Trans. Fluid
Old Jan 25, 2006 | 08:51 PM
arejohn's Avatar
arejohn
Mix 50-50. Please elaborate.
Old Jan 26, 2006 | 10:48 PM
Aggro_Al's Avatar
Aggro_Al
Originally Posted by JoneZZZ
https://my350z.com/forum/engine-and-drivetrain/161182-5at-transmission-basics-info.html
"Nissan-Infiniti TSB (Technical Service Bulletin) addressing Nissan Matic-J fluid, the ATF flavor that's spec-ed for the G35/350Z.......
SERVICE INFORMATION
If the automatic transmission in the new Q45 (F50) or G35 (V35) requires service, a new type of
automatic transmission fluid MUST be used. The new fluid is Nissan Matic-J.
The New Nissan Matic-J
• Only Nissan Matic-J automatic transmission fluid (P/N 999MP-MTJ00P) is specially formulated to meet the
exacting requirements of Infiniti's new 5-speed automatic transmission (RE5R05A).
• The RE5R05A transmission contains new internal components that require the use of
Nissan Matic-J only!
CAUTION:
• Usage of Nissan Matic-D or any other automatic transmission fluid in the RE5R05A 5-speed automatic
transmission will cause deterioration in driveability and transmission durability.
• Do NOT use any other fluid for the RE5R05A 5-speed automatic transmission, only use Nissan Matic-J.
• Use of any other fluid may result in damage to the RE5R05A 5-speed automatic transmission, which will
not be covered by the INFINITI warranty......"
+1
Also, the AT Fluid is Fill-for-Life. You don't need to replace it under normal conditions. The maintenance schedule only says that you only need to have the AT Fluid inspected every 30K and replaced if necessary.
Old Jan 27, 2006 | 08:04 AM
ReavTek's Avatar
ReavTek
Alright does Nissan have any such fluid that MUST be used for MT 6pd Zs or we void the warranty? I ask because I used Redline MT-90 awhile back and want to make sure my warranty isn't void.
Old Jan 27, 2006 | 08:41 AM
Z'd's Avatar
Z'd
It just has to meet API service GL-4.
According to the Redline web site, you're good.
Old Jan 27, 2006 | 10:27 AM
zzz350's Avatar
zzz350
I guess you are assuming that Nissan actually backs up it's warranty, as opposed to worming their way out of it. Generally all manufacturer warranties are just paper.
Old Feb 27, 2006 | 03:13 PM
GReddySetGO's Avatar
GReddySetGO
For those of you using Redline mix of MTL/MT90. Are you using this same mixture in both your tranny and diff?
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Ace2347
Sep 22, 2015 03:12 AM
MyZ2Slow
Mid-Atlantic Marketplace
Sep 9, 2015 10:17 PM
