UR Crank Pulley Squeaks...help!
Old Jan 14, 2006 | 07:09 PM
BootieMAN's Avatar
BootieMAN
Default UR Crank Pulley Squeaks...help!
My belts are making so much noise people think I have a SC! I've tighten my belts quite a bit and it's still making a lot of noise. I've heard they can squeak if they are too tight as well. Any truth to that? Anybody has any advice please chime in. I like the idea of having a SC, but not just the sound
Old Jan 14, 2006 | 08:47 PM
steela2110's Avatar
steela2110
When I had my pullies installed, the reason for the squeaking noise was because the belts were not tight enough... If you tightened them and it is still happening then I would review your install and make sure everything was done properly.
Old Jan 14, 2006 | 08:48 PM
Mike Wazowski's Avatar
Mike Wazowski
check the belt sizes!
Old Jan 14, 2006 | 10:18 PM
FlorendoCruz's Avatar
FlorendoCruz
usually, when ur belts squeak, ur belts are loose. Remember, tighten the bolt little by little cause to much tightening can cause damage to the car.
if that doesnt work, get a smaller belt.
Old Jan 15, 2006 | 06:46 AM
dgz32's Avatar
dgz32
Check the tension, not sure of the exact amount, but it's probably somewhere between 1/4 - 1/2 inch deflection. Any more than that and you are bound to get noise. Perhaps someone can chime in with the correct amount...?
|dg
Old Jan 15, 2006 | 10:39 AM
D350Z10's Avatar
D350Z10
tighten your belt thats all it is... cold weather does the job...
Old Jan 15, 2006 | 08:55 PM
Dubai's Avatar
Dubai
Get the right belts size
Gates Micro-V K060445 ( 21mm x 1150mm O.C.) and Gates Micro-V K040353 ( 14mm x 910mm O.C.)
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
