Power steering fluid
Old Sep 11, 2006 | 05:46 PM
SSJVegita's Avatar
SSJVegita
Default Power steering fluid
hey guys i have been searching and no luck......how many qrts to fill up the power steering.....i wanna change it and needed to know how many qrts to buy...thx guys....
Old Sep 12, 2006 | 01:11 PM
tourinz's Avatar
tourinz
Default Take it to the dealer
you don't want to do this at any shop.... the dealer has special equipment to do it... it only costs like 99 bucks....
Old Sep 12, 2006 | 03:36 PM
350Zteve's Avatar
350Zteve
Its VERY easy to do it yourself. You only need about 1 quart (you use regular Dexron III ATF per nissan. About $2 a quart). Get the car in the air and remove the bottom tray. Remove the lower line to the PS cooler and let it pour out. Fill up the resevoir to the top. Start the car for about 5 seconds. Refill the bottle and restart the car. Turn the steering wheel lock to lock about 5 times and top off to the fill line and you're good to go.
Old Sep 12, 2006 | 03:41 PM
Eazzy's Avatar
Eazzy
+ 1 ----As he said --DO NOT USE P/S fluid
Old Sep 12, 2006 | 03:42 PM
Grommit's Avatar
Grommit
Hmm... hope this works because I'm going to do it this weekend!
Old Sep 12, 2006 | 03:50 PM
Eazzy's Avatar
Eazzy
HMMMM --It will ---But its over kill ---simplicity wise- take a turkey baster and empty ur resivoir fill with fluid , start the car ---Turn to Turn a few times ---Repeat --Repeat --Repeat--- Its just a hydraulic pump
Old Sep 12, 2006 | 05:12 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It says "For Canada, Nissan ATF Dexron III/Mercon or equivalent ATF may also be used."
Why Canada?
I guess I'd probably buy the genuine nissan stuff...
Why did you say don't use PSF??
Old Sep 12, 2006 | 05:20 PM
Eazzy's Avatar
Eazzy
Well thats interesting----What yr is ur car QR25DE ???? My 03 Manual says*7 That Dexron III can be used.
Old Sep 12, 2006 | 05:21 PM
DavesZ#3's Avatar
DavesZ#3
Maybe he meant to say "don't use brake fluid".
Old Sep 12, 2006 | 05:24 PM
Eazzy's Avatar
Eazzy
No --I screwed up ---I swore that it specifically said Dextron---I would have always prefered to use clear PS fluid---
Old Sep 12, 2006 | 05:26 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
It does say DEXRON *may* be used, but I wonder why they say "For CANADA"
Old Sep 12, 2006 | 05:30 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
OK this one is from a 2002 service manual. Now I understand what they mean by "for canada"
Summary: it looks like you can use: Nissan PSF, Nissan PSF II, DEXRON, MERCON, Canadian Nissan ATF
Case closed
Attached Thumbnails Power steering fluid-untitled-2.jpg   Power steering fluid-untitled-3.jpg
Old Sep 12, 2006 | 05:33 PM
Eazzy's Avatar
Eazzy
Maybe for a colder Climate all round fluid-----I may just for a laugh be practicing what I preach this weekend and be syphoning mine out !!!
SSJVegita's Avatar
SSJVegita
well my car is a 03 manual.....i was thinking about filling it wit synthetic fluid from amsoil atf.....wouldnt that work.......???
Old Sep 12, 2006 | 05:36 PM
Eazzy's Avatar
Eazzy
Sometimes Synthetics are a little tough on certain types of seals ---Course this isnt as important as Engine oil or tranny fluid (In the Tranny !!!!)
Old Sep 12, 2006 | 05:39 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I recommend contacting amsoil and asking them if their ATF is equivalent to DEXRON III / MERCON. Or just use the nissan stuff.
Old Sep 12, 2006 | 05:48 PM
SSJVegita's Avatar
SSJVegita
cool guys thx...i guess ill just use the nissan stuff.....should be ok.....
Old Sep 12, 2006 | 05:53 PM
Eazzy's Avatar
Eazzy
Well as I said --its just not that big of a deal ---Iv been using the Dex for 50,000 miles. Had a friend in Fla that had an old Saab --PS leaked like crazy and he was crazy ( Yonkers NY ) He just carried water in a jug and used that. It lasted over a year.
Old Sep 12, 2006 | 05:57 PM
SSJVegita's Avatar
SSJVegita
where can i buy either the nissan stuff or the dex??
Old Sep 12, 2006 | 06:23 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
OMG water in the power steering? LOL pleeeeease don't do that
QR25 - try asking one of the performance nissan guys, they can get practically any part or fluid.
