Dyno results from tuning with Technosquare and Motordyne!
Old Jan 25, 2006 | 01:39 PM
  #41
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by lukesnyder
Yah I just read through everything and looked it up .. Dynojet 2000 isnt load based. The SAE corrected shows up on all dynopaks dyno sheets.
Whats your elevation around?
Close to sea level I am assuming since I am in so cal
Old Jan 25, 2006 | 01:40 PM
  #42
Rickdogg's Avatar
Rickdogg
Out of hiatus
Originally Posted by sfarrah
Looks like his original dyno shows the A/F as pig rich.
Rickdogg, what is your complete list of mods? Nice numbers btw.
http://www.jtuned.com/content/templa...d=336&zoneid=2
Old Jan 26, 2006 | 12:33 PM
  #43
sfarrah's Avatar
sfarrah
Wow, that's pretty hardcore. I would have at least left the headlights!!
What does it weigh in at? What are your alignment specs if you don't mind me asking? Do you run the 19's on the track or do you have a different track wheel/tire combo?
Old Jan 26, 2006 | 12:53 PM
  #44
Rickdogg's Avatar
Rickdogg
Out of hiatus
The car is hovering around 2800 lbs at the moment with the roll bar in place and cast 17" race wheels. I run -3 camber up front and -2.5 rear with I believe 1/16" toe in. I run 17" 5zigen FNO1RC's with Yokohama Advan A032R Soft R Compounds at the track
Old Jan 26, 2006 | 01:04 PM
  #45
sfarrah's Avatar
sfarrah
Thanks for the info. I assume you have it corner balanced. If so, what kind of an improvement did you see from that? I will be installing a set of prototype SPL coilovers and rear camber arms in a few weeks and wanted to see if it's worth the extra expense to corner balance when I get it aligned.
Looks like we have the same track wheels. I have 17x9 fn's with 275/40 hoosiers sitting in the garage-combo weighs in at 42 lbs. I won't run them until I get some camber up front though. Until then i'll stick to my street tires.
My apologies for taking this thread off topic.
Old Jan 26, 2006 | 01:15 PM
  #46
Rickdogg's Avatar
Rickdogg
Out of hiatus
Corner balancing made a world of a difference. With the sway bars upgraded the car was planted to ground!
Old Jan 26, 2006 | 01:56 PM
  #47
rednezz's Avatar
rednezz
+1 on corner balancing. Rickdogg, with all the camber you run you should try the Yokohama A005's for the track. They just love alot of negative camber and they are night and day difference in grip from DOT competition tires. I gurantee you won't wipe the grin off your face for awhile.
Old Jan 26, 2006 | 02:44 PM
  #48
Rickdogg's Avatar
Rickdogg
Out of hiatus
I'll look into that thanks I'm working on a sponsorship with them right now, so fingers crossed
Old Jan 26, 2006 | 08:10 PM
  #49
rolling's Avatar
rolling
where do you guys get all the $$$ to do these dyno runs sooo often?
in my city ye lucky if you oly get 3 runs for about $50 special "dyno day" it really sux here
Old Jan 27, 2006 | 12:28 AM
  #50
Rickdogg's Avatar
Rickdogg
Out of hiatus
I paid for 2 runs which costed me $90. I sell my body on the side
Old Jan 27, 2006 | 04:57 PM
  #51
rolling's Avatar
rolling
man that allota bux if your trying to tune someting if you need many runs..
i guess its O-K if you only need it once to see where yer at for refrence but you guys.. geeesh!! LOL well more dynopower to ya!
Old Jan 27, 2006 | 04:59 PM
  #52
SinCity350Z's Avatar
SinCity350Z
Track Whore
Man thats expensive. I have a shop around the corner from my work that charges $15/pull. $20 w/air fuel.
Old Jan 27, 2006 | 05:17 PM
  #53
Rickdogg's Avatar
Rickdogg
Out of hiatus
Really a pull as in one single run or? We typically get 3 dyno runs with a/f for $45 on a dyno day. So I had a total of 6 runs for $90
Old Jan 27, 2006 | 05:38 PM
  #54
SinCity350Z
Track Whore
Yeah ok, thats better. We get 1 single pull for $15. Thats their everyday price though. On dyno days they usually knock it down to $10/pull or so.
Old Jan 28, 2006 | 05:58 AM
  #55
raptorbh12's Avatar
raptorbh12
weird, i just got my car dynoed at extreme motorsports in Odenton MD, and i made 244 max power at 4800 rpms and a max torque of 230... either somethings very wrong with my car or extreme messed up my dyno.
Old Jan 28, 2006 | 10:30 AM
  #56
Rickdogg's Avatar
Rickdogg
Out of hiatus
What dyno is it on? Also, do you have a Dyno sheet?
Old Jan 28, 2006 | 11:52 AM
  #57
showstoppertk's Avatar
showstoppertk
crappy, we pay about $90 for 3 pulls w/ AF in Hawaii. I haven't heard of them doing any dyno days or single pulls.
Old Jan 30, 2006 | 07:05 AM
  #58
sfarrah's Avatar
sfarrah
Seems low for a car that can run a 12.7. Mustang dyno perhaps? Have you dynoed there before?
Old Feb 2, 2006 | 01:29 AM
  #59
reyes5912's Avatar
reyes5912
Hey Rick let me know when you go dyno again. Also I am realy interested in that new coil system too. I want one.
Old Sep 17, 2007 | 02:43 PM
  #60
9kFever's Avatar
9kFever
A member on here "Sakred" has dynoed 295+ on this same dyno with a lot less mods. He had stock exhaust, tps, pulleys, spacer, headers, and pop charger.
