nismo flywheel
Old Mar 20, 2006 | 05:57 AM
ryan350zpower's Avatar
ryan350zpower
Default nismo flywheel
hey guys, anyone have the nismo flywheel installed to either a after market clutch or OEM clutch???? i want to know how the chatter is at idle with it becaus eit only reduces the weigfht by 8lbs. ALso, how does it feel while driving?
Old Mar 21, 2006 | 09:15 AM
ZPirate's Avatar
ZPirate
I have the Nismo flywheel and clutch. I went with the Nismo set up over the JWT setup because I thought it would produce less chatter. With my set up there is no chatter at idle. It does make some chatter below 2300 rpms when you let the engine lag. Keeping the rpms up eliminates the chatter. The clutch grabs harder than the stock and the flywheel spins up slightly faster than stock. Overall its a good mod.
If I had to do it all over again I might go with the JWT flywheel (because it is lighter than the Nismo) and the Nismo clutch. Although I hear the JWT flywheel produces more chatter. The Nismo clutch is slightly lighter than the JWT clutch.
Old Mar 21, 2006 | 09:24 AM
gringott's Avatar
gringott
What he said.
Old Mar 21, 2006 | 12:00 PM
ryan350zpower
thank you so much for in the input
Old Mar 26, 2006 | 06:56 AM
Armitage's Avatar
Armitage
Nismo is still dual-mass like the stock flywheel I believe, so it produces less chatter. JWT, Tilton, etc. are single mass and produce a lot more chatter.
Personally, I heard the JWT in person and the chatter did not bother me at all.
Old Mar 26, 2006 | 12:14 PM
gringott's Avatar
gringott
The only noise from the NISMO is if you "lug" it around 2K RPMs. At idle, etc, silent.
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
