Who Needs an HKS DLI????
Old Jul 12, 2006 | 08:59 AM
Noah@AAM's Avatar
Noah@AAM
Default Who Needs an HKS DLI????
About the HKS DLI:
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-22)
Dimensions: All Twin Power Units, except for DLI II, are 91mm (L) x 80mm (W) x 34.5mm (H) and weighs Approximately 430g (~15.2oz)
This is a one-week special for all forum members---- $493 Shipped anywhere in the 48
Call and ask for Noah...and you must mention that you are a MY350Z.com member for this price.
gonzalo_300zx
Dec 18, 2015 04:14 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
