removing radiator hoses from throttle body?
Old Dec 30, 2005 | 08:02 AM
03_Track_Z's Avatar
03_Track_Z
Default removing radiator hoses from throttle body?
I'd like to take care of this today, but I don't know exactly what to do, if I unplug the hose will fluid spray everywhere? Where do I plug it back into? Can someone just give me a step by step walkthrough please?
Old Dec 30, 2005 | 08:25 AM
Monsta's Avatar
Monsta
WHen I took my throttle body off, the fluid did not spray. It will dribble out for a lil though. If it gets steady, prop the hoses up and they should stop.
Old Dec 30, 2005 | 09:27 AM
DavesZ#3's Avatar
DavesZ#3
Car must be cool. Open the radiator cap to release any pressure then close it again. When you pull the hoses, a little may spill. Use lots of towels to catch any drips and as Monsta pointed out, keep them "up" and you'll have no problem.
Old Dec 30, 2005 | 09:28 AM
Mike Wazowski's Avatar
Mike Wazowski
if you have a small dog to clean up any mess that is even better.
Old Dec 30, 2005 | 10:07 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You are awful...LOL...just wait till you meet me Rott.
Use use a brass barbed fitting to bridge the two hoses.
Old Dec 30, 2005 | 10:08 AM
Mike Wazowski
Sharif, your Rott likes coolant? I will bring some down and a chew toy
Old Dec 30, 2005 | 10:22 AM
03_Track_Z's Avatar
03_Track_Z
shariff, could i just completely remove one hose and stick the other one where the first one goes? instead of connecting the two?
Old Dec 30, 2005 | 10:30 AM
EM-EFER's Avatar
EM-EFER
With the car cooled you wont have a problem.
Old Dec 30, 2005 | 11:28 AM
Sharif@Forged
Forged Performance
Yes, remove the two hoses from the throttle body, and bridge them with a barbed brass fitting.
Old Dec 30, 2005 | 03:31 PM
Julian@MRC's Avatar
Julian@MRC
We clamp them..If the car is warm and it sprays coolant all over it is not only a stink mess, but it can cause an air pocket in your coolant system which will cause the Temps to spike..The coolant system is a PITA to bleed..
WWW.RACEMRC.COM
For your 350z/G35 performance needs.
Authorized Turbo XS UTEC distributors
Authorized Dyno Dynamics load based tunning facility comming 3/06!!
Authorizes Greddy Dealer/Installer
Authorized GTSPEC dealer
Authorized Unlimited Tuning Revolution dealer
Authorized Speed Force Racing Dealer
Email: Sales@racemrc.com
AIM: salesmrc
Phone: 732-251-8200
Mobile: 732-558-4560
MRC MOTORSPORTS
116 Main St.
Spotswood NJ 08884
Old Dec 30, 2005 | 03:34 PM
plumpzz's Avatar
plumpzz
Damn i forgot to clamp it...theres just a barbed brass connector on them..
Old Dec 30, 2005 | 04:11 PM
Sharif@Forged
Forged Performance
Sorry, I made the assumption you knew to use the stock clamps to secure it to the brass fitting. Definately clamp it as well...sorry for not mentioning that, as I wouldnt trust the barb alone, to secure the hose, and prevent leaks.
Old Dec 30, 2005 | 04:38 PM
plumpzz's Avatar
plumpzz
After taking off the stock clamps, they became pretty loose. I was able to open it with my fingers which was a pita when first taking them off. I'm going to see what I can do. Dont feel like taking off the air tube to check it out
Old Jan 2, 2006 | 09:28 AM
ChicagoX's Avatar
ChicagoX
I clamped the hoses to avoid air bubbles.
Here's a DIY, including pics: http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
Old Jan 2, 2006 | 10:06 AM
overZealous1's Avatar
overZealous1
they must be reconnected to eachother. removing the airtube will save lots of swearing though. if you trace where the lines go, you can just eliminate the rear coolant hose from the throttle body, and with some creative bending, hook the front coolant hose to the steel line. you will see what io am talking about if you trace where the lines go.
Old Jan 2, 2006 | 10:55 AM
ChicagoX's Avatar
ChicagoX
FWIW, the coolant is circulated through the upper plenum, not the throttle body.
Old Jan 4, 2006 | 05:50 AM
PoWeRtRiP's Avatar
PoWeRtRiP
congratulations. u just picked up a few hp for 2$ in fittings. best free mod out there!
Old Jan 11, 2006 | 12:59 PM
rbfd's Avatar
rbfd
So wait, does the motordyne ISO thermal kit already fix this? cuz ive got that? Had it installed by 350EVO though so im not sure if this mod has already been done/addressed?
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 30, 2015 10:54 AM
