Nismo Clutch and flywheel
Old Oct 6, 2005 | 07:57 AM
adrenilan's Avatar
adrenilan
Default Nismo Clutch and flywheel
Will the nismo clutch and flywheel hold up when i get a turbo. And does anyone know if it will be safe to autocross with them. Im worried I may have to get another clutch when i get F/i but i hope the nismo will hold up.
Old Oct 7, 2005 | 06:54 AM
adrenilan's Avatar
adrenilan
please respond i need help
Old Oct 7, 2005 | 07:18 AM
1FlyZ's Avatar
1FlyZ
It all depends on how much boost you run/ what kind of turbo. . . Let say you get a regular turbo running at 7 PSI thats going to be more efficient then a twin turbo pushing the same PSI. It will hold. thats not a question. the question is for how long. Thats where the type of turbo comes into play. Me personally when i get the TT i am not going to go with Nismo.
Old Oct 7, 2005 | 11:41 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
yes... it will hold up to what you can do on a stock motor...
Old Oct 7, 2005 | 11:48 AM
Phatmitzu's Avatar
Phatmitzu
Yup.
If I remembered correctly, Nismos will hold up to 400WHP more or less. Which is about as much hp you want to run with a stock block...safely.
Old Oct 8, 2005 | 07:24 AM
KENZ350's Avatar
KENZ350
Default 350Z (stock) Clutch Raddle
The clutch on my 350Z raddles when the motor is idling with the shifter in neutral. If I push in the clutch peddle the noise stops. From a standing stop the clutch has never engaged smoothly. I assumed that all of this was a result of factory spec heavy duty components use in the assemblies.
Now I think it's just design defect. What do you think?
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
