HELP! TPS wire on 350z.
Old Feb 28, 2003 | 08:22 PM
redlineRED350z's Avatar
redlineRED350z
Default HELP! TPS wire on 350z.
To all the guys/gal in this forum, i need some help. The TPS wire on our car ....where is it located and what color is it? I don't see it anywhere. I am installing ZEX dry kit...55 shot. Thaks for the help.
Old Mar 1, 2003 | 10:13 AM
Chebosto's Avatar
Chebosto
you know there are several wires, right? which one do you need?
Old Mar 1, 2003 | 10:26 AM
Chebosto's Avatar
Chebosto
Old Mar 1, 2003 | 12:09 PM
02trex's Avatar
02trex
Default Which is voltage output?
He, and I, need to know which wire is the voltage output for the TPS. The Zex nitrous system uses that wire for activation.
Thanks.
Old Mar 1, 2003 | 12:26 PM
Chebosto's Avatar
Chebosto
Default Re: Which is voltage output?
voltage, eh?
ok. brb
you can AIM me:
chebosto
Thanks.
Old Mar 1, 2003 | 12:31 PM
Chebosto's Avatar
Chebosto
on that picture?
#47 is the power supply to the TPS... at 5V.
but if you need to know when the cat is at WOT, 50 & 69 are the ones you'll.. they are at ~4.6B at WOT when the accelerator pedal is fully depressed.
Old Mar 1, 2003 | 09:28 PM
redlineRED350z
thanks a million. I knew a fellow 350z would help.
Old Mar 2, 2003 | 06:59 AM
redlineRED350z
Now here is a stupid question...but where is that located. Under the hood or inside the car?
Old Mar 2, 2003 | 07:43 AM
walc's Avatar
walc
Default OFF TOPIC
OFF TOPIC:
redlineRED350z,
Hello to all in Gastonia!
I graduated from Belmont ( now South Point ) H.S. in 1967, about 13 years before you were born.
Old Mar 2, 2003 | 08:14 AM
Chebosto's Avatar
Chebosto
uh..
these wires go to where the ECU is.
the ECU is located on the passenger side, you have to remove the paneling near the floor board area, close to the door.
Old Mar 2, 2003 | 10:37 AM
redlineRED350z
What i mean is can i access the #47 wire from the engine bay? And the color of the is white/red? Thanks
Old Mar 2, 2003 | 06:07 PM
Chebosto's Avatar
Chebosto
that i dont know... from tapping into that from the engine bay. i get if you just find the TPS it self, then you can just that into that..
Old Mar 3, 2003 | 11:06 AM
redlineRED350z
Hey CHEBOSTO you have nitrous on your car too right? Does your check engine light go on? Mine go on and stay on! I don't know what is going on. a little help please.
Old Mar 3, 2003 | 11:15 AM
Chebosto's Avatar
Chebosto
No. i do not have Nitrous... dont plan on it... i just tried to help you with the diagrams you requested...
are you sure you're supposed to tap into the power line for the TPS? and not the TPS signal itself???
Old Mar 3, 2003 | 05:38 PM
redlineRED350z
I did call a few places that install the zex kit on a 350z, and they have the same problem. I call Import Hot Rod and Oscar said on Max 350z it does it too. The car run find though.
Old Mar 3, 2003 | 06:07 PM
grebmohr's Avatar
grebmohr
Anytime you tap into in the fuel/induction(electrical) system can cause that symptom. Maybe a voltage goes out of range and causes the light to come on. The throttle is drive by wire so if you got the wrong wire, you stand to write a hell of a check if it goes **** up.
With OBDII, the light can correct itself and turn off. but the car must sucessfully run 3(i think) times without the fault to turn it off. It is slightly more complicated than I just said.
I would hound the manufacturer about the issue if I had the Chk ENG light coming on.
GL
Old Mar 4, 2003 | 05:36 AM
Zaphod 350z's Avatar
Zaphod 350z
The car may run fine as far as your perception or the butt dyno is concerned. But bottom line is this, if the check engine light in on, the car believes there is a problem. If the car thinks something is wrong, it will take steps to correct the problem. When dealing with nitrous oxide, I wouldn't want to play around with it. For instance, if it is an issue with the TPS and a fault code is thrown because of it, the ECU may try to counteract the problem by readapting or adjusting the the throttle positioning plate. If so, then when you depress the pedal WOT, the throttlw plate may not be completely openning. or conversely it may be openning completely when not WOT in which case the MAF values will be all messed up. This is all just hypothetical.
Ditch the electronic control, get yourself a nice pedal switch. I'd be more than happy to send you pics of mine.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
Alexreyes
Sep 30, 2015 11:30 PM
Dymsi
Sep 29, 2015 11:32 AM
