Clutch Question
Old Dec 14, 2005 | 02:48 PM
Lexquiles's Avatar
Lexquiles
Default Clutch Question
Hey guys, I did the adjustment on my clutch to have my clutch release lower. I love the way it feels now, it is so much easier now to drive it. Here is my question, I did my adjustment, how do I know if I made it too low, I already can't use the cruse control which I don't mind at all, I don't think I've ever used it. I just want to make sure I'm not going to fry the clutch cause it has been adjusted too low. Thanks.
Old Dec 14, 2005 | 02:57 PM
gersteinp's Avatar
gersteinp
It's too low if, with the pedal down, you grind gears trying to shift. Clutch should start engaging with your foot about 1" or so off the floor. It's very easy to readjust the cruise control. You'll see the switch in front of the clutch hinge. Button should be fully pressed in with the clutch out (not depressed).
Old Dec 14, 2005 | 03:09 PM
Lexquiles's Avatar
Lexquiles
Nope no grinding what so ever, It is a dream to drive now. Thank you for the info.
sherm
Apr 11, 2020 05:21 PM
issyz
Jul 2, 2017 03:04 PM
