What would you do?
Old Jul 20, 2006 | 01:10 PM
dingobiatch's Avatar
dingobiatch
Default What would you do?
So, I won a $500 raffle at *********.com, I'm trying to decide what I want to do.
My current mods are in my sig.
The things I had on my mind are: Kinetix HFC's, UR Crank Pulley, MREV+ and 5/16 spacer (I already purchased the MREV+ though), and 3.9 final drive.
I have to choose from the vendors on the *********.com site, so I found:
Kinetix HFC's
UR Crank Pulley
5/16 Spacer
Now, I can't find the 3.9 final drive on any of the vendor's sites, so I guess thats out of the question.
But my big question is.. well.. what should I do? I'm trying to figure out what would be most affordable in the end - what should I buy used elsewhere, and what should I get with this $500 credit? Also, is this a good future-mod list, or should I forget about something..
Old Jul 21, 2006 | 05:21 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
out of those 3?
pulley and spacer..
Old Jul 21, 2006 | 06:42 AM
mikead_99's Avatar
mikead_99
I'm assuming you are mt, so revup. If that's the case, you definately want the spacer with your plenum. Between the other two I could go either way, but would probably go with the hfc's just to finish off your exhaust path, unless headers are in your plans later. You'll ended up spending a little of your own $ that route, but it wouldn't be much.
edit to add: congrats on the raffle win btw.
