Underdrive Pulleys?
Old Jun 9, 2006 | 02:32 PM
MikeKondilis's Avatar
MikeKondilis
Default Underdrive Pulleys?
Are underdrive pulleys good for our engine or are there horrible? Is the unorthodox Racing Inderdrive Pulley worth itt? Did you feel any gains? and what webiste is good to order from? Yes I indeed used the search button and never read nothing about if they are good for ur car or anything else so fill me in with some info...Whoever has this ^ fill me in if to buy it or not
Old Jun 9, 2006 | 02:42 PM
jeff0181's Avatar
jeff0181
I just got mine installed today and i can feel a slight difference. As for are they good for your car or not I have no idea. I ordered mine off ebay.
Old Jun 9, 2006 | 03:47 PM
MikeKondilis
anybody else?
Old Jun 9, 2006 | 03:58 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Honestly...this has been debated for years without a definitive answer so like many other posts similar to yours, you'll just end up having yet another debate.
Old Jun 9, 2006 | 07:11 PM
MikeKondilis
^ I'll guess im getting them lol
Old Jun 9, 2006 | 07:14 PM
cleanandquick06's Avatar
cleanandquick06
haha, well i installed them today with test pipes and i felt alot better throttle response. they are awesome, and look great. the only thing really different is that the alternator works harder so it burns out quicker so i hear.
Old Jun 9, 2006 | 07:36 PM
350Zteve's Avatar
350Zteve
I haven't seen a post yet about a Z having any damage related to the pulley. There are many members here running them for years without problems (myself included)
Old Jun 9, 2006 | 07:39 PM
Mike Wazowski's Avatar
Mike Wazowski
+1 love my UR Pulley had 30,000 miles on the stock motor and 7,000 miles on my built with no problems.
Old Jun 10, 2006 | 12:41 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I have the UR Crank pulley and suggest it. I don't feel there is a need for the pulley "ket/set." With the crank pulley it will smooth out your idle and RPM band. I say go for it.
Old Jun 11, 2006 | 02:31 AM
Dubai's Avatar
Dubai
I've been running the UR crank pulley for over a year now, and no problems whatsoever. the most thing you'll feel is better throttle response.
Old Jun 11, 2006 | 03:42 AM
wilric44's Avatar
wilric44
Well with all that said, well it work with the Stillen SC. I am curious have not gotten a concrete answer on this as of yet.
Old Jun 11, 2006 | 06:46 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I would say no cause its a smaller pulley and the kit is built around the OEM size. I would contact Stillen to get an "offical" answer though.
Old Jun 13, 2006 | 04:14 AM
omernazeer84's Avatar
omernazeer84
all of you who approve of the Pulleys, ......are you running the SS kit with all the pulleys or just the crank?
from what ive been reading it seems best to leave the others and go only with the crank?
Old Jun 13, 2006 | 05:14 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Just the crank. Reason for me incase I decide to add an aftermarket audio system.
Old Jun 13, 2006 | 06:44 AM
SGP-BFH's Avatar
SGP-BFH
When you go with an underdrive pulley, they are smaller and require a shorter belt to pull up the slack. So Im sure it could be made to work if the belt were sized properly.
Old Jun 13, 2006 | 08:38 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
^^^ Good point make sure to order the Gates belts!!! These are the only belt I've heard not giving any problems with a pulley set-up.
Old Jun 13, 2006 | 09:27 AM
shanecrosby's Avatar
shanecrosby
My car is at Stillen right now getting the Pulley set put on. I'll repost tomorrow with my feelings on it.
Old Jun 13, 2006 | 09:32 AM
superchargedg's Avatar
superchargedg
Damn Noobs
no it will not work with a stillen,thee ss box which is locked is programed with the stock pulley in mind.if you put a smaller pulley on it the fmu will not be reading what it is supposed to and will go very lean(thats from sam at stillen)and then you go boom.
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
i wouldnt put a underdrive pulley on if you intend to have a audio system, i would just put on a lightend crank pulley like cnr(crazy nut racing) sells which is oem size so it takes the factory belt, but is like 5+ lbs lighter to achieve the same results as the underdrives.
Old Jun 13, 2006 | 03:22 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the underdriving is so mild, that unless you are trying to drive a mega amp, without a cap, or without an extra battery, it has no plausible affect on how the system charges
I've yet to see a single Z, pulley or not, need a new alternator FWIW
That being said, 2.5 years with my UR pulley....not a single issue
