clutch question
Old Nov 10, 2005 | 08:29 PM
str8cwestin's Avatar
str8cwestin
Default clutch question
how often have u z and g guys had to replace your clutch in the sense of mileage??
Old Nov 10, 2005 | 10:55 PM
drsifu's Avatar
drsifu
huh?
it all depends on your driving habits. i know guys who had it replaced at 10k miles.
I have 25k on my stock clutch. Even this being my first MT car, there was still plenty of life after I had it replaced for my turbo install.
so...you are not going to find any useful info to your question
Old Nov 10, 2005 | 11:20 PM
bmxox's Avatar
bmxox
yea its totally on driving style. my last car went to 60k on stock clutch and my friend now drives it, hes up to like 80k on the same clutch. theres no solid answer to your question.
Old Nov 10, 2005 | 11:21 PM
Z_Driver's Avatar
Z_Driver
Master
I had 177K on my 300ZX Turbo with a stock Nissan clutch. Depends on how you drive and how much HP you have in front of that stock clutch.
On my '98 Firebird the stock clutch came out after 10K and a few runs down the track.
That stock clutch just wouldn't handle the HP. However, GM wanted to make a car with a clutch that was easy on the leg for 80% of the owners. I bought an after market clutch that was supposed to have the same petal press but better clamping pressure. It is a little heavier than stock. However, I wouldn't expect the avg Joe to like it on a daily commute car. It's perfect for me... but, that not for everyone. That performance clutch has handled anything I can throw it it. I twisted a transmission input shaft and the clutch is like new. That is something you need to consider if you upgrade as well. Trannies are more expensive than clutches.
If you have a stock Z, drive your Z like a normal car, don't dump the clutch every week; It should last over 100K as long as you know how to shift properly. If you are dumping the clutch at every chance you get you'll be buying a clutch every year or so. That is my experience.
Hope this give some insight into the clutch wear situations.
Old Nov 11, 2005 | 06:41 AM
34,000 miles and a regular weekend drag racer. The OEM clutch works fine.
Old Nov 11, 2005 | 06:47 AM
Vamos_Rafael's Avatar
Vamos_Rafael
i smell my clutch every time i drive spiritedly...
and i drive spiritedly all the time
Old Nov 11, 2005 | 10:26 AM
MeetJoeAsian's Avatar
MeetJoeAsian
what's the cost of you guys replacing your clutch?
Old Nov 11, 2005 | 10:38 AM
LIdrew's Avatar
LIdrew
I smell clutch all the time when driving hard, however I have never replaced a stock clutch on any of my cars. Lucky?? I probably just doomed myself to a new clutch. My 88 integra went 130K miles on original clutch. My current beater 95 corolla 133k miles stock clutch. Just don't ride it and you will be fine. Someone on here once said " pretend clutch pedal is burning hot and you're barefoot" something like that. I think it's good advice. Shift quick and get your foot of clutch pedal.
I wouldn't replace my Zs stock clutch with another stocker. Probably cheaper to go with an after market light weight that will hold mre HP for future mods. ACT or JWT rated to 500 HP I believe.
Old Nov 11, 2005 | 10:40 AM
Vamos_Rafael
I want carbon ceramic for my next clutch
Old Nov 11, 2005 | 10:53 AM
superblackZ720's Avatar
superblackZ720
A clutch isn't exactly a part you change often like belts of filters they last as long as the driver allows them too, by that i mean driving habits.
Old Nov 11, 2005 | 01:00 PM
isugoo's Avatar
isugoo
I replaced my clutch this week.
Labor was 505. One day job. I had 40k miles. No race, I have slipping clutch habit somewhat. I installed Nismo clutch/flywheel. Couldn't be happier. Its great compare to stock.
Old Nov 11, 2005 | 01:28 PM
toretto26's Avatar
toretto26
i let my cousin drive my car he tried to do a burnout and when he shifted into second and released the clutch it seemed that he didnt release it and the car just reved up and the wheels didnt move... wierd.
Old Nov 11, 2005 | 02:27 PM
bmxox's Avatar
bmxox
Labor was 505.
Damn, I will be laying on my back in my driveway doing mine.
Old Nov 11, 2005 | 05:46 PM
dragon11689's Avatar
dragon11689
When I shift a lil quick sometimes I hear the car kind of making a thump noise right b4 i press the gas. Is this normal? Or should I be pressing the gas sooner, I'd hate to grind it by doing it sooner.
Old Nov 11, 2005 | 06:56 PM
jakesford's Avatar
jakesford
the stock clutch likes to make a lot of noises... I've got an 03' w 47K miles makes noise when engaging and at idle in neutral, seems to be kinda common, but no slipping still feels really strong...
a friend of mine's dad has an early 90's caviler with the stock clutch and 250K miles ... His clutch cable snapped on hime though a while back...
Old Nov 11, 2005 | 09:51 PM
ChunKy350Z's Avatar
ChunKy350Z
well it depends on ur driving style .. i still got my OEM clutch with stock Z .. but am replacing it for a JWT cluch/flywheel combo for more clamping force ...
Old Nov 13, 2005 | 10:28 AM
dragon11689
Sounds good. I'm happy that I'm not the only one hearing things. I might replace also in the future but what do u guys think of ACT clutches. I heard some pretty good things about them.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
