300hp or 287hp
Old Oct 3, 2005 | 12:18 AM
Gandalf123's Avatar
Gandalf123
Default 300hp or 287hp
does anyone know which z is faster. the 2006 have standard 300hp and 260 ft lbs of torque, whereas the years b4 are 287hp and 274ft lbs of torque. now then..... which one is faster??? (0-60, quarter-mile, etc...)
Old Oct 3, 2005 | 02:26 AM
D350Z10's Avatar
D350Z10
the 287 with 274 tq is faster, remember off the line TQ is better, get the 2004 models or i dont know what the have for 06. I got the stock 04 to run 13.77, and 0-60 was 5.3-5.4.
Old Oct 3, 2005 | 02:52 AM
alininger2001's Avatar
alininger2001
The 06 is heavy!
Old Oct 3, 2005 | 03:36 AM
Diesel350's Avatar
Diesel350
Ya the 06 is heavier too.
Old Oct 3, 2005 | 06:06 AM
thawk408's Avatar
thawk408
The 260tq is way underrated by Nissan. I dynoed stock and put down 235rwtq. If you take into account 15% drivetrain loss, 235/.85 = 276tq. And that is dumb to say that car A is faster then car B just becuase it is rated at 14 more peak lbs of torque.
Also, to the original poster. This topic has been discussed many times. I suggest that you do a search.
Old Oct 3, 2005 | 06:09 AM
D350Z10's Avatar
D350Z10
Well i have facts, because we have raced stock 04 vs the 05 35th, and the 04's won... weird 14ft lbs TQ IS A BIG DIFFERENCE! plus weight difference.
Old Oct 3, 2005 | 07:15 AM
thawk408's Avatar
thawk408
That is odd. I have a stock dyno of my car and a stock 03, and my car actually made more peak torque and horsepower. I know that every car is different, but I am just going on facts. I still have a hard time believeing stock for stock the 04 won. And how much more does the 35th weigh...like 20 pounds?
Old Oct 3, 2005 | 08:00 AM
Nano's Avatar
Nano
if you have more torque than a 03-04... that would mean you have a LOT more than 300hp (something like 320 bone stock). Either you have a freak strong car, or that particular 03 was a freak weak car. There is no way nissan would underrate this engine 20hp and there is no way it produces 320hp stock. We had a 35th dyno and the torque was particularly weak... I've seen couple of 35th anni at the track and their trap speed in average is the same as 03-04(100-101). You cannot compare you car to another and draw universal conclusions, that is retarded. Not all cars put out the same amount of power from factory, you have weak cars and strong cars... statistically I'm sure the 300hp engine puts out exactly 300hp.
Old Oct 3, 2005 | 08:06 AM
thawk408's Avatar
thawk408
Where the world did you get that I said I have 320hp stock??? Stock I dynoed 255rwhp and 235tq with good 93 octane. With 15% drivetrain loss the 255rwhp comes out to exactly 300hp and the torque comes out being 276. I am not drawing a universal conclusion, as I already stated that I understand that every car is different.
Old Oct 3, 2005 | 08:10 AM
Nano's Avatar
Nano
Where the world did you get that I said I have 320hp stock??? Stock I dynoed 255rwhp and 235tq with good 93 octane. With 15% drivetrain loss the 255rwhp comes out to exactly 300hp and the torque comes out being 276. I am not drawning a universal conclusion, as I already stated that I understand that every car is different.
you implied it.... genius
power is torque * rpm (for simplicity)
if you have same torque as a 287hp engine @ 4800 - 6400 rpm.... it means either you have WAY more than 300hp or the 287hp engine as WAY less than 287hp.
Old Oct 3, 2005 | 08:17 AM
thawk408's Avatar
thawk408
if you have same torque as a 287hp engine @ 6400 rpm.... it means either you have more than 300hp or the 287hp engine as less than 287hp.
I am sorry, but I never "implied" anything. I have a dyno sheet that compares the two, so I was going on what I have seen. Maybe the 03 was a weaker motor then the norm. I will try to find a stronger one to compare to. All the dyno sheets are in the link in the sig under the folder 350z if you want to check them out.
Old Oct 3, 2005 | 08:36 AM
Nano's Avatar
Nano
I've seen them several times...
the 03 seems a bit low, and your car puts out a ****load of torque over what it's rated.
it's hard to say as a curious point is at what RPM each engine peaks at torque and hp. Power, it seems the 03 peaks bellow 6200rpm, which is odd. While yours is obfuscated so can't really tell, but seems to peak above 6500rpm which is odd again.
Anyway... from what I have seen in general, both engines are so close it's hard to tell which is which. Remember that dyno takes power at the wheel... so there is even more error from one car to another(even same model). Dyno is good only to compare your car to your car... and even there it's not 100% accurate. I've seen some pretty freaky things...
I really hate dynos(nothing personal). They are just too often used in the wrong way and create fuss over nothing. You don't race cars on a dyno.
Old Oct 3, 2005 | 09:05 AM
thawk408's Avatar
thawk408
I really hate dynos(nothing personal). They are just too often used in the wrong way and create fuss over nothing. You don't race cars on a dyno. And just look at the amount of freak dynos manufacturers/tuners use to promote their stuff.
I understand what you are saying and I do agree. I do not have a perfect comparison, but I do think it is pretty good considering that they were done on the same dyno and both were stock. I am going to try and find a stronger 03-04 for better comparison and then have my dyno guy resend me my file so that gap will not be there. I just use the dyno sheets to try and inform people about the 300hp motors HP and TQ curves.
Old Oct 3, 2005 | 09:13 AM
Nano's Avatar
Nano
when I baselined my car we did 4 runs.
1st - 240
2nd - 241
after the 2nd run my cellphone started ringing in the car. So I went in and picked up my cellphone to get the call. Once I got back... results where...
3rd - 245
4th -244
Now, you have to be carefull with the conclusions you draw
driving without cellphone is not 4rwhp
go to dragstrip couple of times in summer and put in 15-30 runs (over a couple of weeks). Compare you MPH to other cars there... best real-life result you can have.
Old Oct 3, 2005 | 09:15 AM
gatti-man's Avatar
gatti-man
300 or 287 paper or plastic. I will take choice C less weight please
Old Oct 3, 2005 | 09:33 AM
D350Z10's Avatar
D350Z10
Wow what dyno did you use, those are some high numbers.
Old Oct 3, 2005 | 11:47 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Best driver would win the race. Neither model has more hp or tq than the other one to say for sure who would win 9/10. Thehawk's 05' dyno is particularly strong, I havent seen any other 05' track or 35th anniversary even come close, they seem to be mid 240's whp average, I did 239whp stock in an 03'.....
I havent seen any 300hp Z's trapping any higher than the 287 ones, until I see a handful of guys trap 104mph( cuz many in regular Z's are 103.XX stock) or over Ill say they are even.
Oh BTW if any 300hp Z's in MD are reading this and would like to race a slow 03' let me know, I dont care what mods you have as long as your NA
Old Oct 3, 2005 | 12:46 PM
thawk408's Avatar
thawk408
Hey alberto, are you close to AAM? I might go there around christmas to get a tune. We could run eachother and I'll let you drive my car.
I think Jason from performance nissan dynoed around 250rwhp, but he was running on crappy CA gas.
Old Oct 3, 2005 | 12:49 PM
thawk408's Avatar
thawk408
I was on a dynojet. Same dyno shop that Crawford Z uses.
Also, are you using the Crawford Headers on the Turbonetics kit?
Old Oct 3, 2005 | 01:37 PM
D350Z10's Avatar
D350Z10
YES Sirrrr.. VERY tight fit, haven't had any rubbing. I heat rapped the headers and put padding on downpipe around the headers
