Clutch and Flywheel Question
I have a JWT Clutch and Flywheel. I need to replace the clutch because I glazed it and never broke it in properly. I want to go with a different clutch this time around and a lot of people are recommending I use the ACT HDSS.
Q1. Will the ACT bolt on to the JWT Flywheel?
Q2. Are there any other clutches that you would recommend? I have the APS ST making about 400whp and over 400ft/tq.
Note: I do not want to replace the flywheel I just want to replace the clutch and pressure plate. So if you offer a suggestion on a new clutch please make sure it will bolt to a JWT Flywheel.
Thanks Everyone,
Dan
Edit- Links or where to purchase a new clutch for a good deal would be appreciated
Thanks Everyone,
Dan
I have the RPS setup and love that combo...I have both their flywheel and 6 puck clutch...their clutch setup will work with your flywheel...the rps comes with throwout bearing, pressure plate, and clutch
