #40
Nano's Avatar
Nano
double mass heavy *** flywheel was for comfort only. (should see the flywheels on some higher end sports cars...)
flywheel is what keeps the angular momentum going... they simply store kinetic energy. Without a flywheel a car would be pretty much undriveable. (potter wheel analogy)
