Squeaky Pulley Belt
Old Jul 28, 2006 | 02:52 PM
intoxicatedpete's Avatar
intoxicatedpete
Default Squeaky Pulley Belt
I just put in a KJR pulley and the belts are squeaky. They only squeak wen i take off in 1st gear from around 900-1100 rpm. After that there is no squeak. I did a search and found out most ppl got rid of their squeaking by tightening the belts. I tried tightening mine but the squeak is still there. Should i get new belts or try belt conditioner? Thanks.
Old Jul 28, 2006 | 03:44 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they are not tight enough. Do not spray anything on the belts
Old Jul 29, 2006 | 04:22 PM
intoxicatedpete
How much tighter can it be? Should they be tightened to the point that the belts are not twistable?
Old Jul 29, 2006 | 05:52 PM
Cannysage's Avatar
Cannysage
don't crank it too much.. just increase the tension abit. If you're not sure, adjust it a few times til the squeak is gone..
Old Aug 1, 2006 | 11:55 PM
intoxicatedpete
Steve from Corner3 told me that tightening it past factory specs (which is what i need to do to get rid of the squeaking) will put added stress on the bearings (forgot which ones...maybe the accessory pulleys) and cause them to fail. Anyone heard of this problem?
Old Aug 2, 2006 | 03:40 AM
Z1 Performance
Former Sponsor
yes he is right - but there is no way it is tight enough, as that is a stock sized pulley and uses a stock sizes belt. Either you did not tighten it sufficiently (measured by the up and down deflection of the belt as you press down on it - consult the factory service manual for this spec), or your belts are worn and need to be replaced with new ones
Old Aug 2, 2006 | 09:46 AM
intoxicatedpete
I saw the belts during the pulley install and they looked fine. I only have 16000 miles on my car as well so i dont think the belts would be worn yet. Maybe he was being too conservative about the tension? Could it be that the alluminum pulley is too smooth for the belt to get a grip of? That is what Steve thought.
Old Aug 2, 2006 | 09:52 AM
Z1 Performance
Former Sponsor
good be - these cars seem to be really finicky about belt tension. I know Kwame struggled with his for a long time on his 03, but ultimate got it. Just make small changes and you should be ok. At 16k, your stock belts should definitely have been ok
Old Aug 2, 2006 | 10:32 AM
intoxicatedpete
I guess ill have to adjust-and-check in small increments. Thanks a lot of the help Z1.
Old Aug 2, 2006 | 10:40 AM
Z1 Performance
Former Sponsor
start with the simple stuff - measure the amount you can push each belt down at the center between the pullies, then compare that to what the factory says it should be. Adjust as needed. Let us know how you make out
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
