G35C Engine Grounding/Earthing Kit
Old Mar 8, 2003 | 05:04 PM
BillR's Avatar
BillR
Default G35C Engine Grounding/Earthing Kit
I recently received and installed the Earthing Kit from Guy (Insanemaine). He custom designed an Earthing Kit for the G35C after I emailed him some measurements and photos. I am quite pleased with the turn around time, as I had the kit in no time!
The workmanship is truly professional. Instructions were very detailed and installation was a no brainer. I think it took me 15 - 20 minutes.
I went with silver cables around the engine and black cables where they attach to - battery or chassis ground. Of course Insaneamine has about every color to compliment your car. The kits looks bad *** installed.
Well how does the car perform with this kit?
Performance wise, it is smoother above 4000 RPM; subtle but noticeable. Throttle response appears to be more responsive and the shifts on the 5AT are definately much snappier. I even got the tires to break loose from 1st to 2nd!!!!
Nismo offers an Earthing kit as a performance option on the Z in Japan.
What does the Grounding System do?
The Grounding System can achieve an extreme improvement on electricity flow and stability by providing a direct ground path from the body, chassis and engine components to the battery negative.
This theory has been known & such system has been used in the racing world for years. Since 1.5 years ago, it has become the hottest modification performed by car enthusiasts in Japan. Its effect on automobile has been proven by dyno tests again and again.
Here is the link to LOTS more info om my350Z.com:
https://my350z.com/forum/showthread....0&pagenumber=1
What does that mean? If you got about $75.00 extra dollars and are interested in a possible smoother engine and better drivability, GET ONE OF THESE FROM INSANEAMINE.
To get your own kit or purchase info, here is Guys' email:
InSaNeAmine@***.net
Old Mar 8, 2003 | 06:49 PM
2003z's Avatar
2003z
any idea in the differences in sizes from the Z? I had 2 made during a group thing we did in atl, but havent got around to installing in the G. Any glaring differences?
Old Mar 9, 2003 | 04:19 AM
BillR's Avatar
BillR
Glaring differences? - no.
Some of the wires are shorter lengths though. One or two mounting points on the motor are a different location, but VERY similar to the Z.
I am very pleased with the results. It was worth the $ and effort.
Old Mar 18, 2003 | 03:53 PM
ihatethatbobbarker's Avatar
ihatethatbobbarker
anyone have directions online for the g35c
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
